21m tipped Lak 17b!
Old October 20th 13, 10:35 PM posted to rec.aviation.soaring
Sean F (F2)
Default 21m tipped Lak 17b!
Damn right it will be!
I finished 5th overall in a lak17a (that's right, lak17"A"!) this year at 18m nationals. I am a very average, inexperienced and essentially new contest pilot. I seemed to keep up with 29's pretty well. I imagine the 17b (with its ability to to up to 1300 gross weight) will be far, FAR more "even" with the 29 that the 17a is. The 17a was initially designed as a 15m and is therefore limited to 1103 gross weight max.
http://www.ssa.org/ContestResults.as...eter+Nationals
From what I have heard, the 17b is far more advanced than the 17a in almost all key aspects. The wing is entirely redesigned as 15/18 and not just 15 with 18 extensions as an afterthought as the 17a was... The airfoils are similar to the Diana 2. So I think it will do extremely well in 18 meter competition when in the hands of a strong pilot.
In 15 meter configuration, the 17a is very good, similar to an ASW 27 which it was designed to beat. The 17b is almost certainly better 15 meter configuration that the 17a with an entirely new wing winglets, new airfoils, a redesigned vertical stab, rudder and all new horizontal stab.
In 21 meter I suspect it will be very good (60:1, similar to the JS1) otherwise why would they bother? Will it compete with a Quintus or a Concordia? I highly doubt it, but it would be a hell of a glider for the $$$...
Sincerely,
Sean Fidler
F2, Lak17a #114
Old October 21st 13, 12:53 PM posted to rec.aviation.soaring
Paul T[_4_]
Hmm - it's just in most Europeans and Worlds the 17b has ended up at the
botttom of the score sheets. Maybe the pilots and not the plane?.
The JS1C seems to cut it (at least in the French mountains and Texas
weather, ) with Concordia's, Quintus - so why not a 21m Lak ? (don't know
if they are upping the max weight for the 21m version ala the JS1C.)
Old October 21st 13, 04:32 PM posted to rec.aviation.soaring
Sean F (F2)
They need a strong US (or Canadian) pilot RACING the glider in US contests. Period.
The Uvalde and Euro pilots have not been top shelf. JS1 is better connected and has many top pilots flying their hardware in contrast.
I agree the 21 meter version needs to be at 850 if it is going to be seriously competitive at a world level BUT...in the US east coast contest environment it would probably be just fine if it was not able to achieve 850.
I'll check and see what the specs say on the website...
Old October 21st 13, 05:36 PM posted to rec.aviation.soaring
John Galloway[_1_]
You mean 850Kg?
If a 21m Lak 17B were to have a wing area similar to the
12.25m2 of the JS1C 21m then at 850kg MAUW it would have a
wingloading of over 69kg/m2! I am not sure where the water
would go. With the JS1C 21m you need to fill the wings, the
21m tips, have fuselage tanks full of water or fuel and a not too
lightweight pilot to get to the MAUW 720kg and 59kg/m2
Furthermore an 21m Lak 17 is likely to have an even smaller
wing area (and ?less water capacity) because the 18m Lak has
a wing area of 10.32m2 compared to 11.21m2 for an 18m JS1.
John Galloway
in US contests.
Period.
better
contrast.
to be
coast contest
achieve
850.
Old October 21st 13, 06:20 PM posted to rec.aviation.soaring
Paul T[_4_]
No specs on the website yet - but announced on Blanik America site and in
the article on the Mini Lak on their news pages about the tips.
I'm presuming you can fly at 15. 18 and 21m with the same ship? Which will
probably make it a popular ship in the US- and agree with Sean bargain
and piloting points.
Upping to 850 kg probably not on- but maybe around the 650-700kg mark?
which would probably give it a similar wing loading to the JS1 with the
smaller wing area.
Now I wonder if the asg 29 is going to be tipped to 21m? (I know its a
tipped 27! and they have the ASH 31).
