On Monday, June 10, 2013 9:39:26 AM UTC-7, jfitch wrote:
On Monday, June 10, 2013 8:53:21 AM UTC-7, Dan Marotta wrote: Neither Flarm nor transponder will protect against VFR aircraft not in contact with ATC. PCAS might work for that, however. I was under the impression that PowerFlarm (not Flarm) did that since it receives Mode C replies. Is that not the case? Yes, but I was replying to Dan who doesn't want a Flarm. We have lots of aviation traffic going to small airfields that are not in contact with ATC. Single-engine stuff is usually low down, but twins are often coming in from a destination further away and descend through airspace near the gliderport. They never seem to be looking out of their windows and won't be aware of me unless they too have a PCAS. Mike |
On Monday, June 10, 2013 10:06:24 AM UTC-7, Mike the Strike wrote:
On Monday, June 10, 2013 9:39:26 AM UTC-7, jfitch wrote: On Monday, June 10, 2013 8:53:21 AM UTC-7, Dan Marotta wrote: Neither Flarm nor transponder will protect against VFR aircraft not in contact with ATC.. PCAS might work for that, however. I was under the impression that PowerFlarm (not Flarm) did that since it receives Mode C replies. Is that not the case? Yes, but I was replying to Dan who doesn't want a Flarm. We have lots of aviation traffic going to small airfields that are not in contact with ATC.. Single-engine stuff is usually low down, but twins are often coming in from a destination further away and descend through airspace near the gliderport. They never seem to be looking out of their windows and won't be aware of me unless they too have a PCAS. Mike Every now and then the argument of flarm vs transponder will come up. This is like comparing apples to oranges. These are not alternative solutions. Each has different purpose and each solution is highly desirable depend on where you fly. Dan flies out of Moriarty so obviously both are desired. Sooner or later those who insist on never installing a flarm will find themselves less popular among their flying buddies who went through the trouble of installing. You may hear on the radio "watch out for a bozo flying around without flarm". My message to those who can afford a powerflarm but don't think they need it: Install one anyway and turn the display off if you want. At least we will be able to see and avoid you. You may never know that it saved your butt. Ramy |
On Monday, June 10, 2013 12:15:16 PM UTC-7, Ramy wrote:
Sooner or later those who insist on never installing a flarm will find themselves less popular among their flying buddies who went through the trouble of installing. You may hear on the radio "watch out for a bozo flying around without flarm". My message to those who can afford a powerflarm but don't think they need it: Install one anyway and turn the display off if you want. At least we will be able to see and avoid you. You may never know that it saved your butt. Ramy __________________ Amen Ramy - I was sympathetic to the rationalizing by those who didn't fly with PowerFlarm or Transponders - until I got both. Both arguments are exactly the same - just focused on different traffic types. That argument is: "big sky, little glider, I don't need it". You correctly point out the big cultural difference between the two - a transponder protect you and airline passengers, PowerFlarm protects you and your soaring buddies. I care that you don't run into an airliner, but it's an intellectual exercise. I care that you don't run into me because it's personal. Lacking a PowerFlarm is becoming the path to being a pariah at contests. I see it being taken up at commercial operations too and I suspect the more active clubs are adopting. We'll see how long the diehard opponents last. 9B |
Ramy, send me one and I'll install it. I won't, however, bend to peer
pressure and you can call me a bozo if you want. We have big skies around Moriarty and, outside of contests, there are few gliders. I want protection from transponder equipped aircraft. "Ramy" wrote in message ... On Monday, June 10, 2013 10:06:24 AM UTC-7, Mike the Strike wrote: On Monday, June 10, 2013 9:39:26 AM UTC-7, jfitch wrote: On Monday, June 10, 2013 8:53:21 AM UTC-7, Dan Marotta wrote: Neither Flarm nor transponder will protect against VFR aircraft not in contact with ATC. PCAS might work for that, however. I was under the impression that PowerFlarm (not Flarm) did that since it receives Mode C replies. Is that not the case? Yes, but I was replying to Dan who doesn't want a Flarm. We have lots of aviation traffic going to small airfields that are not in contact with ATC. Single-engine stuff is usually low down, but twins are often coming in from a destination further away and descend through airspace near the gliderport. They never seem to be looking out of their windows and won't be aware of me unless they too have a PCAS. Mike Every now and then the argument of flarm vs transponder will come up. This is like comparing apples to oranges. These are not alternative solutions. Each has different purpose and each solution is highly desirable depend on where you fly. Dan flies out of Moriarty so obviously both are desired. Sooner or later those who insist on never installing a flarm will find themselves less popular among their flying buddies who went through the trouble of installing. You may hear on the radio "watch out for a bozo flying around without flarm". My message to those who can afford a powerflarm but don't think they need it: Install one anyway and turn the display off if you want. At least we will be able to see and avoid you. You may never know that it saved your butt. Ramy |
Dan,
It is not bending to peer pressure it is waking up to a important safety tool. On a good weekend and some weekdays we have upwards of 20 gliders flying in the Moriarty airspace. Many are flying in the same areas as they are running shear lines and cloud streets for OLC points. We do have a big sky but often well populated routes. On Monday, June 10, 2013 10:24:43 PM UTC-6, Dan Marotta wrote: Ramy, send me one and I'll install it. I won't, however, bend to peer pressure and you can call me a bozo if you want. We have big skies around Moriarty and, outside of contests, there are few gliders. I want protection from transponder equipped aircraft. |
My first near mid-air with a glider some years ago involved a run down a cloud street - I was returning and a colleague was outbound. We were in radio contact and knew of the potential conflict. When we met, I saw a brief flash of wing and as I started climbing and turning, he passed 20 feet under my wing without ever seeing me. Replaying our igc files showed that we were both cruising around 85 to 90 knots IAS and had a closing speed of close to 250mph. I saw him at a distance of a mile, or about 12 seconds before we passed. Flarm would have helped.
