Butterfly vario side-by-side with ClearNav vario
Old May 18th 13, 07:30 AM posted to rec.aviation.soaring
krasw
Default Butterfly vario side-by-side with ClearNav vario
On Saturday, 18 May 2013 02:33:22 UTC+3, Eric Greenwell wrote:
krasw wrote, On 5/17/2013 10:33 AM:
(and as a side produt most accurate speed-to-fly commands I've seen).
In this respect Butterfly Variometer is not comparable with other
current systems. I think this fundamental difference is not
completely understood here.
I really curious about what an "accurate" speed-to-fly command is. What
is the command based on that makes it more accurate than the usual
variometer, like a 302?
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Speed-to-fly is essentially function of vertical airmass movement. When you get inertial-based netto, which is very fast and accurate, your speed-of-command accuracy goes up order of magnitude. With normal TE-based speed-to-fly you normally try to filter out gusts with longer time constant. With inertial netto this gust-induced noise transforms into data that you can use for calculating optimum STF.
With Butterfly I have actually started experimenting with extremely short time constant for inertial netto. It can be set so short that netto becames essentially a quantitative indicator of your seat-of-the-pants feeling. There seems to be no reason to filter or average this data so heavily.
krasw
Old May 18th 13, 10:14 AM posted to rec.aviation.soaring
kirk.stant
Watching the Butterfly vario video, it sure looks nice and smooth, with lots of information - then it occurred to me that this is a potential downside that the pilot will have to guard against - "clock watching" while thermalling, trying to make sense of all the changing data, and perhaps relying on Flarm to stay safe!
It's bad enough with all the data available on our glide computers and PNA displays, but that data is usually checked during cruise, and is more static in nature; while thermalling we try to rely on the audio vario and occasionally check inside for the average. Will conventional audio be sufficient to convey the data that the Butterfly (and by extension, CNv and other future varios) will be generating?
Perhaps more synthetic voice data to give trend info would allow the pilot to keep his eyes out of the cockpit and still make use of all the new data. "Gust", "Roll out - Turn in" (for thermal centering), "two six, two six" for the average, etc.
Or a head mounted display - JHMCS anyone? That would need a big battery!
It would be a shame to equip the fleet with Flarm just so we can thermal on instruments!
Kirk
Old May 18th 13, 01:08 PM posted to rec.aviation.soaring
son_of_flubber
Maybe Themi got it right, ten years ago. Two LEDs in peripheral vision.
Old May 19th 13, 10:56 AM posted to rec.aviation.soaring
kirk.stant
I think so, which is why I still have mine installed.
I like the combination of SN10 audio, Themi lights, and Oudie (with SN10 vario data) trail with vario dots for building a picture of the thermal with minimum time inside the cockpit.
Kirk
66
Old May 19th 13, 06:27 PM posted to rec.aviation.soaring
Hey Eric, I recently acquired butterfly varios for my ASH25. I immediately liked it better than my SN10's vario, and having flown the 302 a bunch in a Duo Discus I would put Cambridge in third place. I can't comment on the ClearNav . The audio is the most pleasant i've heard and the display is bright and delightful to view. I think it is equal to, if not better, than the high end Sage, and much more visible. I am still trouble shooting the more sophisticated features of the instrument. The artificial horizon is cool even if never used, and it doubles as a nice navigation, and final glide device. As far as the cruise control feature, at this point it seems like too much information to me. I just fly fast if the next thermal looks good, and slow if there might be trouble ahead, making some modest changes to accommodate en route sustained lift or sink. That horizontal gust thing might actually work, as it seems easier to center thermals with the Butterfly, although I might be inclined to say that about any variometer that cost as much as my first glider. As of now I think it might be a better mousetrap, and if you are interested come down and fly with me and check it out.
Dale
Old May 18th 13, 05:08 PM posted to rec.aviation.soaring
Maybe there's a good use for Google Glass here. Much easier than a HUD.
Chris
Old May 18th 13, 07:47 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
..... until Google decide its time for an ad break.
It seems that *will* be location-related ads shown ("Coffee time!" as you
pass Starbucks): this is one of the reasons why various states are
talking about banning their use while driving.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old May 18th 13, 04:30 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
krasw wrote, On 5/17/2013 11:30 PM:
What
STF.
Does it give the correct STF for 1 second from now? I can't possibly
change the speed of the glider that fast.
Or does it give me the STF for 10 seconds from now, which I might be
able to achieve with abrupt control movements?
And then, 10 seconds later, when I'm going the speed I was given, but
now I'm in air going down faster/slower, does it give me another STF
that will be wrong by the time I achieve that speed?
I'm trying get an idea of what you mean by "accurate" STF commands. The
top contest pilots I've followed seem to fly pretty steadily - will it
give me the STF that a top contest pilot will cruise at? That's what I
would call "accurate"!
email me)
Old May 18th 13, 05:10 PM posted to rec.aviation.soaring
krasw
email me)
I tried to tell that without accurate info on vertical airmass movement you can't have working STF command. This is where inertial system seems to be very good at. Sorry if I was unclear about this. Without good STF you would probably fly with predetermined still-air mc-speeds. Sure it works also, but it is not optimal. Plus if you know the airmass movement you have a better idea where to fly during glide.
krasw
Where are you Butterfly vario? [email protected] Soaring 17 May 25th 14 05:49 AM
Butterfly Vario IGC Richard[_9_] Soaring 3 April 3rd 13 03:24 PM
Butterfly vario review [email protected] Soaring 3 October 10th 12 08:50 PM
Butterfly vario info [email protected] Soaring 1 August 7th 12 10:08 PM
New Butterfly Vario Paul Remde Soaring 238 February 20th 12 04:05 AM
