I'm not basing this entirely on the AAIB report - I can read between the
li= nes and I have other sources. No, the AAIB didn't address those issues alt= hough they certainly should have. =20 Instead, they ignored a wealth of obvious facts and blamed the accident on = the release position which has worked just fine in literally millions of re= leases. Even so, if the owner, or a maintenance shop, thought there was a = problem, adding a flexible release extension is SOP. Such an extension is = even shown in Figure 5 with the release T-handle BEHIND the stick. Figure = 6 showing a 'pilot' with his RIGHT hand blocked from reaching a release is = grossly misleading. I hope the AAIB doesn't risk its reputation by present= ing this argument in court. OK, try sitting in a Schemp Hirth or even and ASW 17/19/20 with the stick full to the left and try finding the release knob if you do not actually have your hand on it. The time you have to realise you have a problem and react is very short, trying to find the release will take longer than the time you have. Independent sources the glider was not pointing at the winch and, John, eve= n you suggest that's acceptable. I say the rope must be dead straight and = the glider pointed exactly at the winch - no exceptions. This accident is a= great example of why. Actually the glider should point down the direction if the initial cable run, of course that should be the same as the direct line to the winch. I've been officially involved in very similar accidents where the launch cr= ew had far less time yet DID stop a launch in time to save a pilot who fail= ed to release. Your crew had plenty of time to stop the launch. If the si= gnaling system didn't permit such a timely signal, that's yet another probl= em that needs to be addressed.=20 Not so, anyone with any experience of winch launching would know that the time taken for a stop signal to be sent, received by the winch driver and reacted on is way more than the time taken for the event you are trying to prevent being over. Clearly the acceleration was VERY slow and the wing did drag so the roll wa= s wobbly. Rolling 29m (95 feet) into a 15 knot headwind component proves i= t. A dry N3 with flaps set for winch launch lifts off below 33 knots so wi= th the headwind, the winch only had to add 18 knots which requires less tha= n one G for less than one second over a distance of less than 20 feet. =20 All winches, even a Skylaunch, have throttles so the phrase "very powerful = rapidly accelerating winch" is meaningless. Acceleration depends only on t= he throttle setting. So, what could have prevented this accident? In order of importance: 1. Faster acceleration. Get a glider airborne and climbing before a wing c= an drop. Wing drop is not the cause of the problem, it is a symptom. The primary problem is yaw and increased acceleration will exacerbate this. 2. Insist every launch have the rope exactly straight and the glider pointe= d exactly at the winch. 3. Better communications. Maybe someone at the launch point should have a = thumb hovering over a button that lights a big, bright "EMERGENCY STOP" sig= n in the winch cab. Better yet, have that button trigger the guillotine. This accident report will serve as a classroom example for many years inclu= ding a "can you find the screw-ups?" exercise. If you suspended the Imperi= al arrogance long enough, you might hear the groans and forehead slapping f= rom the Continent and around the world - and if you listened to what they'r= e saying you might start improving your miserable accident record. Nothing like a bit of ignorance to provoke a complete misunderstanding of reality. To a certain extent this type of accident is an operating hazard which can be mitigated by making sure that at the very least a pilot is immediately able to terminate the launch. To suggest that a chain of people outside the aircraft can react in time to effect the chain of events, given the total time over which the situation becomes irrecoverable, shows an incredible depth of ignorance. I have absolutely no doubt that over the years pilots in the UK have avoided death or injury by having their hand on the release from the time the cable is attached until complete control is gained in the launch. No, it does not work every time, you have to actually pull it when it goes wrong but part of the problem is that it may not be immediately apparent that it is going wrong until it is to late for anything other than mitigation. The real point is that having your hand on the release may save your life, to me that is a complete no brainer. |
Re winch launching. You guy's might like to check out the very
useful Safe winching leaflet and associated information put out by the BGA after much thought and refinement of the process's. This has resulted in a significant reduction in the number of accidents/injury's in the UK from winch launching. http://www.gliding.co.uk/bgainfo/saf...hlaunching.htm Regards Andy |
On Monday, October 7, 2013 5:33:57 AM UTC-6, Andrew Henderson wrote:
Re winch launching. You guy's might like to check out the very useful Safe winching leaflet and associated information put out by the BGA after much thought and refinement of the process's. This has resulted in a significant reduction in the number of accidents/injury's in the UK from winch launching. http://www.gliding.co.uk/bgainfo/saf...hlaunching.htm Regards Andy Yes, a reduction in accidents to the point where you're now only one order of magnitude worse than the Germans instead of two. |
Wow! I'm gob-smacked at your arrogance Bill!
