On Sunday, October 20, 2013 12:31:32 PM UTC-5, Darryl Ramm wrote:
Capitalized ZERO, like you really mean absolutely zero, nothing, zilch, nada? Ah in a word. No. A fuse will *not* have ZERO voltage drop. A typical fuse for a few amp application might have a voltage drop of ~100mV to ~200mV drop at the fuse rated current, and that depending on the fuse type and ratings). Darryl - Mea Culpa. Yep, you got me on that one. Maybe I will do better this time. Both fuses and breakers have an internal resistance which translates into a voltage drop (which depends on how much current you are drawing). Lets talk about a 1A load for nice round numbers (YMMV). Littlefuse 3AG fuse specifications (common glass tube); Rating Internal Voltage Drop Voltage Drop Resistance at rated Current at 1A ==== ========== ================ ============ 1A 0.19 0.19 0.19 2A 0.07 0.14 0.07 3A 0.04 0.13 0.04 4A 0.03 0.12 0.03 5A 0.02 0.11 0.02 Klixon CT series breaker specifications; Rating Internal Volts Drop Voltage drop Resistance at rating current at 1A ==== ========== ================ ============ 1A 1.10 1.10 1.10 2A 0.35 0.70 0.35 3A 0.13 0.40 0.13 4A 0.09 0.37 0.09 5A 0.07 0.35 0.07 Take aways; - Fuses have significantly lower voltage drops than breakers by an average of 4x ... but it AIN'T ZERO! - The higher the current circuit protection device rating, the less voltage drop. - Covering your panel with low rated fuses or breakers for each and every instrument isn't a good idea. - Circuit protection devices in series with another device compounds the problem. For example a master fuse sourcing individual device fuses. Each layer drops more voltage. - As had been said over and over again in this and other RAS threads, and bears repeating, a single large value fuse at the battery is your single best overall safety bet. - One last thing - Per most manufacturers breakers should not be used as on/off switches. The only one I have found that can be used as an on/off switch is the Tyco W30 and W31 series. - John |
Anyone have any experience with the ETA - 1110-F112-P1M1-5A – circuit breaker/switch? Jonker used these on the early JS-1. See: http://www.newark.com/eta/1110-f112-...-5a/dp/98K5389
Tuesday, October 22, 2013 4:00:27 PM UTC-4, JohnDeRosa wrote: On Sunday, October 20, 2013 12:31:32 PM UTC-5, Darryl Ramm wrote: Capitalized ZERO, like you really mean absolutely zero, nothing, zilch, nada? Ah in a word. No. A fuse will *not* have ZERO voltage drop. A typical fuse for a few amp application might have a voltage drop of ~100mV to ~200mV drop at the fuse rated current, and that depending on the fuse type and ratings). Darryl - Mea Culpa. Yep, you got me on that one. Maybe I will do better this time. Both fuses and breakers have an internal resistance which translates into a voltage drop (which depends on how much current you are drawing). Lets talk about a 1A load for nice round numbers (YMMV). Littlefuse 3AG fuse specifications (common glass tube); Rating Internal Voltage Drop Voltage Drop Resistance at rated Current at 1A ==== ========== ================ ============ 1A 0.19 0.19 0.19 2A 0.07 0.14 0.07 3A 0.04 0.13 0.04 4A 0.03 0.12 0.03 5A 0.02 0.11 0.02 Klixon CT series breaker specifications; Rating Internal Volts Drop Voltage drop Resistance at rating current at 1A ==== ========== ================ ============ 1A 1.10 1.10 1.10 2A 0.35 0.70 0.35 3A 0.13 0.40 0.13 4A 0.09 0.37 0.09 5A 0.07 0.35 0.07 Take aways; - Fuses have significantly lower voltage drops than breakers by an average of 4x ... but it AIN'T ZERO! - The higher the current circuit protection device rating, the less voltage drop. - Covering your panel with low rated fuses or breakers for each and every instrument isn't a good idea. - Circuit protection devices in series with another device compounds the problem. For example a master fuse sourcing individual device fuses. Each layer drops more voltage. - As had been said over and over again in this and other RAS threads, and bears repeating, a single large value fuse at the battery is your single best overall safety bet. - One last thing - Per most manufacturers breakers should not be used as on/off switches. The only one I have found that can be used as an on/off switch is the Tyco W30 and W31 series. - John |
Quote: "Anyone have any experience with the ETA - 1110-F112-P1M1-5A – circuit breaker/switch? Jonker used these on the early JS-1. See: http://www.newark.com/eta/1110-f112-p1m1-5a/circuit-breaker-thermal-250v-5a/dp/98K5389"
Quote: "One last thing - Per most manufacturers breakers should not be used as on/off switches. The only one I have found that can be used as an on/off switch is the Tyco W30 and W31 series." MANY good comments in this entire thread. I don't like (glass) fuses. I do like Tyco W31 breaker(s)/switch(es) in my panel. See http://www.aircraftspruce.com/catalo...?clickkey=5950. More information here http://aviation.derosaweb.net/presentations/ |
Fuses in general | Tuno | Soaring | 19 | December 11th 08 06:45 PM |
fuses vs. circuit breakers | raulb | Soaring | 0 | November 8th 07 02:48 PM |
Bussman Fuses | kevmor | Piloting | 10 | May 25th 07 03:25 AM |
Bussman Fuses | kevmor | Piloting | 2 | May 22nd 07 09:28 PM |
Fuses versus Breakers | ContestID67 | Soaring | 14 | March 14th 05 01:47 PM |
