Keep your hand off the release handle during aero tows!
Old October 10th 13, 11:05 AM posted to rec.aviation.soaring
Terry Walsh[_2_]
Default Keep your hand off the release handle during aero tows!
Fred,
I did not intend this as a comment against Americans I know equally
arrogant people of many different national origins. I was simply commenting
that if this indeed Bill Daniels then he could be considered to be an
expert on winch operations, but his apparent refusal to accept any other
opinion than his own was more than a little arrogant. Since he had
mentioned imperial arrogance I found this ironic.
I do agree with his statement that accidental death is ugly whether caused
by incompetence or any other reason.
Terry Walsh
At 16:59 09 October 2013, Fred Bear wrote:
Well said. Just another big-mouthed Ugly American.
On 10/9/2013 11:45 AM, Terry Walsh wrote:
Hi Justin,
I suspect that this is Bill Daniels, a Google search for Bill Daniels
gliding shows that IN the USA in any case he is considered to perhaps
be
an
expert.
I suspect that by such comments as "imperial arrogance" he is most
certainly not an Anglophile and to be honest find the arrogance part
somewhat ironic.
Terry Walsh
At 12:56 09 October 2013, Justin Craig wrote:
Bill,
I have watched this tread with some interest. Just for the record,
what
authority are you on the subject? I find it very interesting that you
are
so dismissive of the hours of research done by trained professionals
who
have considerable amount of date and past cases to work with.
If this is your humble opinion, look after yourself, but keep your
opinions
to yourself. If how ever you are some sort of authority in the
subject,
I
will bow to your superior judgement.
Regards,
Justin
At 16:52 08 October 2013, Bill D wrote:
On Sunday, October 6, 2013 4:05:57 PM UTC-6, Don Johnstone wrote:
All John says is absolutely correct. The sad fact is that this type
of
accident occurs on a fairly regular basis and as yet no one has come
up
with a plausible cause. What is clear that the wing drop is a
symptom
and
requires that the glider is released very early which is why the
hand
should be on the release. A similar accident happened at my club a
month
back involving a Discus, in that case the pilot was unhurt but the
glider
was written off.
What is clear is that once the glider starts to yaw nothing on this
earth
is going to stop it except contact with the ground so early release,
to
mitigate the inevitable accident, is essential.
The sad fact is the UK hasn't figured out the cause - everyone else
has.
Old October 13th 13, 06:47 PM posted to rec.aviation.soaring
Bill D
On Thursday, October 10, 2013 4:05:22 AM UTC-6, Terry Walsh wrote:
Fred,
I've let the UK "echo chamber" run a bit so they can all congratulate each other for fuzzy thinking.
Arrogant? Indignant and angry are a better words. Every time you screw up, it has enormous impact outside the UK. When those screw-ups are based on institutionalized nonsense, and you try to export that nonsense, it makes me angry. An example is the winch launch section in the 2013 Glider Flying Handbook.
The main source of my guidance isn't from the US, or my own imagination, it's the German SDO Segelflugbetriebsordnung. It contains about the best information on winch launch safety available.
The US stands accused of "doing few winch launches". That's true. Compared to the roughly one million annual launches in Germany, the UK doesn't do many either. That, and their superb safety record, makes Germany a far better source of safety information.
If you want an educational approach, read my thoughts on the acceleration phase and acceleration induced uncommanded rotation.
https://dl.dropboxusercontent.com/u/...celeration.pdf
Old October 13th 13, 08:35 PM posted to rec.aviation.soaring
Terry Walsh[_2_]
OK Bill, here is my problem with your argument that all our problems are
basically due to too slow acceleration.
1. I have not seen or experienced these slow acceleration launches and they
are certainly not the norm at any site at which I have flown recently.
2. I have also auto towed (some years ago) where the acceleration is by
definition slow, I never saw a wing drop come close to an accident.
3. The same applies to aerotows, slow acceleration, here I have seen wing
drops and witnessed people releasing but no cartwheels.
4. The reason these wing drops have been fatal is that they occur just
before the glider ls ready to fly. in my mind this implies that the
acceleration was fast since the glider apparently goes from insufficient
aileron control to flying speed too quickly for the pilot to react. I
think perhaps , as Don said that the problem is actually yaw induced roll.
Based on what you say we in the UK have a much worse safety record than the
Germans, so accepting this I agree that we are apparently not getting
something right. I do not agree with your analysis and you have shown no
readiness to accept that there may be another different problem. This is
what I mean by arrogance. If as you say everybody outside UK agrees with
your argument why have none of them posted here to say so.
I think it is a problem caused by individual pilot errors rather than our
procedures. Why I am not sure although I do have some thoughts regarding
pilot currency.
Terry Walsh
Fred,
=20
=20
=20
=20
commenti=
ng
=20
=20
other
=20
each
up=
on=
makes
Flying=
Handbook.
i=
inf=
Compare=
do
bet=
p=
Old October 14th 13, 03:09 AM posted to rec.aviation.soaring
Bill D
I can't comment on why your experience is what it is, but the BGA is clearly concerned about "cartwheel" accidents.
Aero tow uses a nose hook so the consequences of a wing drop are much less.
With the glider achieving flying speed in 3 - 4 seconds that's not much to distinguish why earlier or later drop is worse. It's bad whenever it happens.
pilot currency.
