Flyte Park Microvario
Old August 15th 13, 07:29 PM posted to rec.aviation.soaring
James Lee
Default Flyte Park Microvario
On Thursday, August 15, 2013 1:02:58 AM UTC-4, Ramy wrote:
James, which version you bought, the micro or micro pro? I bought the nano which suppose to be the same as the micro just smaller and I found it totally unusable in a glider. It will switch back and forth from lift to sink alarm during a steady climb at steady speed. Can't even turn off the sink alarm. Which profile are you using? I used E which suppose to be less sensitive.
Ramy
I got the Micro which should be the same sensor, just a little bigger battery. I left it on the factory setting (1) for the first flight. There are a couple settings with no lift tone, just climb and sink. Maybe try one of those?
90 Minutes at Zruc Air Park - File 35 of 45 - 90 Minutes At Zruc Air Park 81c.jpg (1/2) Orval Fairbairn[_2_] Aviation Photos 5 July 18th 09 03:27 AM
Luke AFB Air Park Jim[_2_] Aviation Photos 0 July 1st 07 04:50 AM
Veteran's Day NMUSAF Memorial Park 11-10-06 - File 01 of 16 - Memorial Park NMUSAF.JPG (1/1) Blue Oval Aviation Photos 0 November 11th 06 01:29 AM