At 16:36 21 October 2013, John Galloway wrote:
You mean 850Kg?
John Galloway
in US contests.
Period.
better
contrast.
to be
coast contest
achieve
850.
Old October 21st 13, 07:36 PM posted to rec.aviation.soaring
Sean F (F2)
Paul,
I just got an email back from Vytas (owner of Lak factory). Here is his statement: "MAX mass remains 600 kg as 18 m class mass, as no space for more water."
That makes sense to me. I think there is ZERO chance the ASG29 will ever get 21 meter tips OR 800kg max weight as its wing is simply not designed for the loads (just like the 17b). Also, the 18 meter tips barely fit in the trailer. Makes me wonder how the Lak17b could fit all these wingtips in a trailer as well. Anyway, the requirement for a 21 meter single for Schleicher has been fulfilled by the ASG 31.
Info on ASG31 --- http://www.alexander-schleicher.de/p...h31_main_e.htm
The 31, as with most motor gliders, has too much wing loading in 18 meter configuration when flying in weak lift. It is better at 21 meters where it can go to 700 kg and 10.8 lbs/sqft wing loading (no, not 800!). Min wing loading looks to be about 8.82 (with a 200 lb pilot) in 18 meter and 8.09 in 21 meter.
Hope this helps to answer your questions on the Schleicher's.
Sean
smaller wing area.
You mean 850Kg?
John Galloway
in US contests.
Period.
better
contrast.
to be
coast contest
achieve
850.
Old October 21st 13, 10:52 PM posted to rec.aviation.soaring
Sean F (F2)
Blanik America leaves a little to be desired in terms of website quality, for sure ;-)
For that matter, all the glider manufacturers websites are fairly poor to be honest.
Sean
On Monday, October 21, 2013 2:36:51 PM UTC-4, Sean F (F2) wrote:
Paul,
Sean
smaller wing area.
You mean 850Kg?
John Galloway
in US contests.
Period.
better
contrast.
to be
coast contest
achieve
850.
Old October 22nd 13, 06:20 PM posted to rec.aviation.soaring
Paul T[_4_]
Sorry - tounge in cheek comment about the 29 - I'm English. The problem
with ASH 31 (not ASG 31) is the motor and too much wing area -it was
designed more as a recreational self launcher than a competitive ship
Looks like the JSIc will be the best bang for the buck if your serious
competing in both 18 and Open Class - the Lak 17b maybe for 15 and 18m?
(depending on what the Ventus 2 replacement will be like!- but that'll
probably cost a lot more)
The JS1C certainly seems competetive with the Quintus and EB29 which cost a
fair bit more - but your also paying for the ability to self launch I geuss
with the latter two.
But I like the concept of a ship that can be flown at 3 diffferent spans!
Did Vytas say it can be flown at 15, 18, and 21m?
At 18:36 21 October 2013, Sean F F2 wrote:
Paul,
st=
more=
water."
g=
for=
a
Schleic=
her has been fulfilled by the ASG 31. =20
Info on ASG31 ---
http://www.alexander-schleicher.de/p.../ash31/ash31_=
main_e.htm
c=
it
l=
in=
21 meter.
Sean=20
in
=20
=20
=20
=20
wi=
ll
=20
bargai=
n
=20
=20
=20
=20
=20
=20
smaller wing area.
=20
=20
=20
=20
=20
=20
=20
=20
=20
=20
=20
=20
You mean 850Kg? =20
=20
=20
If a 21m Lak 17B were to have a wing area similar to the=20
=20
12.25m2 of the JS1C 21m then at 850kg MAUW it would have a=20
=20
wingloading of over 69kg/m2! I am not sure where the water=20
=20
would go. With the JS1C 21m you need to fill the wings, the=20
=20
21m tips, have fuselage tanks full of water or fuel and a not too=20
=20
=20
=20
Furthermore an 21m Lak 17 is likely to have an even smaller=20
=20
wing area (and ?less water capacity) because the 18m Lak has=20
=20
=20
=20
John Galloway
=20
=20
=20
=20
=20
=20
They need a strong US (or Canadian) pilot RACING the glider=20
=20
in US contests.