I give a link to useful information that might help others decide how they want to handle a winch launch and all you can do is rant without any helpful advice or information whatsoever. Why not try being helpful instead. At 17:37 09 October 2013, Bill D wrote: On Monday, October 7, 2013 5:33:57 AM UTC-6, Andrew Henderson wrote: Re winch launching. You guy's might like to check out the very useful Safe winching leaflet and associated information put out by the BGA after much thought and refinement of the process's. This has resulted in a significant reduction in the number of accidents/injury's in the UK from winch launching. http://www.gliding.co.uk/bgainfo/saf...hlaunching.htm Regards Andy Yes, a reduction in accidents to the point where you're now only one order of magnitude worse than the Germans instead of two. |
![]() So, given that it is alleged that the Germans have a far better record on winch accidents than the UK, is there someone on here with a good knowledge of UK and German practices to indicate where or indeed if there are differences that might account for this. I can think of various areas where differences might occur: Glider pilot training on the winch:- amount of launch failure training etc Winch types and driver training including professional or club member operation of the winch. Launch point control systems and personnel operating them - training etc Airfield layout and operations inc quality of strip/grass cutting etc. My main experience is of UK glider clubs so short of people available that at times the wing runner is also communicating upslack/allout over his hand held radio to the winch driver and generally controlling the launch so has both hands occupied. He is in no position while running to be able to stop running, find the transmit button and send a stop command in the event of a problem. |
At 18:05 10 October 2013, John Howell wrote:
My main experience is of UK glider clubs so short of people available that at times the wing runner is also communicating upslack/allout over his hand held radio to the winch driver and generally controlling the launch so has both hands occupied. He is in no position while running to be able to stop running, find the transmit button and send a stop command in the event of a problem. For the record, that scenario emphatically does not apply at the Scottish Gliding Centre. John Galloway |
At 18:47 10 October 2013, John Galloway wrote:
At 18:05 10 October 2013, John Howell wrote: My main experience is of UK glider clubs so short of people available that at times the wing runner is also communicating upslack/allout over his hand held radio to the winch driver and generally controlling the launch so has both hands occupied. He is in no position while running to be able to stop running, find the transmit button and send a stop command in the event of a problem. For the record, that scenario emphatically does not apply at the Scottish Gliding Centre. John Galloway nor at three clubs in eastern england that I regularly visit |
On Thursday, October 10, 2013 7:05:51 PM UTC+1, John Howell wrote:
So, given that it is alleged that the Germans have a far better record on winch accidents than the UK, is there someone on here with a good knowledge of UK and German practices to indicate where or indeed if there are differences that might account for this. We had this debate with Mr Daniels back in July where he was claiming that the UK winch accident record was an order of magnitude or more worse in the UK than Germany. He challenged people to look at the data, which I did (I think it was raining). My conclusion, reproduced below, was that the accident rates (based on fatalities and serious) were not currently significantly different. Having said that, I have no problem learning from what other people do - it's one way to get better. I'm a little disappointed, but perhaps not surprised, that Mr Daniels continues to broadcast the 10:1 difference. Paul Hi Bill None of what follows is to gloss over the need to improve safety, or to say that we can’t learn from others. But, for those of us who have responsibilities in this area, it’s important to distinguish fact from opinion. You seem to be someone who thinks about these things, so here’s a real attempt to engage. So far as I can tell, your premise is that the UK winch accident rate is very poor – an order of magnitude worse than the Germans, and that the cause of that is insufficient acceleration on launch. I think the facts show that you’re wrong. Let’s unpack that. GERMAN VS UK SAFETY You said “The numbers I used are available for anybody to read and analyze. The differences are so huge, there's no way to come up with a different result. If you disagree, go read them and do your own analysis”. So I did and I have. My conclusion is that safety of winch launches in Germany is similar to that in the UK. I