FLARM antenna mounts for ASG-29
Old September 7th 13, 02:27 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default FLARM antenna mounts for ASG-29
On Fri, 06 Sep 2013 19:15:13 -0600, Dan Marotta wrote:
OK, I read the accident report and I can't agree with their findings.
The following was lifted directly from the report:
"A section of canopy of the ASW 19B was found at the top of Sutton Bank,
and the rest of the canopy was found in close proximity to the glider's
fuselage, some 500 m away. Examination of the glider confirmed that the
jettison procedure had been initiated, but not completed, before impact
with the ground. The forward section of the canopy frame had been
released from the 'lifting arm' prior to ground impact, but the canopy
locking pins were in the 'LOCkeD' position."
Part of the canopy was found quite a ways off (it seems) and the rest
was found some 500m from the wreck. I doubt it would have bounced that
far following the crash. The report mentions the cables apparently
being quite securely fastened to the canopy frame so I've just gotta
ask, "How long were those cables?" 500m? Or did they break loose?
With respect, I think you misread that. I read it as saying that part of
the canopy was at the top of Sutton Bank. The rest of the canopy *and the
fuselage* were close together and about 500m from the detached portion.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old September 7th 13, 04:47 PM posted to rec.aviation.soaring
Dan Marotta
If I did misread it, then I stand corrected. Even though we speak the same
language across the pond, it's not always received the same way.
"Martin Gregorie" wrote in message
org |
Old September 7th 13, 05:30 PM posted to rec.aviation.soaring
same language across the pond, it's not always received the same way.
The wording could have been improved.
I'd have written it as:
and the rest of the canopy was found in 500m away in close proximity to
the glider's fuselage. Examination of the glider confirmed that the
I remember reading the AAIB report when it came out.
I presume that by 'the locking pins' they mean the two pins at the rear
that hold the canopy closed. With the front of the canopy freed from the
lifting arm that normally acts as the front pivot but restrained by the
PDA cables after the front had lifted a foot or two, those two pins and
the cable would certainly keep the canopy attached and prevent egress.
org |
Old September 11th 13, 02:35 PM posted to rec.aviation.soaring
Steve Koerner
I'm late to this discussion but I can point out that there is a push-on style RF connector designated as SMB. That's what I used to provide an assured breakaway at minor load.
PowerFLARM antenna mounts Dave Nadler Soaring 52 August 14th 14 01:34 PM
Nice FLARM antenna mount in ASG-29 Dave Nadler Soaring 8 April 6th 13 09:49 PM
Again with FLARM antenna questions. brianDG303[_2_] Soaring 0 July 23rd 12 05:35 PM
PowerFLARM antenna mounts Dave Nadler Soaring 0 July 4th 12 04:11 PM
FLARM antenna installation Kevin Neave Soaring 5 January 16th 07 06:53 PM
