Master Switch
Old October 24th 13, 10:17 PM posted to rec.aviation.soaring
John Strzebrakowski
Default Master Switch
I have just rewired my Lak19T and have shared your frustration with the
small panel. I have Butterfly vario, Butterfly dispaly for powerflarm,
ClearNav vario and display (remotely mounted, Oudie (remotely mounted) ASI,
T/S, Radio and Altimeter all packed in running off two extra batteries
mounted 'in' the wheelbox. The standard batteries and mountings supply the
engine management.
For the instruments two terminal strips are mounted at the side of my knees
in the sloping part of the panel and the common earth sits on the floor of
the panel behing the ASI.
There are two way switches and fuses for each instrument. A master switch
each for engine and instrument circuits.
Have fun i did. i am sending a photo of the panel but photo of the rear of
the panel or a circuit diagram will take a little longer.
Oh i forgot there is panel space for a transponder display but sadly not a
main unit but i think this might be able to go on the cockpit floor behind
the panel unit if i eventually fit one.
Strzeb
At 01:01 24 October 2013, Dan Marotta wrote:
Thanks Kirk,
The panel on my LAK is incredibly small and I'm pulling out my hair trying
to figure out where to cram terminal strips.
"kirk.stant" wrote in message
On Thursday, October 17, 2013 9:10:25 AM UTC-5, Dan Marotta wrote:
Or I could simply divide my equipment across two (or three) busses and
then
rely on the load division to allow the batteries to last an entire
flight.
Dan, that's how I've had my LS6 setup for over 13 years and it has
worked
just fine so far.
2 separate busses, one for each battery, with load divided as equally
and
logically as possible (split varios and loggers, for example).
In addition, the master switch for each buss can also select either
battery, so if one battery fails (forgot to charge it?) the essential
instruments can be powered by the remaining battery.
Probably WAY over-engineered, but it was fun to wire up and has worked
as
designed so far (ugly to look at, though - bit of a spaghetti factory
behind that small LS6 panel that I want to clean up some day...).
Kirk
66
C-133A CARGO MASTER (USAF MUSEUM, DAYTON, OH) - "C-133A Cargo Master.jpg" yEnc (1/3) Glen in Orlando[_3_] Aviation Photos 2 July 8th 12 10:23 PM
C-133A CARGO MASTER (USAF MUSEUM, DAYTON, OH) - "C-133A Cargo Master.jpg" yEnc (3/3) Glen in Orlando[_3_] Aviation Photos 0 July 1st 12 01:14 AM
C-133A CARGO MASTER (USAF MUSEUM, DAYTON, OH) - "C-133A Cargo Master.jpg" yEnc (2/3) Glen in Orlando[_3_] Aviation Photos 0 July 1st 12 01:14 AM
Source for PA28-180 split master switch Mike Noel Owning 3 October 5th 05 02:29 AM
Master Switch Lakeview Bill Piloting 23 July 20th 05 01:46 AM
