Is airspeed control in B777 fundamentally different than in a glider?
Old July 10th 13, 03:13 PM posted to rec.aviation.soaring
Default Is airspeed control in B777 fundamentally different than in a glider?
The news about the B777 accident at SFO is getting me confused. The news stories are constantly pointing to the Autothrottle not maintaining airspeed (and question if the 3 pilots in the cockpit were monitoring airspeed)but in all the aircraft I have flown airspeed is controlled primarily with pitch. Is there something fundamentally different about airspeed control in large jet aircraft? My experience is that pitch controls airspeed and power controls climb/descent, especially in the approach to landing situation.
Guy Acheson "DDS"
Old July 10th 13, 03:28 PM posted to rec.aviation.soaring
Karl Kunz[_2_]
Guy Acheson "DDS"
If you don't care how fast you are coming down yes you can control the airspeed with pitch. If you are trying to maintain a fixed glide angle (3 degrees for most airliner approaches) you will have to add power. IF the were maintaining the glide path with insufficient power there airspeed would have continued to decay all the way down final approach.
Old July 10th 13, 04:12 PM posted to rec.aviation.soaring
kirk.stant
Huh? AOA controls airspeed, even in airliners - you fly a constant AOA for the desired approach speed, with power varying to maintain glidepath: going low, you add power; high, you pull off a bit.
And sure, you can gain or lose a few feet by pushing or pulling, but soon you will have to add or remove power to compensate for the change in airspeed, and now you are destabilized.
Kirk
66
Old July 10th 13, 04:29 PM posted to rec.aviation.soaring
Guy Acheson "DDS"
Portions of the pilots interview were posted and the right seat pilot said he assumed the auto throttles were on but they were not. He says he told the left seat low time pilot to increase speed and pitch but it was too late.
Old July 10th 13, 05:27 PM posted to rec.aviation.soaring
Karl Kunz[_2_]
You are correct. It was what I was trying to explain - poorly. Pitch + Power = Performance.
Kirk
66
Old July 10th 13, 08:51 PM posted to rec.aviation.soaring
Craig Funston[_2_]
On Wednesday, July 10, 2013 10:48:21 AM UTC-7, Vaughn wrote:
Auto throttle or not, ILS or not, I think it's safe to assume that there
is nothing so fundamentally different about the B777 as to relieve the
pilots from their duty to be aware of their airspeed at all times,
especially while on final approach.
This is a great video on automation dependency and cockpit workload.
http://www.youtube.com/watch?v=h3kRE...e_gdata_player
I also suspect having 4 pilots involved ended up being less safe than just two.
Craig
Old July 10th 13, 11:30 PM posted to rec.aviation.soaring
kirk.stant
Yeah, I figured it got garbled in transmission! ;^)
Cheers,
Kirk
66
Old July 11th 13, 01:23 PM
Squeaky Squeaky is offline
Member
First recorded activity by AviationBanter: May 2011
Kirk
66
Spoken like a true F-4 Phantom alumni!
Old July 11th 13, 03:03 PM posted to rec.aviation.soaring
kirk.stant
Guilty!
Rhinos rule - and they have audio AOA!
Kirk
66
LX MiniMap With SeeYou Mobile and Stick Control/Keyboard Control Glen Kelley[_2_] Soaring 7 January 10th 14 04:22 PM
UK2 NJ318 Airspeed Oxford 1950orLater to G-AKCW to UK VX587 Airspeed Consul.jpg Joseph Testagrose Aviation Photos 0 February 9th 12 11:16 AM
Airspeed control during ground launch? Roger Worden Soaring 27 April 3rd 07 06:35 AM
Need glider airspeed indicator [email protected] Soaring 1 June 21st 05 09:57 PM
Tow plane airspeed vs. glider being towed airspeed? MHende6388 Soaring 2 September 28th 03 09:35 AM