I was one of the PowerFlarm skeptics, but have now seen the benefits. Gliders not so equipped are likely to become pariahs, firstly being excluded from competition and later from clubs or FBOs. I would not be surprised if insurance companies also weighed in by offering discounts to Flarm-equipped gliders. I would lump pilots who moan about mandated safety devices with motorcyclists who like the freedom to ride without a helmet, except the pilot may kill one of his buddies too. Mike |
On Tuesday, June 11, 2013 12:00:13 AM UTC-5, Mike the Strike wrote:
My first near mid-air with a glider some years ago involved a run down a cloud street - I was returning and a colleague was outbound. We were in radio contact and knew of the potential conflict. When we met, I saw a brief flash of wing and as I started climbing and turning, he passed 20 feet under my wing without ever seeing me. Replaying our igc files showed that we were both cruising around 85 to 90 knots IAS and had a closing speed of close to 250mph. I saw him at a distance of a mile, or about 12 seconds before we passed. Flarm would have helped. I was one of the PowerFlarm skeptics, but have now seen the benefits. Gliders not so equipped are likely to become pariahs, firstly being excluded from competition and later from clubs or FBOs. I would not be surprised if insurance companies also weighed in by offering discounts to Flarm-equipped gliders. I would lump pilots who moan about mandated safety devices with motorcyclists who like the freedom to ride without a helmet, except the pilot may kill one of his buddies too. Mike I will not install a power flarm or transponder in my KA6CR. too expensive. Dale |
There is still a great deal of work to do on Flarm before it is a
truely trustworthy piece of equipment. Ramy ... name calling is just what we don't want on these discussions. Your Power Flarms should be able to detect and display a transponder that is actively being interrogated by ATC radar. The last four times I have flown in airspace with PowerFlarm equiped gliders and have been close enough to the Flarm plane to be able to read the model name on the side of the cockpit, the PowerFlarm pilot did not see me on their display. I talked with each of those pilots on the radio. My transponder is blinking like a WalMart christmas tree and they don't see me. They don't see me with their eyes either !!!!!!! My transponder has passed all the tests and the antenna radiates with no detectable blind spots. There are still some significant problems with antenna placement with Flarm, especially in aircraft that have carbon fuselages. Then there is the wildcard of how pilots set the parameters on their Flarms...or don't. Guy Acheson "DDS" |
Dan Marotta wrote, On 6/10/2013 9:24 PM:
I want protection from transponder equipped aircraft. Maybe you meant TCAS equipped aircraft? At least get an MRX, if you don't want a PowerFlarm. The MRX will warn you of transponder equipped aircraft, most of which do not have TCAS. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl |
Thanks for understanding my position, Guy.
Robert and Mike, it's not about resistance to anything. As the Moriarty folks know, I ride a motorcycle AND I wear a helmet though it's not required in New Mexico. I make my decisions on my perceived need, not on the latest promise of "safety". Sure I've seen claims of saves with Flarm, but I've also seen a lot of complaints of it not living up to its promise. I can appreciate its value in a crowded thermal; no argument other than the sometimes missed alerts. I only flew one day during the contest. On release, I found a really good thermal and other gliders, seeing me going up so fast, came and joined. There were 4 or 5 as I recall. I left the thermal and headed off in a non-task dirction. I didn't see another glider all day. I generally fly alone or with one other glider and then we're in constant communication. If we lose sight, we leave the thermal. Look back at my OLC traces and you'll see that I don't follow the shear lines all day to maximize speed and distance points. I fly for fun and I enjoy exploring those places where the really fast guys don't go that often because it slows them down. And, no, I'm not talking about TCAS equipped aircraft. I mean ABQ Approach sees me and vectors departing and arriving aircraft around me. I have talked with them and done transponder checks to be sure they can see me - they can! I also dragged my glider down to ABQ to the avionics shop to have my installation checked. It works! I know of at least one pilot at Moriarty who has a Flarm but refuses to install a transponder. So he's protected from other Flarm or transponder equipped gliders, but he's also invisible to ATC and TCAS. How smart is that? "Eric Greenwell" wrote in message ... Dan Marotta wrote, On 6/10/2013 9:24 PM: I want protection from transponder equipped aircraft. Maybe you meant TCAS equipped aircraft? At least get an MRX, if you don't want a PowerFlarm. The MRX will warn you of transponder equipped aircraft, most of which do not have TCAS. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl |
Contest Number on PowerFlarm (US)?? | [email protected] | Soaring | 14 | August 29th 12 07:24 PM |
Region 3 contestants Welcome-Region Six North Contest Ionia | November Bravo | Soaring | 0 | August 13th 09 12:53 PM |
Region 8 Contest | Wayne Paul | Soaring | 4 | July 5th 07 07:48 PM |
Region 3 Contest | James Hamilton | Soaring | 2 | January 3rd 06 09:19 PM |
Region 10 Contest | WDM | Soaring | 0 | April 23rd 05 01:10 AM |