Terry Walsh
Fred,
=20
=20
=20
=20
commenti=
ng
=20
=20
other
=20
each
up=
on=
makes
Flying=
Handbook.
i=
inf=
Compare=
do
bet=
p=
Old October 14th 13, 06:01 AM posted to rec.aviation.soaring
Del Copeland
Many earlier gliders in the UK are not fitted with nose hooks, just
belly hooks, but we still don't get any cartwheel accidents on
aerotow. There is a slightly increased risk of tug upsets due to
the glider trying to 'winch launch' after take off if the pilot allows
the glider to get too high (so still a good case for keeping your
hand on the release knob during the early stages of an
aerotow). Likewise wire launching by autotow on the belly hook
did not cause cartwheel accidents, despite the slower ground run
acceleration. The difference with high powered winch launches
is that you are putting in much more energy much more quickly,
so the consequences of a wing drop are much more serious.
What happens is that the wingtip contacts the ground, drags,
causes the glider to yaw, so that the other wing speeds up and
produces more lift, adding roll to the yaw and the glider lifts off
with one wing still on the ground. Then the other wing gets up
into the wind gradient and produces even more lift, and at this
point you are history. The safety message is 'keep your wings
level and pull off immediately if you can't'.
Derek Copeland
BGA is
drop are much less.
not much to
whenever it
happens.
problems are
launches and
they
recently.
acceleration is by
accident.
have seen wing
occur just
insufficient
react. I
induced
roll.
safety record than
not getting
have shown no
problem. This is
UK agrees with
so.
than our
thoughts
regarding
pilot currency.
Terry Walsh
Walsh wrote:
Fred,
=20
=20
=20
know equally
=20
simply
commenti=
ng
=20
considered to be an
=20
accept any
other
=20
congratulate
each
time you screw
up=
screw-ups are based
on=
nonsense, it
makes
2013 Glider
Flying=
Handbook.
own imagination,
i=
about the best
inf=
That's true.
Compare=
the UK doesn't
do
Germany a far
bet=
acceleration
p=
https://dl.dropboxusercontent.com/u/...Acceleration.p
df
Old October 13th 13, 10:57 PM posted to rec.aviation.soaring
Del Copeland
Hi Bill,
Did you read Paul Ruskin's analysis of German and UK winch
launching accidents, which was number 66 in this thread. He
concluded that there was no significant difference between fatal
and serious accident rates between the two countries. I note that
Germany had about 4 accidents that came into the stall and flick
roll category while the UK only had one. Germany has about 5
times as many glider pilots as the UK. About 2/3rd's of UK glider
launches are by winch. As Skylaunch has sold many winches to
Germany and Tost to the UK, I assume that the winches are
similar and give the same rates of acceleration in both countries.
BTW, before we had winches at our club, we used to wire launch
by autotow, where the ground run acceleration was REALLY
slow, at least 10 seconds to lift off. I don't remember there
being any ground loop or cartwheel accidents on take off in that
era.
Derek Copeland
Walsh wrote:
Fred,
=20
=20
=20
equally
=20
simply
commenti=
ng
=20
be an
=20
accept any other
=20
congratulate each
time you screw
up=
ups are based
on=
nonsense, it makes
Glider
Flying=
Handbook.
imagination,
i=
about the best
inf=
true.
Compare=
UK doesn't do
Germany a far
bet=
acceleration
p=
df
Old October 14th 13, 03:03 AM posted to rec.aviation.soaring
Bill D
I don't get accident statistics from RAS comments.
The Dropbox link has changed. See:
Old October 14th 13, 09:40 AM posted to rec.aviation.soaring
Tom Gardner[_2_]
I don't get instructions about how to fly safely from RAS comments.
Old October 14th 13, 10:43 AM posted to rec.aviation.soaring
Paul Ruskin[_2_]
Which would be an admirable position Bill, except that I took the trouble to go and find the accident reports from the BFU and BGA and posted a list of winch accidents in my comment, including sources and accident report numbers.
The data says that in the period 2006-12 a German pilot had much the same chance as a UK civilian pilot of being killed or injured in a winch accident.
Perhaps you'd let us know whether you now accept that conclusion, rather than claiming that UK winch launches are 10 times more dangerous?
Paul
Old October 14th 13, 02:43 PM posted to rec.aviation.soaring
Bill D
Paul
Yes, I read your ramble. The operable statistic is number of accidents per number of launches - very simple and not included in your post.
For 2011 (The numbers just look worse for the UK the further back one goes.)
The Germans suffered one accident every 180,000 launches
The UK suffered one every 16,000 launches.
That's better than 10:1 and the number can't be twisted to show parity.
Number of aero tows in 2011 Bill D Soaring 35 November 21st 12 03:39 AM
Looking for a Yellow Tow Release Handle Randy Teel Soaring 3 August 7th 12 10:36 PM
Schweizer Tow Release Handle/Bracket Jim Newton Soaring 2 May 14th 10 05:17 PM
Schweizer Tow Release Handle/Bracket Jim Newton Soaring 0 April 22nd 05 07:21 PM
CG hook on aero tows?? Ted Wagner Soaring 130 January 12th 04 11:04 PM
