PowerFLARM firmware v3.00 released (feature complete)
Old May 16th 13, 04:49 PM posted to rec.aviation.soaring
kirk.stant
Default PowerFLARM firmware v3.00 released (feature complete)
On Thursday, May 16, 2013 5:32:32 PM UTC+2, wrote:
Uh, Oh, Dave is getting angry! However, I agree with him. Downloading a flight trace is so easy. Turn off the brick, insert usb-stick, turn it back on and wait until the normal butterfly thingy is displayed with green status boxes. The unit will only download files that are not already on the stick and it beats the 4800 baud rate that I get with ConnectMe out of my 302 by a factor of 20.
Herb
No, Dave is getting frustrated, and I agree with him! If you upgrade the display software and look at the stupid thing - IT HAS AN IGC FILE DOWNLOAD FEATURE! So stick in the free USB extender, route it so you can reach it without taking your glider apart, then after your incredible flight, WITHOUT CYCLING THE PFB POWER, stick in your fancy thumb drive with the pretty lights, go to the igc file download menu, and get your stinking file so you can rush to post it on OLC to the amazement of the unwashed masses and adoration of the breathless groupies...
I would say RTFM, but of course the M isn't quite up to date yet...
Sheesh, don't you guys know any 14 year olds?
Kirk
66
Old May 16th 13, 09:29 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Kirk
66
AFAIK, I have updated to the latest of both display and core fw. There is a menu item for "IGC Download" - On and Off. I have it on. My understanding is not that this forces a download, rather, that it has the core send the file to the USB stick or not. The new manual (3.0 US) says
quote
To read out the flights to the USB stick:
ï‚· Switch CORE OFF after flight (allow at least 2 minutes after landing to avoid losing data).
ï‚· Connect USB stick to CORE.
ï‚· Switch CORE ON.
ï‚· Observe Status LED (flashing RED/GREEN) or progress indication on display to verify flights are being copied.
ï‚· Wait until system has started up normally after copying flights.
ï‚· Disconnect USB stick.
Some displays or flight computers allow reading out flights without switching the CORE OFF after the flight. Please refer to your system’s documentation for details.
PowerFLARM CORE-Manual 3.00 US, page 15ff
unquote.
I did RTFM. If it's accurate, you're wrong; I have tried what you suggest and it does not work - the IGC files do not appear on my stick unless I cycle the power.
Thank you for your wise words; they really helped.
Old May 16th 13, 10:06 PM posted to rec.aviation.soaring
Dave Nadler
Put the cursor on the "download IGC" choice and push the button.
Works great, Kirk is absolutely right.
This *should* be in the Butterfly documentation;
no idea if that has been updated.
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
PowerFLARM Portable - Firmware Update Available - Mode C Traffic Now Supported Paul Remde Soaring 24 January 22nd 12 01:50 AM
New ILEC SN-10 Firmware Paul Remde Soaring 5 August 25th 05 08:11 PM
v3.20 Firmware now out for Garmin 296 {nt} Cockpit Colin Piloting 0 March 8th 05 01:12 AM
Garmin 196 firmware update v3.1 released Aloft Piloting 0 August 13th 03 12:50 AM
