e Reader options for xc soar?
Old July 23rd 13, 04:48 PM posted to rec.aviation.soaring
Mike Hostage
Default e Reader options for xc soar?
I am flying with a Nook Simple Touch, loaded with TopHat (a derivative of
XCSoar, see: tophat.freeforums.org), connected to a Cambridge 302. The
display is superb in direct sunlight and the update rate is immaterial,
given that I use the instrument for occasional quick reference, not
detailed and continuous study.
I have mounted the Nook on a stalk attached to the cockpit side rail,
giving me full panel access for regular instruments.
Mike
At 15:23 23 July 2013, Dan Marotta wrote:
These new devices are interesting, notwithstanding possible slowness.
However, I wonder how you mount them in the cockpit since they're so
large.
Will you make a leg strap or mount it to a stalk? Simply laying it on
your
lap could become an expensive surprise when you hit a strong vertical
shear
and it rises up and through your canopy!
I made paper cutouts of all my instruments and of various sized Android
devices and tried laying them on a spare uncut panel I have. Not even a 7
inch model could be integrated into my panel and I didn't want a Ram
mounted
thing that big blocking the view of my panel.
For now, my Streak on a home made mount works great but I'm always on the
lookout for a suitable replacement.
"Jp Stewart" wrote in message
That's the traditional Nook "Simple Touch"
http://www.barnesandnoble.com/p/nook...ble/1102344735
I can vouch for it as an e-reader but it is pretty slow for something
like
xc-soar.
JP
Old July 23rd 13, 09:15 PM posted to rec.aviation.soaring
AGL
Yes, it's a Nook. I have one with TopHat too, but use a USB mouse GPS or my back-up generic Garmin with a serial/usb adapter. I take it home and download the igc file by USB. (ok for the OLC) It works very well so far.
I made custom clips for a RAM-HOL-TAB-SMU with a 1" ball system to the cockpit side rail. It covers the spare Winter mechanical vario I never use.
After flying four hours on the regular 7AH batteries with that and an audio vario, voltage dropped from 12.8 12.6 volts. One day I'll measure the current usage, but it's a non-issue.
I see no indication that it's too slow to do the job. On-line objections about speed or ghosting have been theoretical. Try one! It's cheap enough. :-)
Old July 23rd 13, 11:18 PM posted to rec.aviation.soaring
Kimmo Hytoenen
This is video of our installation:
http://www.youtube.com/watch?v=a28I9u0fYO8
Still some issues with IOIO connection, but I have been flying with
it. It's B&W only, some ghost images, maybe slow... but readability
in glider cockpit is so much better than anything else, that I am
sure that this is the future of PNA devices.
Since viewing angle is practically unlimited, kneeboard use should
be possible.
Old July 24th 13, 03:14 PM posted to rec.aviation.soaring
Dan Marotta
I present the following not as criticism, but as an alternative for those
who don't want to spend a lot of money.
I looked at RAM mounts for my Streak installation and just couldn't justify
the high price. There's a lot of talk about adjustability but, seriously, I
think that, once you have it adjusted to your preference, you leave it
there. My solution was simple and, most importantly, cheap!
I went to WalMart and bought a universal car cell phone mount. It came with
suction cup and AC vent attachments. Using a hacksaw, I removed the suction
cup base and then, with two adel clamps
(http://www.google.com/imgres?imgurl=...d=0CDsQ9QEwAg),
a couple of nuts and screws, attached it to the side of my panel above my
knee. After a single adjustment, it's there permanently.
"AGL" wrote in message
use.
enough. :-)
Old July 29th 13, 07:28 PM posted to rec.aviation.soaring
Wallace Berry[_2_]
I flew with the Nook running Top Hat for the first time this weekend. It
updates at least as fast as my old PDA. Ghosting was not an issue at all
although I did not enable terrain. I did have roads and rivers turned
on. The Nook is connected to a GPS puck and ship power by an
off-the-shelf OTG ""y" cable. It was stable and held GPS lock for a 2.5
hour flight. Previously, I had tested the setup in the car for almost 3
hours and it worked perfectly there as well.
What a joy to fly with a big display that is actually visible in
sunlight!
Top Hat is thankfully pared down a bit from XCSoar. XCSoar and LK8000
both have too many features IMHO. So far Top Hat does everything that I
want it to do and is simple to use.
One feature that I did not try out: The thermalling assistant. I already
have a great thermalling assistant. It's called a 301 Libelle. She
shakes and wags to tell me where the lift is and I can even keep my eyes
out of the cockpit.
Old July 29th 13, 08:06 PM posted to rec.aviation.soaring
Soartech
JB,
Where did you find this cable? I have not seen one.
Old July 29th 13, 10:32 PM posted to rec.aviation.soaring
Wallace Berry[_2_]
JB,
Got it from a vendor listing on Amazon. It was less than $4 with
shipping. Here's the link:
http://www.amazon.com/dp/B00CXAC1ZW/...pe_309540_2672
5410_item
IGC Reader for iPhone/iPad Jelle Vandebeeck[_2_] Soaring 13 October 25th 11 09:05 PM
RAS group reader Andy Smiel Soaring 15 November 20th 10 11:17 PM
News Reader Stretch Aviation Photos 2 March 10th 08 11:40 AM
easy to use news reader? Dave[_16_] Aviation Photos 10 August 18th 07 12:24 AM
looking for Reader's Digest article [email protected] Soaring 0 March 23rd 06 03:16 AM
