SUN GLASSES
Old June 14th 13, 01:11 AM posted to rec.aviation.soaring
Ramy
Default SUN GLASSES
On Thursday, June 13, 2013 3:12:14 PM UTC-7, noel.wade wrote:
P7 has the best answer...
But Let's step back to facts, shall we?
Polarized lenses literally block light, unless the light-waves are
oriented at a specific angle to the lens.
Almost all LCDs (including PDAs, cell-phones, iPads, and even simple
displays like Cambridge *-NAV devices or digial variometers) have 1 or
2 polarized screens, as part of how they work. See he
http://en.wikipedia.org/wiki/Liquid-crystal_display
Stacking multiple polarizing filters in the proper orientation lets
light pass through. But stacking them in the wrong orientation causes
the light passing through the first filter to be BLOCKED by the
second.
Your polarized sunglasses _are_ a "second filter", sitting between
your eyeballs and the LCD screens in your cockpit. Ergo, if the
orientation of your sunglasses' polarized surface is not near the same
angle of your electronic displays, the visibility of your instruments
will be negatively impacted. Here are two video demonstrations of
this:
http://www.youtube.com/watch?v=GkLBMAY406Q
http://www.youtube.com/watch?v=HcQWAqL2JUw
Polarized sunglasses are not all manufactured the same; and even
different batches of the same sunglasses may not always have the
orientation to the polarized lenses - don't assume that because your
glasses work for you, that you can recommend them to others or that
you can simply buy another pair of the same, and have them work
identically. Additionally, just because you find glasses that may work
with _your_ cockpit instruments and canopy, do _not_ assume that it
will work with _all_ instruments or canopies. Finally, don't assume
that all of your instrument displays have the same polarization on
their screens. I have polarized lenses that work fine when viewing
some of my instruments, but not with others (unless you rotate the
glasses 90-degrees). Also, these polarized sunglasses worked fine
with my DG-300 canopy, but created horrible moire & checkerboard
patterns on a couple of Diamond DA-20 rental aircraft canopies.
If you're going to fly with a lot of cockpit electronics, I strongly
recommend against polarized lenses because you don't want to be
distracted or fumbling with your instruments because of this effect.
There are plenty of effective non-polarized sunglasses out there that
give you good visibility and protection.
Lastly, if you're going to be flying in a club or rental environment,
where you switch ships with any regularity, do NOT assume that
polarized sunglasses which work in one cockpit will work in another.
--Noel
Good points.
I guess it all boils down to "it depends". Polarized glasses always worked for me in the gliders I flew, but I agree this is not always going to be the case.
So the solution is to have a spare non polarized glasses with you in case there is an issue.
Ramy
Old June 14th 13, 02:02 AM posted to rec.aviation.soaring
Jeremy Keeling
Default SUN GLASSES
At 22:20 12 June 2013, wrote:
I'm getting new sun glasses, should I get Polarized or not, what works
best
for flying gliders???
The ones I'm looking at are also anti-glare lenses.
Thanks
Glen
When I was in to gliding I always flew on a sunny day with Oakley wiretap
fire iridium polarized sunglassed, to be specific.
http://www.oakley.com/products/1252/2794).
No colour loss, no glare and on a blue day you can see 'haze caps' of
thermals which would otherwise be invisible - I would recommend them.
Old June 14th 13, 03:08 PM posted to rec.aviation.soaring
John Galloway[_1_]
Default SUN GLASSES
are
even simple
lets
orientation causes
second.
between
the same
instruments
demonstrations of
this:
and even
have the
because your
others or that
them work
may work
assume that it
assume
polarization on
viewing
rotate the
worked fine
checkerboard
canopies.
strongly
want to be
effect.
there that
environment,
that
another.
--Noel
Good points.
always worked
to be
the case.
you in case
there is an issue.
Ramy
Polarised sunglasses should genarally be expected to have
vertical polarization because the whole point about reducing
glare from water surfaces etc is that the light reflected of the
surface to the eye tends to be polarised horizontally.
On another topic - genuine question - do polarised lenses made
without a UV absorbing tint, and without a UV absorbing lens
material such as polycarbonate, reduce UV transmission more
than in proportion to the reduction in general light
transmission?
