On Tuesday, May 21, 2013 9:32:28 PM UTC-4, WaltWX wrote:
I'm going to buy a Nano and wire it up before I leave... Hey Walt - Get a PowerFLARM if you haven't already done so ! Logger works great, SN10 can declare task into PowerFLARM. Hope that helps, See ya, Dave PS: 2.38 is now released: http://www.nadler.com/sn10/SN10_Resource_Index.html |
Hi Dave,
I've already got PowerFlarm. It drives LK8000 on the Vertica V2 which can also declare tasks on the PF. I've been using igc files from the PF for the last half dozen flights and they validate fine on OLC. Want to keep full logger redundancy each driving their own flight software. Needed to replace the VL with another logger that has validation for all flights. PF doesn't isn't good for National or World records. BTW, ten pilots out of 14 flew PF at our local Central California Soaring Contest and v3.0 worked just fine. PCAS seems more sensitive. FLARM sensitivity worked great in and around gaggles. Walt Rogers WX |
Dave,
Can the SN10B declare tasks to an attached (wired RS-232 interface) Nano data logger? Walt Rogers WX |
Hi Walt,
The SN10 can send task declarations to Volksloggers and FLARMs, but not to Nano's or anything else. Best Regards, Paul Remde Cumulus Soaring, Inc. _____________________________ "WaltWX" wrote in message ... Dave, Can the SN10B declare tasks to an attached (wired RS-232 interface) Nano data logger? Walt Rogers WX |
Download Volkslogger IGC file to SeeYou SOLVED - updated USB converter FTDI Driver | Kimmo Hytoenen | Soaring | 0 | March 23rd 13 11:00 PM |
Download Volkslogger IGC file to SeeYou SOLVED - updated USBconverter FTDI Driver | WaltWX[_2_] | Soaring | 4 | March 23rd 13 08:32 PM |
Volkslogger download from Android | [email protected] | Soaring | 0 | January 12th 13 10:31 PM |
Need help with Garmin 196 data transfer (long) | RNR | Piloting | 7 | March 17th 05 07:37 AM |
Garmin Emap Handheld GPS w/ Remote Antenna AND Data Transfer Cable | Cecil E. Chapman | Products | 0 | October 1st 03 02:06 AM |
