Glider accident while filming commercial in 2011. NTSB Report updated
Old June 29th 13, 07:32 PM posted to rec.aviation.soaring
Bill D
Default Glider accident while filming commercial in 2011. NTSB Report updated
On Saturday, June 29, 2013 8:22:46 AM UTC-6, Nigel Pocock wrote:
Excessive initial ecceleration can cause problems with certain types. I
have experienced it with 2 types.
PW5 with stick fully forward at the start of the launch. Hard acceleration
caused the glider to rotate from the nose wheel to the tail wheel and
rocket into the air. I only managed to regain control at about 50ft.
The other one is the K8. Light glider, high wing. Similar problem.
If slow acceleration is a safety problem what about the ground run and take
off with aerotow using belly hooks, and autotows?
Here's a PW-5 winch launch done right. Note the 1 second ground roll.
http://www.youtube.com/watch?v=IseFvZXK7Dw
Here's a K8 also with a one second ground roll.
http://www.youtube.com/watch?v=ict8W0Q5ZpA
Both of these launches were at accelerations greater than 1G. Neither showed an "uncommanded" pitch up. So, neither the gliders nor the acceleration are a problem.
NTSB crash report, autopsy report- Stevie Ray Vaughan Mark. Piloting 5 March 22nd 20 10:17 PM
NTSB Report on Bill Phillips' Accident Ron Wanttaja[_2_] Home Built 63 September 29th 09 12:02 PM
Preliminary NTSB report on Walton accident ChuckSlusarczyk Home Built 11 July 12th 05 04:23 PM
Prelim NTSB report, Pilatus accident in PA vincent p. norris Piloting 15 April 11th 05 02:52 PM
NTSB Aircraft Accident Reports Updated Daily? [email protected] Owning 2 March 4th 05 01:25 PM
