Keep your hand off the release handle during aero tows!
Old October 13th 13, 10:57 PM posted to rec.aviation.soaring
Del Copeland
Default Keep your hand off the release handle during aero tows!
Hi Bill,
Did you read Paul Ruskin's analysis of German and UK winch
launching accidents, which was number 66 in this thread. He
concluded that there was no significant difference between fatal
and serious accident rates between the two countries. I note that
Germany had about 4 accidents that came into the stall and flick
roll category while the UK only had one. Germany has about 5
times as many glider pilots as the UK. About 2/3rd's of UK glider
launches are by winch. As Skylaunch has sold many winches to
Germany and Tost to the UK, I assume that the winches are
similar and give the same rates of acceleration in both countries.
BTW, before we had winches at our club, we used to wire launch
by autotow, where the ground run acceleration was REALLY
slow, at least 10 seconds to lift off. I don't remember there
being any ground loop or cartwheel accidents on take off in that
era.
Derek Copeland
At 17:47 13 October 2013, Bill D wrote:
On Thursday, October 10, 2013 4:05:22 AM UTC-6, Terry
Walsh wrote:
Fred,
=20
=20
=20
I did not intend this as a comment against Americans I know
equally
=20
arrogant people of many different national origins. I was
simply
commenti=
ng
=20
that if this indeed Bill Daniels then he could be considered to
be an
=20
expert on winch operations, but his apparent refusal to
accept any other
=20
opinion than his own was more than a little arrogant.
I've let the UK "echo chamber" run a bit so they can all
congratulate each
other for fuzzy thinking.
Arrogant? Indignant and angry are a better words. Every
time you screw
up=
, it has enormous impact outside the UK. When those screw-
ups are based
on=
institutionalized nonsense, and you try to export that
nonsense, it makes
me angry. An example is the winch launch section in the 2013
Glider
Flying=
Handbook.
The main source of my guidance isn't from the US, or my own
imagination,
i=
t's the German SDO Segelflugbetriebsordnung. It contains
about the best
inf=
ormation on winch launch safety available.
The US stands accused of "doing few winch launches". That's
true.
Compare=
d to the roughly one million annual launches in Germany, the
UK doesn't do
many either. That, and their superb safety record, makes
Germany a far
bet=
ter source of safety information.
If you want an educational approach, read my thoughts on the
acceleration
p=
hase and acceleration induced uncommanded rotation.
https://dl.dropboxusercontent.com/u/...Acceleration.p
df
Old October 14th 13, 03:03 AM posted to rec.aviation.soaring
Bill D
I don't get accident statistics from RAS comments.
The Dropbox link has changed. See:
https://dl.dropboxusercontent.com/u/...celeration.pdf
Old October 14th 13, 09:40 AM posted to rec.aviation.soaring
Tom Gardner[_2_]
I don't get instructions about how to fly safely from RAS comments.
Old October 14th 13, 10:43 AM posted to rec.aviation.soaring
Paul Ruskin[_2_]
Which would be an admirable position Bill, except that I took the trouble to go and find the accident reports from the BFU and BGA and posted a list of winch accidents in my comment, including sources and accident report numbers.
The data says that in the period 2006-12 a German pilot had much the same chance as a UK civilian pilot of being killed or injured in a winch accident.
Perhaps you'd let us know whether you now accept that conclusion, rather than claiming that UK winch launches are 10 times more dangerous?
Paul
Old October 14th 13, 02:43 PM posted to rec.aviation.soaring
Bill D
Paul
Yes, I read your ramble. The operable statistic is number of accidents per number of launches - very simple and not included in your post.
For 2011 (The numbers just look worse for the UK the further back one goes.)
The Germans suffered one accident every 180,000 launches
The UK suffered one every 16,000 launches.
That's better than 10:1 and the number can't be twisted to show parity.
Old October 14th 13, 02:56 PM posted to rec.aviation.soaring
Justin Craig[_3_]
Bill,
You have still not confirmed if you are in fact the highly regarded Bill
Daniels?
I hope you are not, because each time you post, you loose any credibility
by being rude and obnoxious. Why is it necessary to make statements such as
"Yes, I read your ramble"?
If you are the "real Bill Daniels" please let us know.
If you are not, I am sure the "real Bill Daniels" will be royally ****ed
off that you have been letting the wider population of the gliding
community assume that you are whilst blighting his good name!
Justin Craig
trouble
list
numbers.
same
accident.
rather
Paul
per
goes.)
Old October 14th 13, 04:18 PM posted to rec.aviation.soaring
Paul Ruskin[_2_]
OK. I note that you've avoided my question, which was whether we you agree with "The data says that in the period 2006-12 a German pilot had much the same chance as a UK civilian pilot of being killed or injured in a winch accident. "
So, I'll ask again - do you agree with that conclusion? I've provided all the data you need, and its source, and the calculation is simple.
Whether you think that's a good "operable statistic" or not is different. I happen to think it is - because then we don't confuse different reporting of incidents.
Paul
Old October 14th 13, 04:56 PM posted to rec.aviation.soaring
John Galloway[_1_]
accidents
post.
had much the
a winch
accident. "
provided all
simple.
different.
different reporting
of incidents.
Paul
There can be no doubt when an injury or a fatality occurs and
such an event should always be reported and recorded in
gliding developed countries. I think we can all agree that no
country will over-report death and injury data. Therefore the
only way that comparison of death and injury rates between two
countries could *not* be based on valid operable statistics is if
you were to believe that one country is under-reporting them -
which would be an interesting propositon to put to the Germans.
John Galloway
Old October 14th 13, 05:22 PM posted to rec.aviation.soaring
Chris Nicholas[_2_]
John, Paul’s figures are for fatals and “serious” injuries, not all
injuries, AIUI. I would not be surprised if the definition of “serious”
differs.
Chris N
Old October 15th 13, 10:07 PM posted to rec.aviation.soaring
Del Copeland
Bill D has gone remarkably quiet!
accidents
post.
had much the
winch
accident. "
provided all
simple.
different.
reporting
of incidents.
Paul
Number of aero tows in 2011 Bill D Soaring 35 November 21st 12 03:39 AM
Looking for a Yellow Tow Release Handle Randy Teel Soaring 3 August 7th 12 10:36 PM
Schweizer Tow Release Handle/Bracket Jim Newton Soaring 2 May 14th 10 05:17 PM
Schweizer Tow Release Handle/Bracket Jim Newton Soaring 0 April 22nd 05 07:21 PM
CG hook on aero tows?? Ted Wagner Soaring 130 January 12th 04 11:04 PM
