On Wednesday, May 29, 2013 9:47:00 AM UTC-6, JohnDeRosa wrote:
About the automotive units in general and Harbor Freight cheapie unit in particular. http://www.harborfreight.com/1250-lb...lly-67287.html I looked at the HF unit and here are some comments; 1) It can be adjusted fore/aft for some pretty small tires including the common 350x135 glider tires. I don't think that it will "pinch" tires (as mentioned by Dave Springford). YMMV. 2) If the width needs to be narrowed, the HF unit could "easily" be changed (cough...with a hacksaw and muscle). However, the wider stance may be good for stability and dealing with #3. 3) The jack handle may need to be bent or adjusted to get out of the way of the fuselage (as Steve Leonard mentions) while still retain functionally. The other brands mentioned above tilt the entire lift mechanism, not just bend the handle. This may be the trickiest thing to correct but may be unneeded due to #2. 4) Sure is cheaper than the alternatives! Allows for low cost experimentation! - John The Gojack or this one will probably work - with modifications. However, there's an opportunity to do better by using the jack-able fuselage trailer dollies used with some fixed-gear twins as a model. By lifting the fuselage instead of the wheel, the tire and gear doors are accessable for maintenance |
Glider Main Wheel Dolly | Jim[_18_] | Soaring | 0 | March 9th 11 04:19 PM |
ETA glider landing with heavy front wind in Rieti, videoclip | PCool | Soaring | 2 | October 1st 09 03:10 PM |
Glider Hangar Tie-Downs | V1 | Soaring | 0 | March 19th 09 02:09 PM |
Club Glider Hangar? | noel.wade | Soaring | 33 | January 14th 08 10:47 PM |
Ideal Glider Hangar Dimensions | SGS135 | Soaring | 3 | November 27th 04 11:04 PM |
