Martin Gregorie wrote: I wouldn't accept a winch or auto-tow launch if there wasn't a functional guillotine installed so that its release was instantly accessible to the driver and/or the person monitoring the launch. We used to do a lot of ground launching via the "pulley method". We always had an observer in the tow car watching the launch. Our "guillotine" was a sharp machete in the hands of the observer. Of course we were also taught to immediately bank into a tight turn and circle the tow vehicle if we could not release. I always had my doubts about recognizing the release failure in time to cut the line or to turn and get tension off the line before things got out of hand. All the pulley launch rigs I have seen are just a bare pulley, usually a truck rim mounted an a trailer hitch. No fairleads or other structure. I guess a guillotine could be mounted to such a rig. Would be a good Idea, I think. |
On Monday, May 20, 2013 9:19:03 AM UTC-5, WB wrote:
In article , Martin Gregorie wrote: I wouldn't accept a winch or auto-tow launch if there wasn't a functional guillotine installed so that its release was instantly accessible to the driver and/or the person monitoring the launch. We used to do a lot of ground launching via the "pulley method". We always had an observer in the tow car watching the launch. Our "guillotine" was a sharp machete in the hands of the observer. Of course we were also taught to immediately bank into a tight turn and circle the tow vehicle if we could not release. I always had my doubts about recognizing the release failure in time to cut the line or to turn and get tension off the line before things got out of hand. All the pulley launch rigs I have seen are just a bare pulley, usually a truck rim mounted an a trailer hitch. No fairleads or other structure. I guess a guillotine could be mounted to such a rig. Would be a good Idea, I think. If you're using a pulley why not just have a release on the tow vehicle? |
Tony wrote: If you're using a pulley why not just have a release on the tow vehicle? Hi Tony, I was unclear about the pulley launch. The pulley is on the tow vehicle. One end of the line is anchored, the line goes over the pulley to the glider. The tow vehicle is pulling from the middle of the rope, going in the same direction as the glider. The advantages are that acceleration at the glider is almost as fast as a winch launch and the tow car only has to go 25-30 mph maximum to launch the glider. No gear changes required, and the low vehicle speed means it can be done on less than paved surfaces. Launching with 4000 feet of dacron rope and an old LTD with 500 lbs of bricks in the trunk used to get our Ka-8 to 2000' if we had a bit of headwind. A release can be put at the anchor point, but that's a long way from where the action is. There are some other disadvantages to this type of ground launch as well. Turn around time is fairly long. Switching ends of the rope after each launch can speed things up especially if the anchor point is another vehicle. Rope recovery can be problematic since a chute is usually not part of the rope end hardware, so the rope tends to fall a ways downwind. |
On Monday, May 20, 2013 9:52:58 AM UTC-5, WB wrote:
In article , Tony wrote: If you're using a pulley why not just have a release on the tow vehicle? Hi Tony, I was unclear about the pulley launch. The pulley is on the tow vehicle. One end of the line is anchored, the line goes over the pulley to the glider. The tow vehicle is pulling from the middle of the rope, going in the same direction as the glider. The advantages are that acceleration at the glider is almost as fast as a winch launch and the tow car only has to go 25-30 mph maximum to launch the glider. No gear changes required, and the low vehicle speed means it can be done on less than paved surfaces. Launching with 4000 feet of dacron rope and an old LTD with 500 lbs of bricks in the trunk used to get our Ka-8 to 2000' if we had a bit of headwind. A release can be put at the anchor point, but that's a long way from where the action is. There are some other disadvantages to this type of ground launch as well. Turn around time is fairly long. Switching ends of the rope after each launch can speed things up especially if the anchor point is another vehicle. Rope recovery can be problematic since a chute is usually not part of the rope end hardware, so the rope tends to fall a ways downwind. ah i see, i was thinking of a fixed pulley. |
