At 15:34 06 October 2013, Bill D wrote:
On Sunday, October 6, 2013 2:53:16 AM UTC-6, Don Johnstone wrote: http://www.aaib.gov.uk/cms_resources.cfm? file=3D/Schempp-Hirth%20Nimbus-3= %20glider%20G-EENN%2006-13.pdf There are so many bonehead screw-up's in this report it makes one want to c= ry. A few: 1. Not staging the glider so it points exactly at the winch. 2. A VERY long, slow, wobbly takeoff roll despite a 15kt headwind component= .. 3. A failure of the launch crew to stop the launch when a wing went down. 4. Not releasing when it was clear the ground roll wasn't precisely normal. A dry Nimbus 3 launching into a 15 knot wind would likely have aileron cont= rol BEFORE the roll began and should have been airborne in around one secon= d after rolling about a glider length. Obvious point: Once airborne, there= 's no danger of dragging a wing. At least you Brits are good at writing accident reports. This tragic accident happened to one of my club colleagues. With reference to the comments above: 1) There is nothing in the AAIB report to suggest that the glider was not pointing at the winch. It was situated 30m from the position that the cables had been drawn to and so the cable would have been pulled over to the glider. It may have been better to point the glider away from the winch and somewhat towards the line of the cable. (Better still to have minimized the bow in the cable by positioning the glider closer to the cable and pulling the cable as straight as possible.) 2)There is nothing in the report to suggest "a very long, slow, wobbly takeoff roll". I can report from personal experience of many launches from the winch and professional winch-driver involved that this is a very powerful rapidly accelerating winch. The AAIB report makes direct reference to the fact that the winch was operated correctly according to the manufacturer. The cable released at 4 seconds from the start of the launch with the glider already airborne and unrecoverable so that leaves no time for a takeoff roll as characterised above. 3) There is no suggestion in the AAIB report of a "failure" by the ground crew to stop the launch. This point is specifically addressed: "On this occasion both the wing holder and the launch signaller saw the wing touch the ground but events then developed quickly, so it is unlikely that either of them had time to consider and make a ‘stop’ signal. Therefore, the responsibility to release the cable would have to rest with the pilot" 4) Agreed - to release the cable as soon as the wing cannot be kept level is vital. John Galloway |
On Sunday, October 6, 2013 2:08:30 PM UTC-6, John Galloway wrote:
At 15:34 06 October 2013, Bill D wrote: On Sunday, October 6, 2013 2:53:16 AM UTC-6, Don Johnstone wrote: http://www.aaib.gov.uk/cms_resources.cfm? file=3D/Schempp-Hirth%20Nimbus-3= %20glider%20G-EENN%2006-13.pdf There are so many bonehead screw-up's in this report it makes one want to c= ry. A few: 1. Not staging the glider so it points exactly at the winch. 2. A VERY long, slow, wobbly takeoff roll despite a 15kt headwind component= .. 3. A failure of the launch crew to stop the launch when a wing went down. 4. Not releasing when it was clear the ground roll wasn't precisely normal. A dry Nimbus 3 launching into a 15 knot wind would likely have aileron cont= rol BEFORE the roll began and should have been airborne in around one secon= d after rolling about a glider length. Obvious point: Once airborne, there= 's no danger of dragging a wing. At least you Brits are good at writing accident reports. This tragic accident happened to one of my club colleagues. With reference to the comments above: 1) There is nothing in the AAIB report to suggest that the glider was not pointing at the winch. It was situated 30m from the position that the cables had been drawn to and so the cable would have been pulled over to the glider. It may have been better to point the glider away from the winch and somewhat towards the line of the cable. (Better still to have minimized the bow in the cable by positioning the glider closer to the cable and pulling the cable as straight as possible.) 2)There is nothing in the report to suggest "a very long, slow, wobbly takeoff roll". I can report from personal experience of many launches from the winch and professional winch-driver involved that this is a very powerful rapidly accelerating winch. The AAIB report makes direct reference to the fact that the winch was operated correctly according to the manufacturer. The cable released at 4 seconds from the start of the launch with the glider already airborne and unrecoverable so that leaves no time for a takeoff roll as characterised above. 3) There is no suggestion in the AAIB report of a "failure" by the ground crew to stop the launch. This point is specifically addressed: "On this occasion both the wing holder and the launch signaller saw the wing touch the ground but events then developed quickly, so it is unlikely that either of them had time to consider and make a ‘stop’ signal. Therefore, the responsibility to release the cable would have to rest with the pilot" 4) Agreed - to release the cable as soon as the wing cannot be kept level is vital. John Galloway I'm not basing this entirely on the AAIB report - I can read between the lines and I have other sources. No, the AAIB didn't address those issues although they certainly should have. Instead, they ignored a wealth of obvious facts and blamed the accident on the release position which has worked just fine in literally millions of releases. Even so, if the owner, or a maintenance shop, thought there was a problem, adding a flexible release extension is SOP. Such an extension is even shown in Figure 5 with the release T-handle BEHIND the stick. Figure 6 showing a 'pilot' with his