The near mid-air at the Region 9 contest
Old June 21st 13, 01:36 AM posted to rec.aviation.soaring
waremark
Default The near mid-air at the Region 9 contest
About 10 years ago I had s mid-air collision on thermal entry. Happily, neither of us was hurt; we both came down safely on parachutes. If we had both had working Flarms (not available back then) the collision would not have occurred. So I think Flarm/Powerflarm is A GOOD THING.
I have slight reservations about this idea of using rental units at comps. I think you get used to using Flarm over time - the first time I experienced a Flarm warning I jumped out of my skin. And you get used to using it as an aid to scan rather than a distraction from it. Really, it would be better to do that not in a comp environment. And you have to work out how to fix and power the unit safely in your plane.
Mark Burton
London Gliding Club, Dunstable, UK (where Flarm is being adopted quite rapidly by the cross-country community, but it is not compulsory for any type of flying - and Powerflarm and transponders are both very uncommon)
On Thursday, 20 June 2013 19:41:55 UTC+1, WB wrote:
Brad wrote:
We're the pilots talking to each other on the radio?
I've only flown in 1 contest, but if I recall radio "chatter" was frowned
upon.
thanks,
Brad
(who has PowerFlarm and loves it)
"Barking dogs" as Spratt called them, are definitely frowned upon.
However, radio calls in the service of safety are definitely encouraged
by the rules as well as popular opinion. "WB, I'm at your 7 o'clock and
turning inside..." type calls are more than welcome.
Old June 21st 13, 01:42 AM posted to rec.aviation.soaring
Ramy
I have slight reservations about this idea of using rental units at comps.. I think you get used to using Flarm over time - the first time I experienced a Flarm warning I jumped out of my skin. And you get used to using it as an aid to scan rather than a distraction from it. Really, it would be better to do that not in a comp environment. And you have to work out how to fix and power the unit safely in your plane.
Mark Burton
upon.
thanks,
Brad
One thing worth pointing, that even if someone is totally unfamiliar with how to use the unit, just turning it on and ignoring it or even turning down the volume, may be sufficient since it will still warn others.
Ramy
Old June 21st 13, 07:09 AM posted to rec.aviation.soaring
I got accommodated to Flarm on the first flight. I think the benefits so far exceed any learning curve concerns that I strongly favor a rental program.. Ramy makes a great point for those with a shallow learning curve. There is definitely momentum towards 100% compliance at contests in the US right now.
9B
Old June 21st 13, 08:11 PM posted to rec.aviation.soaring
mike
Mark Burton
upon.
thanks,
Brad
Ramy
Doesn't having a transponder also alert the Flarm unit/user?
Mike
Old June 21st 13, 08:31 PM posted to rec.aviation.soaring
Mike
Mode S will tell every flarm in miles where you are. Mode C is next to useless for flarm, and many flarm people will have turned mode c warnings down/off.
John Cochrane
Old June 21st 13, 09:39 PM posted to rec.aviation.soaring
mike
Mike
John Cochrane
I remain in stealth mode...with mode c. ;^)
Old June 22nd 13, 03:37 AM posted to rec.aviation.soaring
bumper[_4_]
Mike
John Cochrane
That is true IF the Mode S or C is operating in an ATC radar environment, or if it is being actively interrogated by a TCAS equipped aircraft. Otherwise, the flarm or PCAS will never know you're there.
That's part of the beauty of PowerFlarm, unlike a transponder, PF is an active system transmitting your position for other PF users to see.
Both PF and a transponder are important if you fly near gliders or powered aircraft . . . it's not a one or the other deal, though depending on where you fly, one might be more advantageous to have than the other, though both is best.
bumper
Old June 22nd 13, 09:39 AM posted to rec.aviation.soaring
Ramy
John can you elaborate? That's the first time I hear that there is a difference between mode C and mode S as for PCAS alert? AFAIK both will provide approximate distance, altitude difference and no direction.
Ramy
Old June 22nd 13, 05:10 PM posted to rec.aviation.soaring
Dan Marotta
To be accurate, it's Mode A (reply code) you're talking about, not Mode C
(pressure altitude). And why would Flarm users filter out signals from
possible threat aircraft? Or did I misunderstand the statement about
turning warnings down/off?
Most of the US air space is covered by ATC radar and so my transponder is
pinging away in reply so I expect Flarm equipped aircraft would see me if
they came into my area. Flying out of Moriarty yesterday, I was one of only
two gliders to stay up and, in 2.1 hours did not get a single blip on my
PCAS. I verified that it was reading my transponder replies by changing my
code and testgin again. I don't think Flarm could have improved my
situation any.
I know I should have simply stayed out of this but... Fire away.
Mike
down/off.
John Cochrane
Old June 22nd 13, 07:29 PM posted to rec.aviation.soaring
Darryl Ramm
situation any.
There seems to be some confusion here.
To be accurate and correct :-O ...
