FAR 61.58 regarding HpH 304SJ,Jonker JS1-CJT, et al jet sustainers
Old May 23rd 13, 03:16 AM posted to rec.aviation.soaring
Default FAR 61.58 regarding HpH 304SJ,Jonker JS1-CJT, et al jet sustainers
Under current FAR 61.58, paragraph (f) states:
" (f) This section will not apply to a pilot authorized by the Administrator to serve as pilot in command in experimental turbojet- powered aircraft that possesses, by original design, a single seat, when operating such single-seat aircraft."
Questions:
Is it correct to assume the 304SJ and the JS1-CJT are imported as experimental sailplanes?
FAA Admininstrator would be FSBO? What would be criteria for district FSBO to "authorize" pilot?
Old May 23rd 13, 04:51 AM posted to rec.aviation.soaring
For now, all US jet sailplanes are experimental. All single seaters are exempt from the 61.58 yearly proficiency check. As for what is required to fly one, there isn't a good standard yet. I fly my Salto with only a glider rating and motorglider endorsement. The BonusJet requires an LOA (partly due to my ability to provide training for hire). It will depend somewhat on the whims of your FSDO (and insurance company).
I do have a Letter Of Deviation Authority (LODA) to provide jet transition training in the BonusJet. Come out to Moriarty and experience some great soaring while learning the nuances of flying a jet sailplane. You actually get it listed on your pilot certificate like a type rating.
Bob
Questions:
Old May 23rd 13, 04:52 PM posted to rec.aviation.soaring
Thanks Bob for your response. No doubt the authorization "by the Administrator to serve as pilot in command" is abstract as opposed to specific and will vary from one FSDO to another.
Ben
FS: Jonker Sailplane, JS1B, N51WE [email protected] Soaring 10 June 16th 13 04:48 AM
Jonker Revalation ( JS -1 ) [email protected] Soaring 1 August 7th 10 12:03 PM
Jonker JS1 Winning US 18m Nationals? Greg Arnold[_2_] Soaring 3 May 21st 08 06:01 PM
Jonker JS1 Winning US 18m Nationals? Paul Remde Soaring 1 May 21st 08 05:08 PM
Jonker 18 meter sailplane Greg Arnold Soaring 4 November 4th 06 02:15 AM