RIGHT hand blocked from reaching a release is grossly misleading. I hope the AAIB doesn't risk its reputation by presenting this argument in court. Independent sources the glider was not pointing at the winch and, John, even you suggest that's acceptable. I say the rope must be dead straight and the glider pointed exactly at the winch - no exceptions. This accident is a great example of why. I've been officially involved in very similar accidents where the launch crew had far less time yet DID stop a launch in time to save a pilot who failed to release. Your crew had plenty of time to stop the launch. If the signaling system didn't permit such a timely signal, that's yet another problem that needs to be addressed. Clearly the acceleration was VERY slow and the wing did drag so the roll was wobbly. Rolling 29m (95 feet) into a 15 knot headwind component proves it. A dry N3 with flaps set for winch launch lifts off below 33 knots so with the headwind, the winch only had to add 18 knots which requires less than one G for less than one second over a distance of less than 20 feet. All winches, even a Skylaunch, have throttles so the phrase "very powerful rapidly accelerating winch" is meaningless. Acceleration depends only on the throttle setting. So, what could have prevented this accident? In order of importance: 1. Faster acceleration. Get a glider airborne and climbing before a wing can drop. 2. Insist every launch have the rope exactly straight and the glider pointed exactly at the winch. 3. Better communications. Maybe someone at the launch point should have a thumb hovering over a button that lights a big, bright "EMERGENCY STOP" sign in the winch cab. Better yet, have that button trigger the guillotine. This accident report will serve as a classroom example for many years including a "can you find the screw-ups?" exercise. If you suspended the Imperial arrogance long enough, you might hear the groans and forehead slapping from the Continent and around the world - and if you listened to what they're saying you might start improving your miserable accident record. |
li= nes and I have other sources. No, the AAIB didn't address those issues alt= hough they certainly should have. =20 Instead, they ignored a wealth of obvious facts and blamed the accident on = the release position which has worked just fine in literally millions of re= leases. Even so, if the owner, or a maintenance shop, thought there was a = problem, adding a flexible release extension is SOP. Such an extension is = even shown in Figure 5 with the release T-handle BEHIND the stick. Figure = 6 showing a 'pilot' with his RIGHT hand blocked from reaching a release is = grossly misleading. I hope the AAIB doesn't risk its reputation by present= ing this argument in court. OK, try sitting in a Schemp Hirth or even and ASW 17/19/20 with the stick full to the left and try finding the release knob if you do not actually have your hand on it. The time you have to realise you have a problem and react is very short, trying to find the release will take longer than the time you have. Independent sources the glider was not pointing at the winch and, John, eve= n you suggest that's acceptable. I say the rope must be dead straight and = the glider pointed exactly at the winch - no exceptions. This accident is a= great example of why. Actually the glider should point down the direction if the initial cable run, of course that should be the same as the direct line to the winch. I've been officially involved in very similar accidents where the launch cr= ew had far less time yet DID stop a launch in time to save a pilot who fail= ed to release. Your crew had plenty of time to stop the launch. If the si= gnaling system didn't permit such a timely signal, that's yet another probl= em that needs to be addressed.=20 Not so, anyone with any experience of winch launching would know that the time taken for a stop signal to be sent, received by the winch driver and reacted on is way more than the time taken for the event you are trying to prevent being over. Clearly the acceleration was VERY slow and the wing did drag so the roll wa= s wobbly. Rolling 29m (95 feet) into a 15 knot headwind component proves i= t. A dry N3 with flaps set for winch launch lifts off below 33 knots so wi= th the headwind, the winch only had to add 18 knots which requires less tha= n one G for less than one second over a distance of less than 20 feet. =20 All winches, even a Skylaunch, have throttles so the phrase "very powerful = rapidly accelerating winch" is meaningless. Acceleration depends only on t= he throttle setting. So, what could have prevented this accident? In order of importance: 1. Faster acceleration. Get a glider airborne and climbing before a wing c= an drop. Wing drop is not the cause of the problem, it is a symptom. The primary problem is yaw and increased acceleration will exacerbate this. 2. Insist every launch have the rope exactly straight and the glider pointe= d exactly at the winch. 3. Better communications. Maybe someone at the launch point should have a = thumb hovering over a button that lights a big, bright "EMERGENCY STOP" sig= n in the winch cab. Better yet, have that button trigger the guillotine. This accident report will serve as a classroom example for many years inclu= ding a "can you find the screw-ups?" exercise. If you suspended the Imperi= al arrogance long enough, you might hear the groans and forehead slapping f= rom the Continent and around the world - and if you listened to what they'r= e saying you might start improving your miserable accident record. Nothing like a bit of ignorance to provoke a complete misunderstanding of reality. To a certain extent this type of accident is an operating hazard which can be mitigated by making sure that at the very least a pilot is immediately able to terminate the launch. To suggest that a chain of people outside the aircraft can react in time to effect the chain of events, given the total time over which the situation becomes irrecoverable, shows an incredible depth of ignorance. I have absolutely no doubt that over the years pilots in the UK have avoided death or injury by having their hand on the release from the time the cable is attached until complete control is gained in the launch. No, it does not work every time, you have to actually pull it when it goes wrong but part of the problem is that it may not be immediately apparent that it is going wrong until it is to late for anything other than mitigation. The real point is that having your hand on the release may save your life, to me that is a complete no brainer. |
