On Tuesday, June 18, 2013 7:49:16 AM UTC-7, StaPo wrote:
You can adapt 8mm multiple type probe installation to single 8mm TE probe via joining existing 2-3 hoses outputs together via T-piece(s). But do simple leak test on the ground before flight testing to avoid "interesting" instrument readings... But you will have only a single probe system then (probably suction) and he is starting with a double probe...fine if nothing is connected to static or pitot. |
CHT probes | flybynightkarmarepair | Home Built | 4 | May 14th 07 06:07 AM |
New TE Probes | Paul Buchanan | Soaring | 0 | August 21st 06 08:53 PM |
WTB CHT probes | [email protected] | Home Built | 6 | August 11th 04 06:46 PM |
WTB CHT probes | [email protected] | Aviation Marketplace | 6 | August 11th 04 06:46 PM |
WTB CHT probes | [email protected] | Owning | 6 | August 11th 04 06:46 PM |