On Monday, May 20, 2013 11:00:54 AM UTC-4, Tony wrote:
On Monday, May 20, 2013 9:52:58 AM UTC-5, WB wrote: In article , Tony wrote: If you're using a pulley why not just have a release on the tow vehicle? Hi Tony, I was unclear about the pulley launch. The pulley is on the tow vehicle. One end of the line is anchored, the line goes over the pulley to the glider. The tow vehicle is pulling from the middle of the rope, going in the same direction as the glider. The advantages are that acceleration at the glider is almost as fast as a winch launch and the tow car only has to go 25-30 mph maximum to launch the glider. No gear changes required, and the low vehicle speed means it can be done on less than paved surfaces. Launching with 4000 feet of dacron rope and an old LTD with 500 lbs of bricks in the trunk used to get our Ka-8 to 2000' if we had a bit of headwind. A release can be put at the anchor point, but that's a long way from where the action is. There are some other disadvantages to this type of ground launch as well. Turn around time is fairly long. Switching ends of the rope after each launch can speed things up especially if the anchor point is another vehicle. Rope recovery can be problematic since a chute is usually not part of the rope end hardware, so the rope tends to fall a ways downwind. ah i see, i was thinking of a fixed pulley. Yes, fixed pulley has some advantages: quick turnaround, can use a chute, driver is facing the action. The disadvantage is that you drag the whole rope the length of the field at speed. I would think that would wear out Spectra pretty fast. There's some places that use multiple pulleys that can mitigate some of that. Check out the pulleylaunch Yahoo group for that. Matt |
On Monday, May 20, 2013 10:02:54 AM UTC-6, wrote:
On Monday, May 20, 2013 11:00:54 AM UTC-4, Tony wrote: On Monday, May 20, 2013 9:52:58 AM UTC-5, WB wrote: In article , Tony wrote: If you're using a pulley why not just have a release on the tow vehicle? Hi Tony, I was unclear about the pulley launch. The pulley is on the tow vehicle. One end of the line is anchored, the line goes over the pulley to the glider. The tow vehicle is pulling from the middle of the rope, going in the same direction as the glider. The advantages are that acceleration at the glider is almost as fast as a winch launch and the tow car only has to go 25-30 mph maximum to launch the glider. No gear changes required, and the low vehicle speed means it can be done on less than paved surfaces. Launching with 4000 feet of dacron rope and an old LTD with 500 lbs of bricks in the trunk used to get our Ka-8 to 2000' if we had a bit of headwind. A release can be put at the anchor point, but that's a long way from where the action is. There are some other disadvantages to this type of ground launch as well. Turn around time is fairly long.. Switching ends of the rope after each launch can speed things up especially if the anchor point is another vehicle. Rope recovery can be problematic since a chute is usually not part of the rope end hardware, so the rope tends to fall a ways downwind. ah i see, i was thinking of a fixed pulley. Yes, fixed pulley has some advantages: quick turnaround, can use a chute, driver is facing the action. The disadvantage is that you drag the whole rope the length of the field at speed. I would think that would wear out Spectra pretty fast. There's some places that use multiple pulleys that can mitigate some of that. Check out the pulleylaunch Yahoo group for that. Matt Yes, dragging a rope will wear it out. The car doing the dragging will also wear out fairly quickly. Auto tow is like drag racing - it puts a lot of strain on a car. Of course, start-up costs for auto tow are lower than a winch which makes it attractive but in the medium term (Say two years) a winch is much cheaper to operate. There are about 1500 clubs worldwide which use ground launch but only a handful use auto tow. They've found a winch is quicker, cheaper, safer and gets the glider higher using less space. By the time you've replaced a few ropes and tow cars, a winch starts looking pretty cheap. |
