On 08/06/2013 11:51 AM, kirk.stant wrote:
On Tuesday, August 6, 2013 4:17:59 PM UTC+2, Mike the Strike wrote: I think he means that he shortened the mile-long signal-eating coaxial cable that is shipped with the unit - it's an easy fix that I also did. Mike I may have to bring my antennas to you for "the fix" this winter. Need to shorten the GPS antenna cable too - it's ridiculous! But all seems to work OK - on the few occasions I've flown 66 this year... Kirk I believe PowerFlarm are now supplying different antennas for that are tuned for the xpndr freequencies Luke |
Correct, I was referring to the shorter more tuned antenna. Early units came with identical antennas for PCAS and Flarm (except the connector). If your antennas are identical in size and you have reception issues you may want to consider replacing with the newer one. My newer antenna also came with shorter coax. It is also possible that my antenna had a defect, but once I replaced the antenna the results were remarkably better.
Ramy |
Ramy, through what source did you purchase this newer style antenna?
Is the newer antenna just for flarm or is there a newer and better antenna for the pcas also? Thanks, Joe |
On Wednesday, August 7, 2013 5:11:34 AM UTC-7, joesimmers wrote:
Ramy, through what source did you purchase this newer style antenna? Is the newer antenna just for flarm or is there a newer and better antenna for the pcas also? Thanks, Joe It is the other way around. The newer Antenna is just for PCAS. It came out shortly after the initial batch were delivered. You should be able to order one from your dealer. Ramy |
ZAON MRX | Andrzej Kobus | Soaring | 1 | February 9th 13 01:39 AM |
Fs Zaon Pcas Xrx | cessna150 | Aviation Marketplace | 0 | January 26th 12 06:02 AM |
Warning to users of Zaon PCAS MRX | Bruno[_2_] | Soaring | 23 | February 22nd 10 05:04 PM |
GPS intrference from Zaon PCAS ?? | Carl | Soaring | 9 | May 31st 07 05:12 AM |
I got my Zaon XRX PCAS test flight | cpu | Products | 3 | January 27th 06 01:13 AM |
