Bill,
You have still not confirmed if you are in fact the highly regarded Bill Daniels? I hope you are not, because each time you post, you loose any credibility by being rude and obnoxious. Why is it necessary to make statements such as "Yes, I read your ramble"? If you are the "real Bill Daniels" please let us know. If you are not, I am sure the "real Bill Daniels" will be royally ****ed off that you have been letting the wider population of the gliding community assume that you are whilst blighting his good name! Justin Craig At 13:43 14 October 2013, Bill D wrote: On Monday, October 14, 2013 3:43:07 AM UTC-6, Paul Ruskin wrote: On Monday, October 14, 2013 3:03:44 AM UTC+1, Bill D wrote: I don't get accident statistics from RAS comments. Which would be an admirable position Bill, except that I took the trouble to go and find the accident reports from the BFU and BGA and posted a list of winch accidents in my comment, including sources and accident report numbers. The data says that in the period 2006-12 a German pilot had much the same chance as a UK civilian pilot of being killed or injured in a winch accident. Perhaps you'd let us know whether you now accept that conclusion, rather than claiming that UK winch launches are 10 times more dangerous? Paul Yes, I read your ramble. The operable statistic is number of accidents per number of launches - very simple and not included in your post. For 2011 (The numbers just look worse for the UK the further back one goes.) The Germans suffered one accident every 180,000 launches The UK suffered one every 16,000 launches. That's better than 10:1 and the number can't be twisted to show parity. |
On Monday, October 14, 2013 2:43:37 PM UTC+1, Bill D wrote:
Yes, I read your ramble. The operable statistic is number of accidents per number of launches - very simple and not included in your post. OK. I note that you've avoided my question, which was whether we you agree with "The data says that in the period 2006-12 a German pilot had much the same chance as a UK civilian pilot of being killed or injured in a winch accident. " So, I'll ask again - do you agree with that conclusion? I've provided all the data you need, and its source, and the calculation is simple. Whether you think that's a good "operable statistic" or not is different. I happen to think it is - because then we don't confuse different reporting of incidents. Paul |
Paul did allow for the greater number of glider pilots and winch
launches in Germany and his figures are for fatal and serious injury accidents only. As I have pointed out to you before, the BGA accident statistics include all minor accidents and incidents that are even vaguely related to winch launching and which do not cause death or serious injury. There are probably 10 such incidents for every serious accident which probably explains the difference. There are lies, damn lies, and your interpretation of accident! Derek Copeland At 13:43 14 October 2013, Bill D wrote: On Monday, October 14, 2013 3:43:07 AM UTC-6, Paul Ruskin wrote: On Monday, October 14, 2013 3:03:44 AM UTC+1, Bill D wrote: I don't get accident statistics from RAS comments. Which would be an admirable position Bill, except that I took the trouble to go and find the accident reports from the BFU and BGA and posted a list of winch accidents in my comment, including sources and accident report numbers. The data says that in the period 2006-12 a German pilot had much the same chance as a UK civilian pilot of being killed or injured in a winch accident. Perhaps you'd let us know whether you now accept that conclusion, rather than claiming that UK winch launches are 10 times more dangerous? Paul Yes, I read your ramble. The operable statistic is number of accidents per number of launches - very simple and not included in your post. For 2011 (The numbers just look worse for the UK the further back one goes.) The Germans suffered one accident every 180,000 launches The UK suffered one every 16,000 launches. That's better than 10:1 and the number can't be twisted to show parity. |
At 02:03 14 October 2013, Bill D wrote:
I don't get accident statistics from RAS comments. The Dropbox link has changed. See: https://dl.dropboxusercontent.com/u/...Acceleration.p df Maybe the ancient Gehrlein winches you have in the US are not powerful enough to cause uncontrollable pitch ups, but we did have a problem with this when we first had powerful V8 Tost winches. K8's and the like would rocket up almost vertically before (usually) the weak link broke. Fortunately none of them flicked and all the pilots involved were quite switched on and managed to get the nose down and land safely. The problem was largely solved by opening the throttle a bit more gently at the start of the launch. The nice thing about the Skylaunch winches we have now is that they deliver the right amount of power for the glider type being launched, so you get the same ground run time for all types. So one less type conversion issue. The acceleration induced pitch up effect is only transitory by the way. During the ground run it is constrained by the tailwheel, and once the glider is safely established in the full climb the pull line and the c of g become more closely aligned. The dangerous bit is the rotation! If the mainwheel lifts off first, the glider pitches up to a steep angle and then the tailwheel lifts off and no longer constrains the pitch angle, it is at this point the wings may stall, and if any yaw is present may flick roll. The safety message is don't over-accelerate lightweight gliders and control the rotation rate so that it is not more than 10 degrees per second. Derek Copeland |
Number of aero tows in 2011 | Bill D | Soaring | 35 | November 21st 12 03:39 AM |
Looking for a Yellow Tow Release Handle | Randy Teel | Soaring | 3 | August 7th 12 10:36 PM |
Schweizer Tow Release Handle/Bracket | Jim Newton | Soaring | 2 | May 14th 10 05:17 PM |
Schweizer Tow Release Handle/Bracket | Jim Newton | Soaring | 0 | April 22nd 05 07:21 PM |
CG hook on aero tows?? | Ted Wagner | Soaring | 130 | January 12th 04 11:04 PM |