John Galloway
Old June 14th 13, 08:36 PM posted to rec.aviation.soaring
Jeremy Keeling
Default SUN GLASSES
are
even simple
lets
orientation causes
second.
between
the same
instruments
demonstrations of
this:
and even
have the
because your
others or that
them work
may work
assume that it
assume
polarization on
viewing
rotate the
worked fine
checkerboard
canopies.
strongly
want to be
effect.
there that
environment,
that
another.
--Noel
Good points.
always worked
to be
the case.
you in case
there is an issue.
Ramy
transmission?
John Galloway
re uv absorption by sunglasses with no uv absorbing lens. I have no idea,
but according to the page about my oakleys "...combines patented optics and
PLUTONITEĀ® lens material that provides 100% UV filtering and unsurpassed
impact protection...".
Which is probably of no use to you whatsoever.
All the best.
Old June 16th 13, 06:25 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default SUN GLASSES
John Galloway wrote, On 6/14/2013 7:08 AM:
transmission?
Your canopy filters out most of the UVB, as will almost every pair of
sunglasses, regardless of their tint or polarization. Plastic or glass
that passes significant amounts of UVB is "special" stuff that costs
more. UVA transmission is more variable, as it takes some effort to
filter it out, so if you want to block it, look for a pair that
specifically claims to do so.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old June 16th 13, 05:42 PM posted to rec.aviation.soaring
Dan Marotta
Default SUN GLASSES
After trying a friend's Eagle Eyes (As seen on TV!!!), I found them to
improve detailed vision, especially spotting very thin dust devils. So I
bought a pair with built in readers.
They're great! I used them to take my wife for a ride in a friend's
DG-500m-22 and they were flawless. Yesterday, when I pulled down the canopy
of my LAK-17a, I found the screen of my CAI-302 to be totally black. At
first I thought it was due to the heat but, raising the glasses, I saw the
problem was with the misaligned polarization of the 302 screen with the
glasses.
I wonder if the glass in the 302 can be rotated 40-90 degrees...
transmission?
that passes significant amounts of UVB is "special" stuff that costs more.
UVA transmission is more variable, as it takes some effort to filter it
out, so if you want to block it, look for a pair that specifically claims
to do so.
Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email
me)
Old June 17th 13, 09:51 PM posted to rec.aviation.soaring
Ramy
Default SUN GLASSES
glasses.
transmission?
to do so.
me)
No problem with my 302 with all polarized glasses I used. Either your glasses or your 302 polarized wrong.
Ramy
  #28
Old June 18th 13, 03:36 PM posted to rec.aviation.soaring
bumper[_4_]
Default SUN GLASSES
I always fly with my "Zoomies" binocular glasses (as seen on TV) https://www.buyzoomies.com/
Other gliders look 300% closer, so does the ground . . . it's a truly terrifying experience. I have no idea why a wear them but everyone else should as well.
bumper
  #29
Old June 18th 13, 03:44 PM posted to rec.aviation.soaring
bumper[_4_]
Default SUN GLASSES
Ramy
Some 302's had their polarization off by 90 degrees (I think they got a bad batch IIRC). When I bought my 302 in '03 screen blacked out with polarized glasses. Sent it in and they replaced the glass to fix this at no charge.
bumper
  #30
Old June 19th 13, 01:37 AM posted to rec.aviation.soaring
Dan Marotta
Default SUN GLASSES
I don't know of any where to send mine now... I'll just use my older
non-polarized glasses and swap the Eagle Eyes to my car, hiking, and
kayaking.
"bumper" wrote in message
Ramy
no charge.
bumper
Polarized Sun Glasses Richard[_9_] Soaring 13 May 29th 12 05:38 PM
Polarized Sun Glasses and PDAs Michael Reid Soaring 12 April 11th 10 02:36 PM
Carrying glasses? Emily Piloting 58 September 13th 06 12:27 AM
INFLIGHT IFR Training glasses,,,, anyone try them before Cecil E. Chapman Instrument Flight Rules 0 October 18th 03 12:24 AM
More on Sunreader glasses Eric Greenwell Soaring 0 September 22nd 03 11:38 PM
