Glider accident while filming commercial in 2011. NTSB Report updated
Old June 27th 13, 03:06 PM posted to rec.aviation.soaring
Dan Marotta
Default Glider accident while filming commercial in 2011. NTSB Report updated
The following short clip is taken from a video made for ESPN back in the 90s
some time. This is how it should have looked:
http://www.youtube.com/watch?v=DHa-t...ature=youtu.be
"Bill D" wrote in message
On Wednesday, June 26, 2013 3:38:21 PM UTC-6, Paul Ruskin wrote:
Hi Bill
So, Andreas verifies the 5 accidents the BFU lists for 2011 was all
there was in 900,000 winch launches.
http://rdd.me/dstznowe says the UK suffered 12 for 180,000 launches.
How does that stack up?
UK: 1:15,000
Germany 1:180,000
Seems like Germany has a 12:1 lower accident rate.
Actually, the reference you quote above says that in 2011 there were 12
accidents plus incidents. Not the same as accidents. It's not really
credible that the accident rate is 12:1 but the fatality / serious rate
roughly the same, as calculated earlier. I think we're going to need to
agree to differ on this one though.
It's great that the safer winch launching initiative in the UK has
improved things but I think you need to find out what the Germans are
doing right. I'd start by watching every "windenstart" video on YouTube.
Hint: Time the takeoff rolls
OK - good thought. So I did. First five UK launches 5,2,2,4,2 seconds
(roughly). First five German ones 5,4,3,3,2. Again roughly. Not a lot
of difference (caveat - not a large sample and dependent on lots of other
things). What was interesting was that the first two UK ones were from
the same club, and used their old and new winch respectively. I think
this time is largely equipment driven - could be that newer winches tend
to be higher power. Don't disagree in principle though - and as I
mentioned earlier, avoiding wing drop is a current focus at the moment in
the UK.
On your point about minimum winch airspeed, I agree totally. It's
standard teaching: (BGA Instructors' manual edition 3 page 16-1). I find
it strange that gliders are placarded with maximum airspeed but not
minimum.
Paul
When timing takeoff rolls, you need to find a way to consistently pick a
moment when the acceleration begins. Many of the launches roll for several
meters before the winch driver really hits the throttle. I choose the
moment a nose wheel/skid glider's tail goes down and for tail wheel gliders
when the wing runner lets go to start the clock.
To compensate a bit for this late clock start, I stop the clock when the
glider's wheel is .5 - 1m above the ground. It's not perfect but then it's
YouTube.
It's also necessary to estimate the wind. If there's a lot of wind noise on
the sound track or the trees are obviously bending, I disregard that video.
If I can see a wind sock in the background, I can estimate the wind. If
there's a good sound track without wind noise, there's probably little wind.
Try that and see if your numbers change.
NTSB crash report, autopsy report- Stevie Ray Vaughan Mark. Piloting 5 March 22nd 20 10:17 PM
NTSB Report on Bill Phillips' Accident Ron Wanttaja[_2_] Home Built 63 September 29th 09 12:02 PM
Preliminary NTSB report on Walton accident ChuckSlusarczyk Home Built 11 July 12th 05 04:23 PM
Prelim NTSB report, Pilatus accident in PA vincent p. norris Piloting 15 April 11th 05 02:52 PM
NTSB Aircraft Accident Reports Updated Daily? [email protected] Owning 2 March 4th 05 01:25 PM