Bill D wrote: Matt Yes, dragging a rope will wear it out. The car doing the dragging will also wear out fairly quickly. Auto tow is like drag racing - it puts a lot of strain on a car. Of course, start-up costs for auto tow are lower than a winch which makes it attractive but in the medium term (Say two years) a winch is much cheaper to operate. There are about 1500 clubs worldwide which use ground launch but only a handful use auto tow. They've found a winch is quicker, cheaper, safer and gets the glider higher using less space. By the time you've replaced a few ropes and tow cars, a winch starts looking pretty cheap. Yep, we did that. We did the pulley ground launch until the club's founder, Glen Lawler, built the "Eagle Winch". We happily used it for several years before a change if airfield made winch use untenable (crossing runway, not enough runway length). Last I heard, the winch was at Philly Gliding Council. I miss it. We once launched half a contest grid with it. The other poor, benighted sods without a ground launch endorsement had to suffer aerotow. Speaking of Glen's winch, it had a wide drum requiring an active level wind mechanism to lay the line on evenly. Glen's level wind was a neat bit of engineering involving a slotted bar that cammed the guide back and forth across the drum. Have seen some pretty expensive winches that had level winds mechanisms that did the job, but were clearly not as precise as Glen's. Given that, if designing a winch, I'd go for simple with a large diameter drum that would not need an active level wind. |
![]() Matt Yes, dragging a rope will wear it out. The car doing the dragging will also wear out fairly quickly. Auto tow is like drag racing - it puts a lot of strain on a car. Of course, start-up costs for auto tow are lower than a winch which makes it attractive but in the medium term (Say two years) a winch is much cheaper to operate. There are about 1500 clubs worldwide which use ground launch but only a handful use auto tow. They've found a winch is quicker, cheaper, safer and gets the glider higher using less space. By the time you've replaced a few ropes and tow cars, a winch starts looking pretty cheap. We shortened the life of a Nissan Pathfinder transmission autolaunching at remote locations. Our primary launch car at home was straight out of a scrap yard. It was an old LTD with a big motor, maybe a 460. I think it actually only ran on 5 cylinders though. The transmission was crap but it worked in low gear and reverse. That was all we needed. Oh, and the 500 lbs of salvaged brick wall that we put into the trunk to hold the back end down when the glider was at the top of the climb. |
On Monday, May 20, 2013 8:26:41 AM UTC-6, Tony wrote:
On Monday, May 20, 2013 9:19:03 AM UTC-5, WB wrote: In article , Martin Gregorie wrote: I wouldn't accept a winch or auto-tow launch if there wasn't a functional guillotine installed so that its release was instantly accessible to the driver and/or the person monitoring the launch. We used to do a lot of ground launching via the "pulley method". We always had an observer in the tow car watching the launch. Our "guillotine" was a sharp machete in the hands of the observer. Of course we were also taught to immediately bank into a tight turn and circle the tow vehicle if we could not release. I always had my doubts about recognizing the release failure in time to cut the line or to turn and get tension off the line before things got out of hand. All the pulley launch rigs I have seen are just a bare pulley, usually a truck rim mounted an a trailer hitch. No fairleads or other structure. I guess a guillotine could be mounted to such a rig. Would be a good Idea, I think. If you're using a pulley why not just have a release on the tow vehicle? http://framework.latimes.com/2013/05...hed-sailplane/ |
On Tuesday, May 21, 2013 5:20:21 PM UTC-6, Frank Whiteley wrote:
http://framework.latimes.com/2013/05...hed-sailplane/ Bad Photoshop job. You can see the real rope going past the horse to something out of the frame that's really launching the glider. However, it would have to be a gentile something - that's a Baby Albatross with a, IIRC, 65mph Vne. |
Ground launch payout winch systems...Are they suitable for gliders? | [email protected] | Soaring | 13 | August 13th 14 04:30 PM |
Winch Launch Fatality | Ed Gaddy[_2_] | Soaring | 3 | June 23rd 09 11:15 PM |
Pay out winch launch to 2500ft agl.. | WAVEGURU | Soaring | 8 | June 5th 07 07:06 AM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
Winch launch | M B | Soaring | 0 | October 30th 03 07:33 PM |
