Almost perfect payout winch launch.
Old May 20th 13, 09:07 PM posted to rec.aviation.soaring
Wallace Berry[_2_]
Default Almost perfect payout winch launch.
Bill D wrote:
Matt
Yes, dragging a rope will wear it out. The car doing the dragging will also
wear out fairly quickly. Auto tow is like drag racing - it puts a lot of
strain on a car.
Of course, start-up costs for auto tow are lower than a winch which makes it
attractive but in the medium term (Say two years) a winch is much cheaper to
operate. There are about 1500 clubs worldwide which use ground launch but
only a handful use auto tow. They've found a winch is quicker, cheaper,
safer and gets the glider higher using less space.
By the time you've replaced a few ropes and tow cars, a winch starts looking
pretty cheap.
Yep, we did that. We did the pulley ground launch until the club's
founder, Glen Lawler, built the "Eagle Winch". We happily used it for
several years before a change if airfield made winch use untenable
(crossing runway, not enough runway length). Last I heard, the winch was
at Philly Gliding Council. I miss it. We once launched half a contest
grid with it. The other poor, benighted sods without a ground launch
endorsement had to suffer aerotow.
Speaking of Glen's winch, it had a wide drum requiring an active level
wind mechanism to lay the line on evenly. Glen's level wind was a neat
bit of engineering involving a slotted bar that cammed the guide back
and forth across the drum. Have seen some pretty expensive winches that
had level winds mechanisms that did the job, but were clearly not as
precise as Glen's. Given that, if designing a winch, I'd go for simple
with a large diameter drum that would not need an active level wind.
Old May 21st 13, 09:49 AM posted to rec.aviation.soaring
Chris Nicholas[_2_]
It is possible and highly desirable to fit a guillotine to a pulley system. My club had considerable experience with reverse pulley for many years when we had a hard runway, and developed it to a great degree.
Method: We had 2 pulley wheels in a frame which pivoted about a horizontal axis, and also mounted so that it could swing sideways. This enabled the cable to run true from glider to one pulley, and from the other pulley to the tow vehicle. Both pulleys were framed in lead-in guards. The horizontal pivot was hollow. A spring loaded chisel-edged cutter ran through it. This could be released from the cab of the truck on which the pulley system was mounted. It would hit the cable, against an anvil mounted between the two pulleys. It worked.
Reason: Cable hang-ups at the glider end are not unknown. One fatal accident in the UK in the 1970’s arose from this (either release hook did not work, or cable wrapped round wheel, on a winch launch). With the cable taut, the glider described an arc from nearly above the winch to the ground. A non-fatal accident from a similar cause was addressed by the pilot circling over the winch while descending, straightening up with slack in the cable near the ground and landing downwind.
Mitigation: Plastic hose round the strop from weak link/drogue to glider prevents hang-up round the wheel/axle, but faulty cable release in the glider still needs the safety of a guillotine.
Chris N
Old May 21st 13, 03:10 PM posted to rec.aviation.soaring
Wallace Berry[_2_]
worked.
Sounds like an excellent setup. If we ever do groundlaunch again, we
will have to put together a guillotine system like that. Your guillotine
sounds almost identical to the one Glen Lawler put on the Eagle Winch.
It was a spring loaded chisel firing against an anvil. A hydraulic jack
was used to cock the thing. Made a heck of bang when fired. It would
shear steel rope like it was made of air. Not sure how well it worked on
Spectra, but I would expect that it had no trouble with it, especially
with any tension on the line.
Old May 21st 13, 04:41 PM posted to rec.aviation.soaring
Bill D
worked.
I suggest a cheaper and safer guillotine is a simple air cylinder powered by a portable air tank. I bought a new 2" bore Bimba cylinder on eBay for $15 and an air tank with pressure gauge from Harbor Freight for $25. A "pop-open" push-button air valve and some air hose completes the system.
A 2" cylinder produces exactly 3.1316 pounds-force for every PSI. The tank holds over 100 PSI so the cylinder can drive a chisel blade with at least 313 Lbs-F which WILL cut a rope. Checking the gauge on the tank assures you have air pressure. If necessary, refill with any shop air compressor. Unlike a steel spring, compressed air doesn't rust or lose strength with age..
Why is it safer? You can de-energize by just removing the air hose to the guillotine so there's no chance of losing a finger. Spring powered guillotines resemble bear traps and have to be relaxed VERY CAREFULLY to work on them.
Old May 23rd 13, 02:35 PM posted to rec.aviation.soaring
Wallace Berry[_2_]
on them.
I don't think we had to worry about the spring losing strength. It took
around 500 lbs to compress it IIRC so it had some margin. Valve springs
on cars sit compressed for long periods without losing strength. Might
get rusty, but the winch was only outside when being used. No argument
about the bear trap. We did not put our fingers anywhere near that thing.
We "relaxed" ours by firing it. Not a gentle process, but worth it in
entertainment value! We never fired it in anger, not sure about
subsequent users.
I drove about 2000 launches with that winch and I miss it!
Old May 22nd 13, 12:18 AM posted to rec.aviation.soaring
Frank Whiteley
worked.
http://www.coloradosoaring.org/think...ey/default.htm
No guillotine, wire and tackle pulled through the 'pulley' apparently.
Ground launch payout winch systems...Are they suitable for gliders? [email protected] Soaring 13 August 13th 14 04:30 PM
Winch Launch Fatality Ed Gaddy[_2_] Soaring 3 June 23rd 09 11:15 PM
Pay out winch launch to 2500ft agl.. WAVEGURU Soaring 8 June 5th 07 07:06 AM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 12:33 AM
Winch launch M B Soaring 0 October 30th 03 07:33 PM
