Oxygen Generators
Old October 1st 13, 09:12 AM posted to rec.aviation.soaring
Peter Purdie[_3_]
Default Oximeter issues
If you are going to use an EDS system, then you need to know how it is
meant to work (and from some of the comments on the thread clearly some
posters don't).
The EDS system gives a pulse of O2 at the beginning of the breathing cycle,
the length of the pulse depends on the ambient pressure. When you inhale,
the oxygen used by the lungs is taken from the air that ends up down there
any oxygen in the upper respiratory tract is unused and breathed out.
If you stop inhaling at the end of the pulse ('shallow breathing') then the
oxygen at the end of the pulse is wasted, it never gets down to the lungs.
The EDS box doesn't know that so you are under delivering useful oxygen.
Constant flow systems enrich all the air in the system, so 50% plus of the
oxygen you pay for is wasted.
You need to be aware of the need to breathe normally. I have used EDS with
cannula up to 24,000ft or so without issues. I have had an altitude
chamber run so I can recognise the symptoms of anoxia (yes, I know it can
creep up on you).
Old October 1st 13, 12:43 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
I have gotten away with using EDS with
creep up on you).
Fixed it for you. Sorry, hot button issue. I am aware of pilots having flown the EDS/cannula system to around 27K, once or twice. That doesn't mean it's something we ought to brag about. The guy that did that has since smartened up, uses an EDS mask above 18K, has a nice constant flow backup system in place.
On constant flow, use of a mask above 18K is even more important. You probably can achieve good oxygen saturation on a constant flow cannula at 25K, but the flow rate will have to be high to do it (several liters/minute). Misleading advertising aside, a good quality rebreather mask is a far more efficient delivery device than a "pink mustache".
Evan Ludeman (Mt Wash Wave Camp Ox Nag)
Vortex generators? Waveguru Soaring 3 December 17th 12 04:21 PM
Generators that use Wind power. a[_2_] Home Built 6 July 17th 08 02:36 AM
vortex generators. Stew Hicks Home Built 2 July 17th 06 12:56 AM
Vortex Generators Source Pietpilot Home Built 0 August 14th 04 10:35 PM
Generators, redundancy, and old stories Michael Owning 2 March 3rd 04 06:25 PM
