Almost perfect payout winch launch.
Old May 10th 13, 03:55 PM posted to rec.aviation.soaring
Bill D
Default Almost perfect payout winch launch.
On Friday, May 10, 2013 8:42:39 AM UTC-6, Peter F wrote:
Don is right in thinking that there should be one person in charge of the launch.
Unfortunately the person he thinks should be in charge is at the wrong end of the cable.
You are correct, it's much better to have the pilot control airspeed with pitch. However, for this to happen, the winch has to control rope tension accurately as a percentage of glider weight. Control is divided where pilot controls airspeed and winch controls tension. This means Gary is right to control rope tension with his payout winch.
Old May 10th 13, 04:36 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
the=
launch.
en=
d of the cable.
p=
a=
pilot=
to=
No, I said there should be one person with total control of the winch, just
the same as the number of people in command of a glider. Would you fly an
airplane where one pilot had control of the stick pulling back and another
pilot was in control of pushing it forwards? The person in charge of the
launch is always the pilot of the glider who has absolute control of the
airspeed at all times via the stick and yellow knob.
From a 2500' run we get 1000 ft winch launches in still air. We are cleared
and capable of winching to 3000ft but seldom do, using a standard Skylaunch
winch.
Average winch launch at our site using the standard runs is 1500ft.
Old May 10th 13, 05:09 PM posted to rec.aviation.soaring
Bill D
the=
launch.
en=
d of the cable.
p=
a=
pilot=
to=
winch.
That's a fuzzy analogy. A better analogy is an airplane with a flight engineer controlling the power of the engines. The engineer (think winch operator) applies whatever power the pilot asks for. The pilot then takes that power and controls airspeed with pitch attitude.
Old May 10th 13, 05:25 PM posted to rec.aviation.soaring
WAVEGURU
Please describe to us a winch accident that would be the fault of the winch and not the pilot.
Boggs
Old May 10th 13, 06:12 PM posted to rec.aviation.soaring
Bill D
Boggs
First, Gary, let me say again I agree with your position on pilot responsibility and I would be perfectly willing to take a tow behind your payout winch. However, here's a couple of scenarios where a powerful winch can be safer than auto tow.
On a calm but strongly thermic day, a tailwind gust is encountered just as the glider begins rotation into the climb. If the winch has substantial reserve power, and is controlling rope tension, it will instantly add power to help the glider maintain a safe margin over stall in the critical rotation phase. In this case, the pilot has less control over his fate than the winch. If the winch or tow car power is marginal, the glider may stall in this situation.
This is why the DAeC Technical Committee guidelines set minimum power and rope speed requirements.
Another scenario is a winch which balks just after the glider is airborne leaving the glider momentarily gliding at minimum controllable airspeed. The winch then "catches" and applies full power. Without the runway surface supporting the tail wheel, and if the glider's CG is well above its hook, the inertial couple effect may cause a dangerous uncommanded pitch-up.
This is why the DAeC Technical Committee, in another paragraph, requires absolute smoothness in winch power without any tension oscillations or spikes in rope tension.
Ground launch payout winch systems...Are they suitable for gliders? [email protected] Soaring 13 August 13th 14 04:30 PM
Winch Launch Fatality Ed Gaddy[_2_] Soaring 3 June 23rd 09 11:15 PM
Pay out winch launch to 2500ft agl.. WAVEGURU Soaring 8 June 5th 07 07:06 AM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 12:33 AM
Winch launch M B Soaring 0 October 30th 03 07:33 PM
