After reading the Colibri V1 thread, I had a similar issue yesterday.
Upon submitting the log from my 302 to OLC, the flight didn't appear with today's date. Investigating, I found a 2005 date for the flight. I simply submitted the log from my Dell Streak 5 which runs XCSoar to get credit for the flight. Next time I fly I'll see if it works correctly. It's been less than 2 years since I sent it to Gary for repair, calibration, and battery replacement. I hope I don't have the same problem as the Colibri. Dan |
Hi Dan,
The date problem with 302 was probably caused by taking-off before the 302 had locked on to satellites. Best Regards, Paul Remde Cumulus Soaring, Inc. ______________________________ "Dan Marotta" wrote in message ... After reading the Colibri V1 thread, I had a similar issue yesterday. Upon submitting the log from my 302 to OLC, the flight didn't appear with today's date. Investigating, I found a 2005 date for the flight. I simply submitted the log from my Dell Streak 5 which runs XCSoar to get credit for the flight. Next time I fly I'll see if it works correctly. It's been less than 2 years since I sent it to Gary for repair, calibration, and battery replacement. I hope I don't have the same problem as the Colibri. Dan |
I second Paul's observations. This happened to me a few weeks ago with my
302 and I'm pretty sure I took off before the satellites had locked on. The IGC file had over 20 data points from the midwest (Paul's country), though I fly in Northern NV and the file date was 2005. It's worked fine on several flights since. David Prather At 18:46 05 June 2013, Paul Remde wrote: Hi Dan, The date problem with 302 was probably caused by taking-off before the 302 had locked on to satellites. Best Regards, Paul Remde Cumulus Soaring, Inc. ______________________________ "Dan Marotta" wrote in message ... After reading the Colibri V1 thread, I had a similar issue yesterday. Upon submitting the log from my 302 to OLC, the flight didn't appear with today's date. Investigating, I found a 2005 date for the flight. I simply submitted the log from my Dell Streak 5 which runs XCSoar to get credit for the flight. Next time I fly I'll see if it works correctly. It's been less than 2 years since I sent it to Gary for repair, calibration, and battery replacement. I hope I don't have the same problem as the Colibri. Dan |
Premature aviation... nothing to be ashamed of...
Ouch!
OK, I'll fire it up sooner next time. Thanks, Guys! Dan wrote in message ... Premature aviation... nothing to be ashamed of... |
Cambridge Model 10/20/25 and 302/302A recorders contain Garmin
Receivers used for GPS reception. These receivers use internal (a metal shielding cover needs to be unsoldered for access) 3v rechargeable batteries. This battery keeps a memory chip "alive" when the recorder is turned off. Most of these receiver batteries are starting to or already have reached end of life (unable to hold a charge) due to their age. These Garmin internal batteries have nothing at all to do with the 3v security batteries that need to be replaced every few years. One of the side effects of failing batteries are what y'all have been describing. Basically the Garmin has lost it's memory and defaults to its original settings. Since the last date, time and location are lost when the device is turned off, it can take awhile, sometimes a very long while depending on which version of the Garmin Receiver is installed in the product, before it determines where it is and subsequently locks onto enough satellites to get a 3D fix and update it's memory. Depending on the state of the battery the stored data may be lost as soon as it's turned off or however long the battery can keep the memory refreshed.....an hour, day, week.......it will vary and get worse. Sometimes, not often and I'm not sure why, the Garmin receivers will get a fix but not update the date correctly. At that sorry point they will need to be serviced by a qualified service tech. The rechargeable battery can be replaced with a new one and the Garmin can be reconfigured. ST |
Interesting... Thanks!
"Soaring Tech" wrote in message ... Cambridge Model 10/20/25 and 302/302A recorders contain Garmin Receivers used for GPS reception. These receivers use internal (a metal shielding cover needs to be unsoldered for access) 3v rechargeable batteries. This battery keeps a memory chip "alive" when the recorder is turned off. Most of these receiver batteries are starting to or already have reached end of life (unable to hold a charge) due to their age. These Garmin internal batteries have nothing at all to do with the 3v security batteries that need to be replaced every few years. One of the side effects of failing batteries are what y'all have been describing. Basically the Garmin has lost it's memory and defaults to its original settings. Since the last date, time and location are lost when the device is turned off, it can take awhile, sometimes a very long while depending on which version of the Garmin Receiver is installed in the product, before it determines where it is and subsequently locks onto enough satellites to get a 3D fix and update it's memory. Depending on the state of the battery the stored data may be lost as soon as it's turned off or however long the battery can keep the memory refreshed.....an hour, day, week.......it will vary and get worse. Sometimes, not often and I'm not sure why, the Garmin receivers will get a fix but not update the date correctly. At that sorry point they will need to be serviced by a qualified service tech. The rechargeable battery can be replaced with a new one and the Garmin can be reconfigured. ST |
| Thread Tools | |
| Display Modes | |
| CAI 302 date problem | Bernie[_4_] | Soaring | 21 | May 6th 16 03:38 AM |
| FSDO enforcement- GPS before effective date - which date to put in Aircraft Log for Part 43? | Ron A. | Instrument Flight Rules | 18 | March 15th 06 03:30 PM |
| First Date | Jay Honeck | Piloting | 35 | September 14th 05 05:42 AM |
| GPS 90b out of date? | Roger Long | Piloting | 2 | August 8th 03 04:58 PM |
| Need a date.... | Sagz525 | Instrument Flight Rules | 2 | July 23rd 03 03:34 PM |
