Nothing magical about 45 degree angle of bank. For any given angle of
bank, turn radius varies with the square of (true) airspeed. For the gliders we are mostly used to and average sized and velocity gradient thermals, 45 degrees is often about right. For a vintage type with a stalling speed of 30 knots, circling at 30 degrees of bank, or even less, at 35 knots may be better, for a heavily ballasted modern type, in a small thermal, 60 degrees or even more may be best (better to dump the water unless your pretty sure of finding bigger thermals later). How much bank to use in a particular thermal is one of the most important and hardest learned skills. At 17:48 05 October 2013, son_of_flubber wrote: I know that a 45 degree bank is useful for flying small circles and staying in small thermals, but is there something special about a 45 degree bank compared to say a 50 degree bank? For example, does the designer intend for the glider to do something special at 45 degrees? Is the glider designed to balance aerodynamic forces in a particular harmony at a precise 45 degree bank? |
Thank you for the recommendations made here. I've just ordered copies of:
"Fundamentals of Sailplane Design" by Fred Thomas. "Radio Control Thermal Gliding" by Markus Lisken and Ulf Gerber Good reading for the winter ahead. |
If you haven't already read it, you should also look at "Streckensegelflug"
by Helmut Reichmann: http://www.amazon.com/Streckensegelf.../dp/3613024799 "son_of_flubber" wrote in message ... Thank you for the recommendations made here. I've just ordered copies of: "Fundamentals of Sailplane Design" by Fred Thomas. "Radio Control Thermal Gliding" by Markus Lisken and Ulf Gerber Good reading for the winter ahead. |
On Sunday, October 6, 2013 1:47:40 PM UTC-4, Dan Marotta wrote:
If you haven't already read it, you should also look at "Streckensegelflug" Ich habe nur eine bischen deutsch. |
If that means you don't speak German, fear not. It's published in English.
"son_of_flubber" wrote in message ... On Sunday, October 6, 2013 1:47:40 PM UTC-4, Dan Marotta wrote: If you haven't already read it, you should also look at "Streckensegelflug" Ich habe nur eine bischen deutsch. |
60 degree Mopar V6 for homebuilt? | RapidRonnie | Home Built | 17 | February 9th 07 04:12 AM |
90 degree locking pliers? | B. Jensen | Home Built | 8 | October 3rd 05 06:50 PM |
37 degree fitting | Ernest Christley | Home Built | 8 | June 17th 04 03:29 AM |
90 Degree turn while slipping | ISoar | Soaring | 40 | February 14th 04 10:49 AM |
37 degree flare, 1/8" stainless | Richard Riley | Home Built | 8 | August 29th 03 04:21 AM |
