Keep your hand off the release handle during aero tows!
Old October 8th 13, 05:25 PM posted to rec.aviation.soaring
Dan Marotta
Default Keep your hand off the release handle during aero tows!
Same for me in my LAK-17a except that I lock the spoilers before hookup.
Hand on the flaps which are at negative until I have aileron control and
move the flaps down to thermal position. Hand stays on flap lever (very
close to release) until safely airborne.
I have wheels at the 15 meter tips, at 18 meters, the tips are angled
upwards such that they're parallel with the ground when a "tip" is on the
ground.
We stage on a very wide taxiway with the nose pointed at the taxiway/runway
intersection, maybe 10-15 degrees off runway heading. If a wing is down
and the grass is approaching, we release.
I can't recall how I do it on ground launch since it's been 6 months since I
did one. I'm going back to the dry lake in Nevada for a ground launch
weekend in a couple of weeks and, if this thread is still alive then, I'll
report back.
On Monday, October 7, 2013 12:30:59 PM UTC-6, John Marsh wrote:
Oh!!!! So it,s OK to let your wingtip run along the ground during an areo
tow launch.?? NO NO NO Pull the bloody release when ever your wing is on
the gound THAT WILL SAVE YOUR LIFE ONE DAY Soggy 16:16 07 October 2013,
The real point is that having your hand on the release may save your
life=
to me that is a complete no brainer.
Lol, Love your enthusiasm John. I promise it is possible to use the release
lever without having to hold on to it the entire tow and put yourself in
possible danger of an inadvertent release. Of course you release if you
drop a wing and can't raise it safely on aero tow. That doesn't mean you
need to keep your hand on the thing. In my glider (ASW27) I have my hand on
the spoiler to start and then move to flaps and then move to my knee so it
is close to the release in case I need to pull early. I can move the hand to
the release at any point.
Bruno - B4
Old October 8th 13, 06:34 PM posted to rec.aviation.soaring
Bill D
On Monday, October 7, 2013 2:24:08 AM UTC-6, Don Johnstone wrote:
OK, try sitting in a Schemp Hirth or even and ASW 17/19/20 with the stick
full to the left and try finding the release knob if you do not actually
have your hand on it. The time you have to realise you have a problem and
react is very short, trying to find the release will take longer than the
time you have.
If reaching the release is difficult, it gets an extension installed ASAP. (That a minor modification not requiring paperwork.) The really bonehead action is to continue flying a glider where the pilot can't reach the release. does that idea actually occur to anyone in the UK?
Actually the glider should point down the direction if the initial cable
run, of course that should be the same as the direct line to the winch.
Only the UK still seems to be using steel cable. Almost everyone else is using "plastic rope" (Dyneema) Plastic rope straightens out like a bowstring as soon as tension is applied so it's always in a "direct line to the winch" which means POINT THE GLIDER AT THE WINCH - NO EXCEPTIONS.
Not so, anyone with any experience of winch launching would know that the
time taken for a stop signal to be sent, received by the winch driver and
reacted on is way more than the time taken for the event you are trying to
prevent being over.
No one suggests the pilot shouldn't pull the release. But, clearly, in the case of the UK, that isn't working. You need a backup plan to stop the launch if the pilot doesn't act.
Wing drop is not the cause of the problem, it is a symptom. The primary
problem is yaw and increased acceleration will exacerbate this.
WHAT!! Acceleration causes wing drop? Causes yaw? That's as absurd as it gets.
To a certain extent this type of accident is an operating hazard.
In aviation safety, this is one of the hazardous thought processes called "resignation".
Again, no one says a pilot shouldn't have a hand on the release and should pull it if the launch goes wrong but a fair question is, "How's that working out?"
Giving a skilled observer at the start point an option to instantly stop the launch if the pilot doesn't act would have saved this pilots life. FIGURE OUT HOW TO DO IT! Or, just ask the Germans.
The totally absurd aspect of this is the UK is has a longstanding problem with "cartwheel" accidents like this one. A problem not seen to anywhere near the same degree in the rest of the world. Yet, your response it to lecture everybody else on doing it your way.
Old October 9th 13, 12:57 AM posted to rec.aviation.soaring
Don Johnstone[_4_]
stick
actually
and
time you have.
ASAP.
a=
releas=
I wish it were that simple. A change of this nature, to a critical control,
requires approval from EASA which in turn requires the TC Holder to
approve.
In all the gliders I fly I use a paracord loop which I loop round my wrist
and the release knob. As it is a modification to my hand it does not
require EASA approval.
I am not going to bother answering the rest of your points, I feel you have
proved your ignorance sufficiently.
As far as the UK is concerned starting a winch launch with the hand on the
release is not optional. As I have said before doing it can save your life,
it is a complete no brainer.
Number of aero tows in 2011 Bill D Soaring 35 November 21st 12 03:39 AM
Looking for a Yellow Tow Release Handle Randy Teel Soaring 3 August 7th 12 10:36 PM
Schweizer Tow Release Handle/Bracket Jim Newton Soaring 2 May 14th 10 05:17 PM
Schweizer Tow Release Handle/Bracket Jim Newton Soaring 0 April 22nd 05 07:21 PM
CG hook on aero tows?? Ted Wagner Soaring 130 January 12th 04 11:04 PM