=20
Period.
=20
=20
The Uvalde and Euro pilots have not been top shelf. JS1 is=20
=20
better
=20
connected and has many top pilots flying their hardware in=20
=20
contrast. =20
=20
=20
I agree the 21 meter version needs to be at 850 if it is going=20
=20
to be
=20
seriously competitive at a world level BUT...in the US east=20
=20
coast contest
=20
environment it would probably be just fine if it was not able to=20
=20
achieve
=20
850.
=20
=20
=20
=20
=20
Old November 4th 13, 10:00 AM posted to rec.aviation.soaring
Tom Claffey
I flew beside the two Lak17Bs at Uvalde.
In my opinion the ASG29 (thanks Al) I flew was better.
I am not an Aeronautical engineer but to my eye the winglet and
winglet/wing interface just looked wrong. Dr Maughmer or others could
probably fix that.
A 21M version at the right wing loading would be possibly good per $ but
EB29 will eat it up in weak weather and the JS1 eat it up everywhere else.
IMO
Tom
t 21:35 20 October 2013, Sean F F2 wrote:
Damn right it will be! =20
1=
conte=
(w=
"even"=
and
http://www.ssa.org/ContestResults.asp?
contestId=3D2224&ContestDetailId=3D72=
39&ContestName=3D18+Meter+Nationals
almost=
15=
are
c=
ompetition when in the hands of a strong pilot. =20
which=
conf=
a
redesigned vertical stab, rudder and all new horizontal stab. =20
other=
Concordia?=
Sincerely,
Sean Fidler
F2, Lak17a #114
Old November 4th 13, 10:34 PM posted to rec.aviation.soaring
Sean F (F2)
Tom,
With all due respect ;-), I believe the Lak17b's you flew against in Uvalde were Lak17b FES models (Front Engine Sustainer, http://lak.lt/index.php?option=com_c...&Itemi d=136).
The 17b FES has a folding propeller system on its nose which, even though fairly slick, still has a few square inches of square structure in the airflow as well as two 18' propeller blades. This is especially disruptive when at higher speeds in flying locations such as Uvalde Texas.
The FES version of the 17b should actually have a decent handicap for this reason, not a penalty over a pure glider as the US rules currently. The US handicap committee has not thought this one out very well in my opinion. The 17b FES should have a fairly decent handicap advantage over the pure version, not vice versa based purely on the gross weight.
The pure version of the 17b would produce a different story from you I imagine. I believe it would give a 29 a hell of a problem based on the way the Lak17a performs against them this year at the US Nationals, 5th place... (http://www.ssa.org/ContestResults.as...ter+Nationals).
Also the pilots flying the 17b's in Uvalde were, admittedly, not the "creme of the Uvalde crop." They were there to have fun mainly and to show off the new FES system. If you put two evenly matched pilots into a 29 and a pure 17b, I imagine it would come down to the pilot and not the glider. Not a bad thing considering the Lak17b is a far less expensive glider, even with the impressive FES system added.
Its all about fun, and arguing about glider performance for me is just that, fun. So don't take this too seriously. I think the Lak is not given a fair shake by many. It is a very nice glider for the money and worth serious consideration by those looking for a versatile 15/18 and now even a 21 meter glider which has the option to use FES.
Sean
F2
probably fix that.
EB29 will eat it up in weak weather and the JS1 eat it up everywhere else..
IMO
Tom
1=
conte=
(w=
"even"=
and
almost=
15=
are
c=
which=
conf=
a
other=
Concordia?=
Sincerely,
Sean Fidler
F2, Lak17a #114
Interview with the managers of a flight school that tipped the FBI to Zacarias Moussaoui Matt Barrow Piloting 0 March 3rd 06 06:05 PM
