Help: Cirrus 75 Landing Gear Parts
Old June 17th 13, 09:43 PM posted to rec.aviation.soaring
Sarah Arnold
Default Help: Cirrus 75 Landing Gear Parts
Hello Everybody,
I received the following email from a friend of mine who lives in Argentina and would like to help, but I don't know how to find these parts.
"I´m writing you because I need some help in finding some spare part for a Cirrus 75 that belongs to my gliding Club in Argentina. Last Saturday I had a bad landing and I need to replace, as soon as possible, the wheel mass, the wheel chamber and wheel cover. Unfortunately any of this is available in Argentina. I wonder if you can help me in finding one. A friend is coming from the States to Argentina in a month time and he could bring everything I can find from there."
I've emailed Heinz M & H Soaring as well. Are there any Rec Readers out there who could help point me in the right direction please? Thanks in advance..
Sarah Arnold
Old June 18th 13, 12:22 PM posted to rec.aviation.soaring
On Monday, June 17, 2013 4:43:07 PM UTC-4, Sarah Arnold wrote:
Hello Everybody,
Sarah Arnold
http://www.sky-craft.co.uk/acatalog/...ailplanes.html
Not sure if this helps, doesn't say what cirrus it's for (standard, open class?). Scroll down a bit, there's a Cirrus landing gear assembly unit.
Old June 18th 13, 01:06 PM posted to rec.aviation.soaring
GM
On Monday, June 17, 2013 2:43:07 PM UTC-6, Sarah Arnold wrote:
Hello Everybody,
Sarah Arnold
Hi Sarah,
looks like your friend is looking for the complete wheel assembly - hub, inner tube and tire. A Cirrus 75 was one of the last Cirrus' series built and the wheel was most likely made by TOST. I would recommend your friend contacts them (www.tost.de then go to 'English') with some dimensions and I am sure he will be able to get all the correct replacement parts.
Uli
'GM'
Old June 18th 13, 02:03 PM posted to rec.aviation.soaring
BruceGreeff
Hello Sarah
The wheel is a 4" Tost Lilliput rim with a 4.00x4 tyre and tube, can
also use the Kobold wheel as fitted to the early Ventus.
I had a spare - but sold it with my Cirrus...
Bruce
Hello Everybody,
Sarah Arnold
Hi Sarah,
Uli
'GM'
Bruce Greeff
T59D #1771
Old June 18th 13, 02:07 PM posted to rec.aviation.soaring
BruceGreeff
This sounds like a known weakness on the Lilliput wheel where the
aluminium hub develops fatigue cracks and separates at the steel liner.
If this happens as it generally does with the landing shock - you can
expect a very sudden stop as the wheel locks.
The white stripe is expensive. ;-)
I got mine welded up - and kept it as a backup.
Bruce
Hello Everybody,
Sarah Arnold
Hi Sarah,
Uli
'GM'
Bruce Greeff
T59D #1771
A Jet Blue Aircraft Landing with Sideway Landing-Gear Hansi Instrument Flight Rules 1 July 17th 06 04:01 AM
Landing Gear Parts, Antique Part, EXP Airplane Auction Bill Berle Home Built 0 November 24th 04 05:11 PM
Landing Gear Parts, Antique Part, EXP Airplane Auction Bill Berle Aviation Marketplace 0 November 24th 04 05:11 PM
Landing Gear Parts, Antique Part, EXP Airplane Auction Bill Berle Owning 0 November 24th 04 05:11 PM
Wanted: L-13 landing gear parts Brian Doyle Soaring 0 September 14th 04 03:16 PM