PCAS typically has *nothing* to do with Mode A replies and is all about Mode C replies. Mode A encodes the squawk code and Mode C encodes the altitude.. A traditional Mode A/C transponder when being interrogated by an SSR system responds to interleaved Mode A and Mode C interrogation pulses (the targets are interrogated multiple times in both Mode A and C each rotation as the SSR interrogator beam sweeps past the aircraft) and responds with whatever its being asked for. PCAS systems, including in the PowerFLARM just listen to those replies and try to guess which ones are mode A or Mode C (the replies don't explicitly say what type they are, traditionally the interrogating SSR knows what it asked for). The PCAS first job is to typically discard any replies it things are mode A and then only using the Mode C replies, work out the altitude of the threat and whether it should display that/issue an alert etc. How well PCAS systems work given they are effectively blind and are have very little data, have to make guesses about Mode C replies and have to infer range from the RF power etc. With Mode S threats PCAS systems can be smarter, e.g. they can absolutely know that a squawk code and altitude transmission comes from the same aircraft etc. There was one older PCAS system that did display threat aircraft squawk codes (e.g. it decoded both Mode A and C) with the claim that its nice to know if a threat is VFR or under ATC control etc. But to me that is all just more info you have to display/let users understand etc. and likely not worth it.
One of the benefits of lots of the special Mode A codes like 1200, 1202, 7700, 7600 is that they do not encode as valid Mode C altitudes but lots of other altitude and squawk codes can alias with each other. This is not an issue when dealing with Mode S transponders being interrogated by a Mode S interrogator.
PCAS clearly cares about Mode C replies because it wants to know the altitude of any threat so it can work out what to do with it, including just ignore it. Mode A does not help much, and with pure Mode A and C transmission in dense traffic environments the PCAS cannot ever tell how to match up Mode C and A replies from the same threat aircraft.
And to complicate things further TCAS and TCAD systems never issue a Mode A interrogation, another reason PCAS never want to rely on anything Mode A, if they just listen to mode A and you were in a TCAS interrogator only environment you would just never ever see the threat. There are some complex second order things that PCAS systems could try to do with Mode A transmissions, but I suspect none of them do.
And to be clear on products here... Flarm equipped aircraft never see any PCAS threats. *PowerFLARM* does see Flarm and PCAS, at least in the USA where all PowerFLARM come with this capability, in other geographies things may be different, for example in Europe "PowerFLARM Pure" does not include PCAS reception capability.
Lots of USA airspace where gliders fly, especially close to terrain/mountains etc. is not covered by SSR and so transponders will not be interrogated by SSR. the obvious pointer here is that controlled airspace has SSR ground interrogator coverage and uncontrolled airspace may not. That will change to some extent as ADS-B rolls out, but hats a who other hairy topic. The savior there frequently is airborne TCAS interrogators, there are lots of airline, private jet and military aircraft flying around issuing mode C (and Mode S, but not Mode A) interrogations and that can be an important factor here to make out PCAS systems work.
Especially in mountainous regions you have to be cautious about PCAS, it might appear to work fine and then suddenly not work as you fly behind an obstruction that shields an SSR ground interrogator or as the overhead TCAS interrogator flies away. Or it might appear to work fine and then as you descent down to pattern altitude you can lose the interrogator yet be exposed to the more dangerous traffic density around an airport.
I'm not sure exactly what point you are making on you PCAS observation out of Moriarty. Assumption about whether you would see other gliders depends firstly on if those other gliders are Mode C or Mode S transponder equipped. And what the local interrogator coverage is, at Moriarty especially when low near the airport, which I assume does rely on TCAS interrogators. Or if you wanted to compare seeing them with PowerFLARM then you need to know if they are PowerFLARM equipped. What exactly was your point here and what are all the other gliders in the area equipped with?
PowerFLARM is clearly superior to PCAS in high-density glider on glider scenarios like contests because of the much more accurate threat information, because more gliders in the fleet are likely to be PowerFLARM equipped than transponder equipped and because there is no issues with needing the Flarm system to be interrogated. Transponders and PCAS have huge benefit when mixing with other traffic (especially gliders carrying transponders where there are high density TCAS equipped fast/commercial jet traffic) and working with ATC etc. Its simply a false paradox to make forced comparisons between transponders vs. PowerFLARM. Owners/pilots should be evaluating what is best for their needs, and that may be to get both.
Region V So Contest, USA Hartley Falbaum[_2_] Soaring 0 April 16th 12 02:12 AM
NEW REGION 2 CONTEST J9 Soaring 0 May 15th 11 02:35 PM
Region 3 contestants Welcome-Region Six North Contest Ionia November Bravo Soaring 0 August 13th 09 12:53 PM
Region 12 contest g l i d e r s t u d Soaring 0 December 17th 07 06:35 PM
(US) Region 11 Contest Pat Russell Soaring 2 July 13th 06 09:29 PM
