Please don't install glass fuses, because they are prone to:
- blowing under vibration (like, rolling during launch) - even more prone to blowing in gas-powered motorgliders - corroding and introducing voltage drop at the (non-gas-tight) ends The voltage drop breakers introduce can be significant and can cause problems. Use blade types inline (not on the panel!) and avoid these problems... Hope that helps, Best Regards, Dave "YO electric" |
On Wednesday, October 16, 2013 5:26:48 PM UTC-4, Dave Nadler wrote:
Please don't install glass fuses, because they are prone to: - blowing under vibration (like, rolling during launch) - even more prone to blowing in gas-powered motorgliders - corroding and introducing voltage drop at the (non-gas-tight) ends The voltage drop breakers introduce can be significant and can cause problems. Use blade types inline (not on the panel!) and avoid these problems... Hope that helps, Best Regards, Dave "YO electric" Can blade fuses be installed in type certified gliders? |
Fuses in general | Tuno | Soaring | 19 | December 11th 08 06:45 PM |
fuses vs. circuit breakers | raulb | Soaring | 0 | November 8th 07 02:48 PM |
Bussman Fuses | kevmor | Piloting | 10 | May 25th 07 03:25 AM |
Bussman Fuses | kevmor | Piloting | 2 | May 22nd 07 09:28 PM |
Fuses versus Breakers | ContestID67 | Soaring | 14 | March 14th 05 01:47 PM |
