Jeff Bennett leaves Cambridge Aero Instruments
Old May 24th 13, 09:46 AM posted to rec.aviation.soaring
Peter F[_2_]
Default Jeff Bennett leaves Cambridge Aero Instruments
I believe the advice given by an English 2x World Champion is to have a
good, well compensated, leak free, simple, vario then spend the difference
on Aerotows.
Likewise most modern (Standard Class) gliders have a kink in the polar,
such that best speed to fly for almost any rate of climb is somewhere
around the kink. So there are in fact only two speeds to fly; at the kink
if you're comfy, best LD if you're in survival mode.
So for the original Discus (Dry) it's either 80kts or 50kts
PF
At 14:00 23 May 2013, Wallace Berry wrote:
In article
The more I read about high end instruments, the less I regret not being
able to afford them.
I have asked a number of people to explain to me exactly what their
"super varios" do that a good basic vario and a decent PDA/software
setup does not do. I mean besides calculating to more decimal places.
Maybe I would understand if I flew a glider with more than two speeds....
Old May 24th 13, 11:37 AM posted to rec.aviation.soaring
Mike Clarke
difference
on Aerotows.
PF
I had the great pleasure of flying with the same English 2x World Champion
two weeks ago. His advice for modern 18m gliders was also two speeds,
90-100kts or 60kts. I tried it, it works!
Mike
Where is Cambridge Aero Instruments Dan Marotta Soaring 2 February 28th 12 01:05 AM
Cambridge Aero Instruments - The Future Looks Bright Paul Remde Soaring 0 June 27th 08 03:27 PM
Cambridge Instruments Ian McPhee Soaring 2 June 18th 04 10:14 AM
Cambridge Aero Instruments Ulrich Soaring 6 August 7th 03 05:48 PM
Cambridge Aero Instruments Inc. Changeover Joe McCormack Soaring 3 July 30th 03 08:45 PM
