Minden Airstrip Review
Old September 21st 13, 04:51 PM posted to rec.aviation.soaring
Ramy
Default Minden Airstrip Review
The Truckee database covers the exact same area and is much more current. It is maintained by Sergio and myself. Last update was earlier this year. Still it may have outdated data, but at least anything that was brought to our attention was corrected. I recommend anyone flying from Reno area to use the Truckee database. However as others pointed out, if you can't get high enough (over 12K) it is not worth trying to go XC here. If you are at the normal altitude band, there are only few airports we occasionaly land at: Carson, Rosachi, topaz international, Hilton ranch, swee****er, alpine county, Bridgeport, Mamooth, Lee Vining, Bishop, Hawthorn, Yerrington, Mina, gabbs, Austin, Flanigan, Susanville, Sierraville, Nervino.
These are the ones that comes to mind. I may have missed few. You probably don't need to consider more than that.
Ramy
Old September 21st 13, 05:41 PM posted to rec.aviation.soaring
Ramy
Forgot to mention that I looked at your list and almost everything you listed I never considered as landable places (although they may be) other than Spaulding and both soldier meadows. The whole black rock dry lake is landable but we normally land as close to Gerlach as possible (should be on Truckee database). I dont think you would need to consider any of the others in any day worth flying XC.
Ramy
Old September 21st 13, 09:17 PM posted to rec.aviation.soaring
Ramy
Ramy,
Have you guys considered coding all these marginal strips as 'outlanding' (type 3 in .CUP files, '(L)andable in .DAT files) rather than as an airport? My main intent in doing the review is to NOT aim at a marginal/non-existent airstrip, and absent a different appearance on my PDA, as a newcomer I won't know the difference. Just a thought, but it might help us newcomers ;-)
In the meantime, I'll probably modify the standard database to remove/re-code for my personal use.
Frank (TA)
Old September 21st 13, 06:48 PM posted to rec.aviation.soaring
I'd add Farias Wheel (been there, done that, in a Duo), Tiger Field, Silver Springs, and Rabbit Dry Lake (if actually dry) to that list. There are other places where 15M or less gliders can safely land (Herlong comes to mind, if it's still there). While I have managed to land safely in a couple of backyard strips, if one is resorting to those sorts of options, it's because they're doing it wrong...
Marc
Old September 21st 13, 07:38 PM posted to rec.aviation.soaring
Mike I Green
Ramy
Don't know a Flanigan Airport. Do know a Flanigan Turnpoint and a
Flanigan Dry Lake, which are several miles apart. Flanigan Dry Lake may
or may not be land-able depending on the season. Flanigan Turnpoint is
not land-able.
Mike I Green
Old September 22nd 13, 04:13 AM posted to rec.aviation.soaring
Ramy
Ramy,
Thanks for taking the time to list out the most commonly used airports. I agree that all these aiports, with the exception of Flanigan (no airport found, waypoint is coded as non-landable) appear imminently landable even for 18m. Nervino is called 'Beckworth' in the Minden database, but 'Nervino' in AirNav and the FAA database. Don't know why the Minden database renamed it, but ... ;-).
Are you referring to the dry lake bed near Flanigan, and if so, can you comment on what parts of the year it is usable?
TIA,
Frank (TA)
Airstrip on the property Mark Piloting 8 December 14th 09 04:13 PM
How to land on a grass airstrip drclive Piloting 144 June 25th 06 06:41 PM
Planning a Minden Vacation?-Rating? Soar Minden Block Time FS SAVE SOME MONEY! [email protected] Soaring 1 January 27th 06 07:16 PM
Airstrip on Sanibel Island fl? [email protected] General Aviation 2 August 22nd 03 10:01 PM
