How important are aileron gap seals?
Old May 23rd 13, 06:28 PM posted to rec.aviation.soaring
Andrew[_14_]
Default How important are aileron gap seals?
I imagine external seals are much more critical/effective on high-performance gliders where transition to turbulent flow occurs aft of the aileron and flap hinge lines. Otherwise a nice gap could certainly cause earlier transition.
Typically, on older gliders where transition occurs ahead of the hinge line the manufacturer recommends Tesa tape on the bottom hinge only. Having a smooth/flush seal isn't so critical anymore since the flow is already turbulent. However, it's still effective because it's a pressure barrier and prevents flow through the control gap.
Installing aileron/flap seals Uncle Fuzzy[_2_] Soaring 5 April 17th 13 11:52 PM
Mylar aileron and flap seals Grider Pirate[_2_] Soaring 12 June 2nd 12 01:52 AM
mylar seals wing to flap/ Aileron culverflyer Soaring 2 May 5th 04 02:52 PM
mylar seals D.A.L Soaring 1 February 23rd 04 07:15 PM
New ear seals Chris Owning 7 December 16th 03 01:02 AM
