jfitch wrote, On 8/11/2013 9:59 PM:
It makes a difference if you are trying to relate your thermaling track to a track projected to the ground. Some thermal assistants (like SYM) draw a track on the ground color coded by climb rate. If you are drifting with the wind, this track quickly drifts upwind relative to you and the airmass (which are drifting downwind). The Thermal Assistant in my version of SYM does not draw a track on the ground (of course, the map shows the ground track); instead, it opens it's own window with no map info on it, and uses about 20 or so small circles ("bubbles") arranged uniformly in a large circle to display the thermal. Each bubble is sized and colored to depict the lift at that point: bigger bubble, bigger lift; red is stronger, blue is weaker (the actual colors can be selected) In essence, your circles do overlay each other, no matter how much the glider drifts with the wind. I never had trouble with wind drift when using the Assistant. ClearNav, what I am now using, does use a ground track, and it's hard for me to make sense of the the thermal is doing from it's depiction. I'm nagging them about this, and I hope it will be improved soon. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl |
On Tuesday, August 20, 2013 1:55:53 PM UTC-7, Eric Greenwell wrote:
jfitch wrote, On 8/11/2013 9:59 PM: It makes a difference if you are trying to relate your thermaling track to a track projected to the ground. Some thermal assistants (like SYM) draw a track on the ground color coded by climb rate. If you are drifting with the wind, this track quickly drifts upwind relative to you and the airmass (which are drifting downwind). The Thermal Assistant in my version of SYM does not draw a track on the ground (of course, the map shows the ground track); instead, it opens it's own window with no map info on it, and uses about 20 or so small circles ("bubbles") arranged uniformly in a large circle to display the thermal. Each bubble is sized and colored to depict the lift at that point: bigger bubble, bigger lift; red is stronger, blue is weaker (the actual colors can be selected) In essence, your circles do overlay each other, no matter how much the glider drifts with the wind. I never had trouble with wind drift when using the Assistant. ClearNav, what I am now using, does use a ground track, and it's hard for me to make sense of the the thermal is doing from it's depiction. I'm nagging them about this, and I hope it will be improved soon. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl The latest version of SYM draws a color coded ground track, as well as the bubbles. Still has quite a ways to go to catch up with what Winpilot had in 2005.... |
Thermal Forcasting -Thermal index | gldrgidr | Soaring | 6 | November 27th 10 10:26 PM |
Manchester England (EGCC) Spey Engine (I assume) | Andrew B | Aviation Photos | 0 | October 9th 07 09:39 PM |
Circular runways for airports? | Larry Dighera | Piloting | 15 | December 27th 06 12:24 AM |
Thermal Data Files Thermal Mapping Project Australia | Mal | Soaring | 0 | December 2nd 05 11:14 PM |
Circular Runway | jsmith | Piloting | 55 | April 11th 04 10:22 AM |
