PowerFLARM firmware v3.00 released (feature complete)
Old May 17th 13, 12:59 AM posted to rec.aviation.soaring
Andrzej Kobus
Default PowerFLARM firmware v3.00 released (feature complete)
On May 16, 1:58*pm, Dave Nadler wrote:
On Thursday, May 16, 2013 12:11:24 PM UTC-4, wrote:
A friend has proposed the idea of using a fiber-optic cable to bring the
Core's LED out to the panel. *I don't know whether or not that will work,
but it is an interesting idea. *He's looking into it.
Paul, I've done this. You need to get good quality fiber optic
multi-strand and it works pretty well. *There is some loss but under
a shadowed part of the panel, you can see it just fine. *The trick is
to make a coupling for the fiber at the LED end.
Darren
Guys, you really don't need the LEDs.
Any display device *should* echo the relevant status messages.
The designers of PowerFlarm must have intended to put this LED on a
Christmas tree but they confused it with PowerFlarm brick and now we
have LED there that is not needed. Great!
Old May 17th 13, 09:58 AM posted to rec.aviation.soaring
kirk.stant
It's too bad the PowerFLARM display doesn't have an attitude indicator on it and a direct link to an online glider-for-sale site - then we could have a really good thread going!
Seriously, it can be frustrating, but if you ensure you have the correct files for updating the PF and display - making SURE you check the file name because Windows 7 WILL try to stick a .txt on it - the install is easy.
And if you have a Butterfly External display (the one that comes standard with the PF Core), you will no longer have to power cycle the PF to download.
And for Mike Stringfellow - With an Oudie, it is literally plug and play. The hardest part of installing the Flarm system is finding a place for all the antennas!
Let's all go flying!
Kirik
66
Old May 17th 13, 11:24 PM posted to rec.aviation.soaring
Craig Funston[_2_]
Kirik
66
RAS seems to serving perfectly well as an "Attitude Indicator". Happy Friday, let's go fly now.
Craig
Old May 17th 13, 09:31 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Andrzej Kobus wrote, On 5/16/2013 4:59 PM:
Core's LED out to the panel. I don't know whether or not that will work,
but it is an interesting idea. He's looking into it.
multi-strand and it works pretty well. There is some loss but under
a shadowed part of the panel, you can see it just fine. The trick is
Darren
My guess: one reason it's there is to give the pilot indication when
he's using a flight computer for the display, as they may not bother to
show update messages.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
PowerFLARM Portable - Firmware Update Available - Mode C Traffic Now Supported Paul Remde Soaring 24 January 22nd 12 01:50 AM
New ILEC SN-10 Firmware Paul Remde Soaring 5 August 25th 05 08:11 PM
v3.20 Firmware now out for Garmin 296 {nt} Cockpit Colin Piloting 0 March 8th 05 01:12 AM
Garmin 196 firmware update v3.1 released Aloft Piloting 0 August 13th 03 12:50 AM
