Correct, I was referring to the shorter more tuned antenna. Early units came with identical antennas for PCAS and Flarm (except the connector). If your antennas are identical in size and you have reception issues you may want to consider replacing with the newer one. My newer antenna also came with shorter coax. It is also possible that my antenna had a defect, but once I replaced the antenna the results were remarkably better.
Ramy |
Ramy, through what source did you purchase this newer style antenna?
Is the newer antenna just for flarm or is there a newer and better antenna for the pcas also? Thanks, Joe |
On Wednesday, August 7, 2013 5:11:34 AM UTC-7, joesimmers wrote:
Ramy, through what source did you purchase this newer style antenna? Is the newer antenna just for flarm or is there a newer and better antenna for the pcas also? Thanks, Joe It is the other way around. The newer Antenna is just for PCAS. It came out shortly after the initial batch were delivered. You should be able to order one from your dealer. Ramy |
ZAON MRX | Andrzej Kobus | Soaring | 1 | February 9th 13 01:39 AM |
Fs Zaon Pcas Xrx | cessna150 | Aviation Marketplace | 0 | January 26th 12 06:02 AM |
Warning to users of Zaon PCAS MRX | Bruno[_2_] | Soaring | 23 | February 22nd 10 05:04 PM |
GPS intrference from Zaon PCAS ?? | Carl | Soaring | 9 | May 31st 07 05:12 AM |
I got my Zaon XRX PCAS test flight | cpu | Products | 3 | January 27th 06 01:13 AM |