Re winch launching. You guy's might like to check out the very
useful Safe winching leaflet and associated information put out by the BGA after much thought and refinement of the process's. This has resulted in a significant reduction in the number of accidents/injury's in the UK from winch launching. http://www.gliding.co.uk/bgainfo/saf...hlaunching.htm Regards Andy |
On Monday, October 7, 2013 5:33:57 AM UTC-6, Andrew Henderson wrote:
Re winch launching. You guy's might like to check out the very useful Safe winching leaflet and associated information put out by the BGA after much thought and refinement of the process's. This has resulted in a significant reduction in the number of accidents/injury's in the UK from winch launching. http://www.gliding.co.uk/bgainfo/saf...hlaunching.htm Regards Andy Yes, a reduction in accidents to the point where you're now only one order of magnitude worse than the Germans instead of two. |
Wow! I'm gob-smacked at your arrogance Bill!
I give a link to useful information that might help others decide how they want to handle a winch launch and all you can do is rant without any helpful advice or information whatsoever. Why not try being helpful instead. At 17:37 09 October 2013, Bill D wrote: On Monday, October 7, 2013 5:33:57 AM UTC-6, Andrew Henderson wrote: Re winch launching. You guy's might like to check out the very useful Safe winching leaflet and associated information put out by the BGA after much thought and refinement of the process's. This has resulted in a significant reduction in the number of accidents/injury's in the UK from winch launching. http://www.gliding.co.uk/bgainfo/saf...hlaunching.htm Regards Andy Yes, a reduction in accidents to the point where you're now only one order of magnitude worse than the Germans instead of two. |
![]() So, given that it is alleged that the Germans have a far better record on winch accidents than the UK, is there someone on here with a good knowledge of UK and German practices to indicate where or indeed if there are differences that might account for this. I can think of various areas where differences might occur: Glider pilot training on the winch:- amount of launch failure training etc Winch types and driver training including professional or club member operation of the winch. Launch point control systems and personnel operating them - training etc Airfield layout and operations inc quality of strip/grass cutting etc. My main experience is of UK glider clubs so short of people available that at times the wing runner is also communicating upslack/allout over his hand held radio to the winch driver and generally controlling the launch so has both hands occupied. He is in no position while running to be able to stop running, find the transmit button and send a stop command in the event of a problem. |
One of the reasons the UK historically had a poor winch
launching safety record was that we copied German methods. In particular, when we first had powerful German Tost winches we were told to start with the stick hard back to contain the speed. This led to a number of (usually fatal) flick spin accidents, so we realised that this was not a good idea, as have the Germans. We now start with the stick forward of centre and control the rotation rate, and haven't had a flick spin accident for several years. Bill Daniels is the self styled US expert on winch launching, a country where very little winch launching is done. He is busy trying to re-invent the wheel and seems unwilling to learn from European experience (not invented here syndrome). Derek Copeland At 13:55 10 October 2013, Andrew Henderson wrote: Wow! I'm gob-smacked at your arrogance Bill! I give a link to useful information that might help others decide how they want to handle a winch launch and all you can do is rant without any helpful advice or information whatsoever. Why not try being helpful instead. At 17:37 09 October 2013, Bill D wrote: On Monday, October 7, 2013 5:33:57 AM UTC-6, Andrew Henderson wrote: Re winch launching. You guy's might like to check out the very useful Safe winching leaflet and associated information put out by the BGA after much thought and refinement of the process's. This has resulted in a significant reduction in the number of accidents/injury's in the UK from winch launching. http://www.gliding.co.uk/bgainfo/saf...chlaunching.ht m Regards Andy Yes, a reduction in accidents to the point where you're now only one order of magnitude worse than the Germans instead of two. |
Number of aero tows in 2011 | Bill D | Soaring | 35 | November 21st 12 03:39 AM |
Looking for a Yellow Tow Release Handle | Randy Teel | Soaring | 3 | August 7th 12 10:36 PM |
Schweizer Tow Release Handle/Bracket | Jim Newton | Soaring | 2 | May 14th 10 05:17 PM |
Schweizer Tow Release Handle/Bracket | Jim Newton | Soaring | 0 | April 22nd 05 07:21 PM |
CG hook on aero tows?? | Ted Wagner | Soaring | 130 | January 12th 04 11:04 PM |
