"Bad" CAI302 Display
Old September 18th 13, 05:14 AM posted to rec.aviation.soaring
Doug Mueller
Default "Bad" CAI302 Display
Dan, you can rotate your glasses 90 degrees, if the display
becomes visable, it is the glass not the LCD on the 302.
Old September 18th 13, 01:51 PM posted to rec.aviation.soaring
Peter Purdie[_3_]
The material in polarised sunglasses is oriented to minimise specular
reflection from water/snow surfaces. As a bonus for soaring pilots this
enhances cloud definition. Rotating sunglasses material reduces the useful
effect appreciably, so negates the benefit of polarising sunglasses.
Early production CAI302s had an LCD with the 'wrong' orientation for
polarising sunglasses, and nobody is likely to have a new batch
manufactured now.
The only practical answer is to use non-polarising sunglasses; brown tint
is good for cloud definition. A reddish tint is even better, but at the
expense of false colour which can cause problems when identifying crop
types for the field selected, and in reading paper charts.
Old September 18th 13, 03:02 PM posted to rec.aviation.soaring
Dan Marotta
It's 45 degrees, not 90. Very strange.
And still no definite answer about whether it's the LCD waver or the front
glass that's the problem. I wear my old standby smoke colored sunglasses in
the glider and the Eagle Eyes in the car. I'd much prefer the reverse.
I sent Gary an email but no reply just yet...
"Peter Purdie" wrote in message
manufactured now.
Old September 18th 13, 03:57 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default CAI302 Display
Peter Purdie wrote, On 9/18/2013 5:51 AM:
I found it practical to punch holes in my polarized clip-ons. That
eliminated the polarization over the area of the panel, and also the
tinting: no LCD problems, no paper chart problems (not that I look at a
chart very often). It does not solve the tinting problem for crops,
because I'm using bifocal glasses, and the holes are over the bifocal part.
I'd probably use non-polarized clip-ons if I could find them. If you
don't need distant vision correction, there are polarized "sunreaders"
available that have non-polarized, non (or lightly)-tinted inserts with
correction for reading.
http://www.amazon.com/Polarized-Bifo...reader+glasses
These look like the inserts are tinted, unlike the ones I have. Since
the inserts aren't polarized, looking at LCDs isn't a problem.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
InReach: does it have a "daily" track display? Eric Greenwell[_4_] Soaring 6 March 3rd 13 04:57 PM
Raptors are the worlds most advanced ground display "aircraft" Dan[_15_] Piloting 2 October 24th 11 01:02 AM
CAI302 altitude in NMEA.. PCool Soaring 6 October 23rd 09 07:25 PM
"Helmet system replaces heads-up display on F-35s" Mike[_1_] Naval Aviation 19 May 11th 07 01:45 PM
Which would draw more juice? A glass display Dynon Efis-D100 or regular style "Steam Gauges" that are electric. [email protected] Home Built 3 September 30th 06 08:36 PM
