FLARM IGC files: erasable?
Old May 20th 13, 04:25 AM posted to rec.aviation.soaring
Craig R.
Default FLARM IGC files: erasable?
To help the scorer, it would be nice to present a USB stick with only that day's contest file. But how can one delete all the other flight logs that end up on the USB stick, too?
From the updated Powerflarm manual:
CORE has internal memory for around 100 hours of flight recording at a 4s interval. Flight recording automatically starts when the aircraft starts moving and ends when the CORE is switched OFF or after more than 10 minutes of standstill. When the memory is full, the oldest flights are overwritten first.
Regarding the USB stick, the guys above are correct. The scorer shouldn't have issues if you have a valid .igc file for your contest day on the stick. They will find the correct file. Personally, I use a clean stick at the start of a contest and don't bother erasing anything until after the contest.
Craig R.
FLARM for SAR FLARM Soaring 57 November 21st 12 07:21 PM
Flarm v5 Kevin Neave[_2_] Soaring 5 February 23rd 11 01:35 PM
Successful conversion of .cai files to .igc files for OLC danlj Soaring 2 August 5th 07 02:45 PM
FLARM Robert Hart Soaring 50 March 16th 06 11:20 PM
Flarm Mal Soaring 4 October 19th 05 08:44 AM
