Ventus 2c vs. 2cx
Old June 20th 13, 10:16 AM posted to rec.aviation.soaring
Muttley
Default Ventus 2c vs. 2cx
On Thursday, June 20, 2013 2:39:34 AM UTC+2, noel.wade wrote:
All -
I've spent a long time studying Schleicher aircraft; not as much
looking at S-H ships. Can anyone explain how much of a performance
difference there is between a V2c and a V2cx? I understand the
fuselage changed between the two; any major improvements or
innovations, or was the D2 fuselage just slightly better and easier to
manufacture? Any aerodynamic differences (other than the fuse) between
the 2c and the 2cx? Any comments on whether an "older" 2c is
competitive with an ASW-27 or other current 15m ships?
Thanks a bunch,
--Noel
Noel
the Ventus 2 was conceived as an 18metre ship and I think it was not comparable in performance to an ASW 27 in 15metre
However if you are looking just for a ship for pleasure flying the Ventus 2C in 18metre is quite nice as the wings are not as stiff as the Ventus 2cx and also the change to the wings and elevator as mentioned before makes the Ventus 2cx more competitive in 15 and 18 metre and also a bit sharper in handling.
Mottley
Old June 20th 13, 12:48 PM posted to rec.aviation.soaring
Peter F[_2_]
The results at World Championships level don't suggest that the V2 lacks
performance.
The actual difference between any of the top performing gliders in a given
comp class...
Std (D2/LS8),
15M (ASW27/ ASW29 / V2a / V2ax),
18m (V2c / V2cx / ASW29 / JS1)
...is tiny.
More than made up for by decisions made by the pilot.
(Apologies to owners of ships from other manufacturers!)
Open class may be a different matter, too many new designs to provide any
history of results.
PF
At 09:16 20 June 2013, Muttley wrote:
Noel
compar=
FS: Ventus 2AX John C Soaring 0 September 8th 12 01:29 PM
Ventus 2C W&B - 15M vs 18M [email protected] Soaring 0 March 29th 06 10:20 PM
Ventus C 17.6 John Shelton Soaring 0 January 17th 05 05:48 PM
Ventus C 17.6 John Shelton Soaring 0 November 18th 04 08:39 PM
FS Ventus C 17.6 John Shelton Soaring 0 November 15th 04 09:10 PM
