Question about PowerFlarm IGC recording rate
Old June 1st 13, 04:54 AM posted to rec.aviation.soaring
Ron Gleason
Default Question about PowerFlarm IGC recording rate
On Friday, 31 May 2013 21:47:49 UTC-6, SoaringXCellence wrote:
I just had my first flight with my newly updated PowerFlarm. I was able to download the ICG file to the microSD card and it all worked great.
BUT, (there's always a but), I also had another recorder (XCSoar, thank you VERY much) and compared the files with SeeYou. It appears the PF is recording at a rate of about a point about every 10-12 seconds. I'd like to have files with a little more detail.
Does anyone know if/how the rate can be changed?
Mike
Mike
The B records of the IGC file are the fix records
A4.1.1 The format of the basic data, with extra spaces for clarity, is:
B HHMMSS DDMMM MmmmN DDDMMmmm E V PPPPP GGGGG CR LF
The one IGC file I reviewed from a PF had a 8 second interval on the ground and 4 seconds once in the air.
Open the IGC with an application like NOTEPAD and look at the file
I do not know how you can specify with PF the recording interval.
Ron
PowerFLARM Mode S question kirk.stant Soaring 54 October 26th 10 02:51 PM
Question: Standard rate turns, constant rate turns, and airspeed Robert Barker Piloting 5 April 15th 07 04:47 PM
camcorder recording Cessna intercom audio question Marty from Sunny Florida Owning 7 November 15th 04 04:26 PM
Newbie question on Rate of Climb Wright1902Glider Home Built 0 August 17th 04 03:48 PM
Lapse Rate Question Waduino Soaring 0 October 1st 03 07:32 PM
