Keep your hand off the release handle during aero tows!
Old October 12th 13, 07:22 AM posted to rec.aviation.soaring
Del Copeland
Default Keep your hand off the release handle during aero tows!
If the pilot is going to hold the release knob, which I would
assert is a good idea, his arm should not be at full stretch when
their is a chance of accidentally pulling it if turbulence is
encountered. There should be some slack in the system. If the
release knob is hard to get at, or a bit too far away, then an
extension cord should be added.
Derek Copeland
At 16:54 11 October 2013, wrote:
Hi George,
Thanks for your comments. You are correct that we do need to
remember the
a=
mazing guys and gals up in the tow planes and remember the
risks they take
to tow us up for our own fun. That said, I would like to assert
that there
have been many more accidents and bent ships from gliders
accidentally
rele=
asing at low altitudes because their hand was on the release
than tow
plane=
s being pulled into the ground because a hand was NOT on the
release.=20
Bruno - B4
Old October 11th 13, 10:29 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
On Fri, 11 Oct 2013 10:20:54 +0000, Del Copeland wrote:
That's what we told to do when we first acquired our Tost winches at
Lasham, in order to contain the speed and get the highest possible
launches. Prior to that we autotowed, where you had to initially climb
quite gently as the acceleration was slow and it took time to build up a
safe speed. After a few cases when K8's and similar lightweight gliders
went into near vertical climbs before breaking the weak link, we backed
off the instruction. Fortunately we didn't kill any of the pilots.
Dunstable went on launching quite steeply for some years until they had
a fatality caused by a flick spin. Certainly when we visited that club
we always used to hold our breath as we watched them winch launching
gliders. Some German pilots seem to pull up more steeply than we now do,
and I note from the accident statistics published earlier in this thread
that they have had a couple of flick spin fatalities in recent times.
Very interesting, and it may well explain a German photo I found showing
a Libelle around a meter off the ground, cable attached, but pitched up
steeply enough to make me, as a fellow Libelle driver who usually
winches, wonder just what happened during the next 2 or three seconds.
Unfortunately the photo only showed the front half of the glider so I
couldn't see what angle the elevator was at.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Number of aero tows in 2011 Bill D Soaring 35 November 21st 12 03:39 AM
Looking for a Yellow Tow Release Handle Randy Teel Soaring 3 August 7th 12 10:36 PM
Schweizer Tow Release Handle/Bracket Jim Newton Soaring 2 May 14th 10 05:17 PM
Schweizer Tow Release Handle/Bracket Jim Newton Soaring 0 April 22nd 05 07:21 PM
CG hook on aero tows?? Ted Wagner Soaring 130 January 12th 04 11:04 PM