base this on the fact that a German pilot’s chance of being seriously injured or killed on a winch launch is similar to that of a UK pilot. I think the differences you are seeing are reporting and analysis differences. In the last seven years, there have been 17 accidents with 20 fatalities and serious injuries closely related to winch launching in Germany. I’ve listed them below. In the same period, there have been five fatal and serious injury accidents relating to winch launching in the UK. (see 2009-2012 accident reports by the BGA) so about a 3.4:1-4:1 ratio depending on whether you count accidents or fatalities. I’ve also listed those. Given your earlier numbers of 180K launches in the UK, and 900K in Germany (a 5:1 ratio), the chance of someone being injured or killed on a winch launch in Germany looks pretty similar to that in the UK – certainly within statistical significance. I conclude that the safety of the two countries is probably similar (whilst still being very interested in anything we can learn from the way that the Germans go about things). We know we can improve in the UK – but it’s not helpful to suggest that there’s worse than an order of magnitude difference – it leads to looking in the wrong place. Don Johnstone’s account of the way that the UK Air Cadets go about things Is much more compelling from an evidential point of view (no fatalities, similar numbers of launches to rest of UK, we’re told) Why are your numbers so different? You seem to be taking the BGA numbers which are all accidents and incidents and comparing them with some fairly filtered results from Germany. The data you previously quoted from 2011, for example, and which you said were not filtered for serious and fatal are all on a table labelled “Reports on completed investigations of accidents and serious incident” from the BFU (http://tinyurl.com/occjw49). I don’t think they get to that list unless they’ve merited an investigation, and it’s notable that in earlier years (up to 2008) there were annual reports published with a lot of incidents that didn’t make it to the main list (see http://tinyurl.com/pxhm4ln). CAUSE OF ACCIDENTS If you’re talking about all the accidents and incidents that the BGA records (which is what you generally seem to be looking at), there’s little to support your contention that the speed of acceleration on the winch launch is the prime cause. By far the majority of incidents and accidents can in no way be related to launch acceleration – for example landing accidents following a real or practice cable break. Even looking at the fatal and serious UK accidents, they appear mostly to be related to other causes. I don’t think anyone is against the idea that an excessively long ground runs are bad – but it’s not clear that being told that the BGA advises a three second acceleration merits “You and the BGA are tragically wrong. You need to take another long look at that analysis. Slow acceleration is the most significant cause of the poor UK accident record. “ Even Andreas is saying that they use 3s accelerations at his club. It’s also not persuasive to dismiss first-hand accounts as old wives’ tales. Think of the definition of the latter. At least one of the German accidents I looked at above seems to have been caused by a high acceleration pitch up (09-3X118) (subject to Google translate’s accuracy!). Even if you’re right about that, your correct observation that high accelerations can cause incorrect pitch sensations would seem to me to be quite a good reason to back off the acceleration. I don’t have a strong view or expertise on this, but I note there seems to be a degree of consensus around a 3 second acceleration (and when I looked at youtube videos, as you suggested, there was not a significant difference between UK and German practice – and I know how to time things, thanks). Bottom line – there’s a useful discussion here, comparing practices in different countries. But it’s not helped by misunderstanding different data sets. Paul Here’s the data. German winch accidents 2006-2012 (serious injury and fatal) 06-3X080: New solo student, cable break at 80m, turned, glider destroyed, serious injury 07-3X127: Steep climb, stall and flick at 40m, glider destroyed, fatal 08-3X041: ASH 26 E, stall and flick at 20-30m, aircraft destroyed, serious injury 08-3X063: Discus 2, water, launch from wing stand, wing drop or low altitude stall, aircraft destroyed, serious injury 08-3X113 : Hornet, roll at about 30m, stall? Aircraft destroyed, fatal 09-3X047: DG300, Low cable break, turned, spun in, glider destroyed, fatal 09-3X118: Cirrus. High acceleration, high angle, flick, aircraft destroyed, fatal 09-3X123: Climb to 10-20m, dropped a wing, crash, injury 09-3X144 : Janus, cable break, heavy landing, one serious injury 10-3X058: SF34, Low cable break, turned, spun in. Aircraft destroyed, two fatalities 10-3X059: ASW19, hit ground from 10-20m. Aircraft destroyed, serious injury 11-3X060. : A Jeans-Astir got launched into a Remos ultralight which crossed the pass of the glider from right to left. The two a/c's collided in about 1,200ft and both lost their wings resulting in three fatalities. 