On Sunday, June 9, 2013 12:04:54 PM UTC-4, Bill D wrote:
Some form of AoA sensing/stall warning is installed on every aircraft made - except rotorcraft and gliders. Do many pilots recount hearing the stall alarm on the turn to final and then saving their own butt? Or are stall alarms only effective when they go off high above the ground? |
On Sunday, June 9, 2013 9:27:16 PM UTC-6, son_of_flubber wrote:
On Sunday, June 9, 2013 12:04:54 PM UTC-4, Bill D wrote: Some form of AoA sensing/stall warning is installed on every aircraft made - except rotorcraft and gliders. Do many pilots recount hearing the stall alarm on the turn to final and then saving their own butt? Or are stall alarms only effective when they go off high above the ground? Most definitely! Low altitude is where they save your butt. |
I've found stall horns annoying in high performance flying. It's the
physical signals the airplane gives, not alarms, that tell me a stall is imminent. You should really learn to feel the aircraft and not rely on horns, bells, whistles, gauges, etc. They WILL fail some day... "Bill D" wrote in message ... On Sunday, June 9, 2013 9:27:16 PM UTC-6, son_of_flubber wrote: On Sunday, June 9, 2013 12:04:54 PM UTC-4, Bill D wrote: Some form of AoA sensing/stall warning is installed on every aircraft made - except rotorcraft and gliders. Do many pilots recount hearing the stall alarm on the turn to final and then saving their own butt? Or are stall alarms only effective when they go off high above the ground? Most definitely! Low altitude is where they save your butt. |
On Monday, June 10, 2013 9:03:38 AM UTC-6, Dan Marotta wrote:
You should really learn to feel the aircraft and not rely on horns, bells, whistles, gauges, etc. They WILL fail some day... Straw man argument.... 99.9% of the time they don't fail and they save lives. I can assure I do know what an impending stall feels like. However, for most people, it doesn't take much distraction for them to miss the sensations.. Our miserable safety record proves that. The entirety of aviation, excluding gliders, has found AoA/stall warning systems necessary whether it's high performance jets or airliners. Presumably, the professionals flying them can feel a stall developing but their stall warning systems are still a no-go item. |
Yes, I know that the MEL requires a lot of stuff. Still, what do you do
when it fails? My argument is not so much about the equipment as it is about slavishly relying on devices to bring you home. You WILL have electrical failure some day and will have to actually read a map, land visually, respond to light signals from a control tower, pick up a wing with rudder instead of aileron. Your 99.9% argument omits the 0.1% and that's a lot higher number than the number of accidents per 100,000 flying hours. Aviation requires nothing but skill and attention in maintenance and operation. Bells and whistles are mandated by the barn door closers. "Bill D" wrote in message ... On Monday, June 10, 2013 9:03:38 AM UTC-6, Dan Marotta wrote: You should really learn to feel the aircraft and not rely on horns, bells, whistles, gauges, etc. They WILL fail some day... Straw man argument.... 99.9% of the time they don't fail and they save lives. I can assure I do know what an impending stall feels like. However, for most people, it doesn't take much distraction for them to miss the sensations. Our miserable safety record proves that. The entirety of aviation, excluding gliders, has found AoA/stall warning systems necessary whether it's high performance jets or airliners. Presumably, the professionals flying them can feel a stall developing but their stall warning systems are still a no-go item. |
Dan Marotta wrote, On 6/10/2013 9:04 AM:
Yes, I know that the MEL requires a lot of stuff. Still, what do you do when it fails? My argument is not so much about the equipment as it is about slavishly relying on devices to bring you home. You WILL have electrical failure some day and will have to actually read a map, land visually, respond to light signals from a control tower, pick up a wing with rudder instead of aileron. Your 99.9% argument omits the 0.1% and that's a lot higher number than the number of accidents per 100,000 flying hours. Aviation requires nothing but skill and attention in maintenance and operation. Bells and whistles are mandated by the barn door closers. Yes, devices fail, but so do people. If the device fails less often than the people, would you accept the device as useful? My experience is I fail more often than the devices, such as gear warnings, slow speed warnings, automatic hookups, and more. My radios have worked reliably, but I haven't always set the frequency correctly. I made more mistakes with paper maps than I ever did because the GPS failed, and I've flown more hours with GPS than with maps. I think each device has to be evaluated for efficacy, not discarded because it might fail some day. If we treated pilots the same way, there would be no pilots, either. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl |
On 6/10/2013 11:39 AM, Bill D wrote:
The entirety of aviation, excluding gliders, has found AoA/stall warning systems necessary whether it's high performance jets or airliners. I don't fly either jets or airliners, but I can tell you that the average Joe learning to fly in, or renting, an old Cezzna probably can't hear the stall alarm because they were never designed to overpower the noise isolation of today's headsets. |
On Monday, June 10, 2013 12:40:43 PM UTC-6, Vaughn wrote:
On 6/10/2013 11:39 AM, Bill D wrote: The entirety of aviation, excluding gliders, has found AoA/stall warning systems necessary whether it's high performance jets or airliners. I don't fly either jets or airliners, but I can tell you that the average Joe learning to fly in, or renting, an old Cezzna probably can't hear the stall alarm because they were never designed to overpower the noise isolation of today's headsets. Well...as one data point, my hearing isn't great and I wear an excellent noise cancelling headset but I can plainly hear a Cessna stall warning. |
On 6/10/2013 3:03 PM, Bill D wrote:
Well...as one data point, my hearing isn't great and I wear an excellent noise cancelling headset but I can plainly hear a Cessna stall warning. I can't, and that's with about a decade of experience with a pretty wide selection of rental Cezznas using both passive and electronic headsets. Surely I'm not alone. |
Another stall spin | Jp Stewart | Soaring | 153 | September 14th 12 07:25 PM |
Stall/ Spin testing the RV-12 | cavelamb himself[_4_] | Home Built | 3 | May 14th 08 07:01 PM |
Glider Stall Spin Video on YouTube | ContestID67 | Soaring | 13 | July 5th 07 08:56 AM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