11-3X065: The glider was launched on the winch but did not gain sufficient altitude and released in about 40m. Instead of landing straight ahead, the pilot tried to reach a field to the left and then forced the glider into a ground-loop. Pilot suffered broken vertebrae; the passenger only minor injuries. 11-3X080: A LS4 was being launched and after 40-50m of ground roll (!!) the gear collapsed. The glider was dragged for another 23m on the belly and finally lifted off. The launch-boss had given the 'All-stop' command which was followed by the operator. The glider did not have enough speed or altitude to recover and landed very hard. Minor injuries 11-3X093: Spin-in after normal launch - aircaft destroyed, fatal 11-3X095: A Ka-8 was launched on the winch and when the glider's right wing touched the ground and veered off to the right, the launch-boss gave the command 'All stop', which was followed by the operator. The the command to continue the launch was given but the line detached from the glider which then stalled over the right wing and impacted the ground out of about 10m. The pilot was 65 years old. Serious damage and injury 12-3X034: Wing drop, serious injury, aircraft destroyed I missed out a couple that were on a winch but were, for example, controls not connected. UK winch accidents 2006-2012 (serious injury and fatal) 2006-2008: 2 fatal or serious injury accidents connected with winch launching (BGA Glider Accidents in 2008) 2009: Cable break at 300 ft, instructor lowered nose, turned, stalled. Serious injury 2009: Stall and flick during rotation. Fatal 2012: Cartwheel after wing drop. Fatal |
One of the reasons the UK historically had a poor winch
launching safety record was that we copied German methods. In particular, when we first had powerful German Tost winches we were told to start with the stick hard back to contain the speed. This led to a number of (usually fatal) flick spin accidents, so we realised that this was not a good idea, as have the Germans. We now start with the stick forward of centre and control the rotation rate, and haven't had a flick spin accident for several years. Bill Daniels is the self styled US expert on winch launching, a country where very little winch launching is done. He is busy trying to re-invent the wheel and seems unwilling to learn from European experience (not invented here syndrome). Derek Copeland At 13:55 10 October 2013, Andrew Henderson wrote: Wow! I'm gob-smacked at your arrogance Bill! I give a link to useful information that might help others decide how they want to handle a winch launch and all you can do is rant without any helpful advice or information whatsoever. Why not try being helpful instead. At 17:37 09 October 2013, Bill D wrote: On Monday, October 7, 2013 5:33:57 AM UTC-6, Andrew Henderson wrote: Re winch launching. You guy's might like to check out the very useful Safe winching leaflet and associated information put out by the BGA after much thought and refinement of the process's. This has resulted in a significant reduction in the number of accidents/injury's in the UK from winch launching. http://www.gliding.co.uk/bgainfo/saf...chlaunching.ht m Regards Andy Yes, a reduction in accidents to the point where you're now only one order of magnitude worse than the Germans instead of two. |
At 06:31 11 October 2013, Del Copeland wrote:
One of the reasons the UK historically had a poor winch launching safety record was that we copied German methods. In particular, when we first had powerful German Tost winches we were told to start with the stick hard back to contain the speed. This led to a number of (usually fatal) flick spin accidents, so we realised that this was not a good idea, as have the Germans. We now start with the stick forward of centre and control the rotation rate, and haven't had a flick spin accident for several years. Del, when you say "we copied the German methods etc" - who is the "we"? It was 1969 that I first trained and soloed on the winch in the UK and I have never personally encountered instruction to start a winch launch with the stick hard back to contain the speed. John Galloway |
Number of aero tows in 2011 | Bill D | Soaring | 35 | November 21st 12 03:39 AM |
Looking for a Yellow Tow Release Handle | Randy Teel | Soaring | 3 | August 7th 12 10:36 PM |
Schweizer Tow Release Handle/Bracket | Jim Newton | Soaring | 2 | May 14th 10 05:17 PM |
Schweizer Tow Release Handle/Bracket | Jim Newton | Soaring | 0 | April 22nd 05 07:21 PM |
CG hook on aero tows?? | Ted Wagner | Soaring | 130 | January 12th 04 11:04 PM |
