East Coast winter ridge soaring?
Old October 28th 13, 04:46 PM posted to rec.aviation.soaring
Dan Marotta
Default East Coast winter ridge soaring?
Wouldn't that be Mid-Atlantic Soaring Association?
"Soartech" wrote in message
Depends on whether you'll have your own sailplane or if you are expecting
to rent? Rental possibilities are very few.
We have gliders. Thanks for the info.
David, what is M-ASA?
Old October 29th 13, 03:14 AM posted to rec.aviation.soaring
JS
Doesn't a place called "Ridge Soaring" in Julian, PA have tows? How do the "Irregulars" get into the air? With a name like that, is their best lift from a ridge? Is it nearby? Has anyone ever flown a fast or long distance out of there?
And there's Blairstown, NJ... Home of the Pudnockers. But then you never see names like Schwartz or Templin (stand by for reactions from others like Mann) posting long flights on OLC.
Old October 29th 13, 01:49 PM posted to rec.aviation.soaring
Ridge Soaring usually stops ops when the weather turns bad (late Nov-mid Dec?)and re-opens in March. But when the weather is right, extremely long flights are possible. This is the premier soaring location in the east. Its world famous for a reason.
Old October 29th 13, 04:29 PM posted to rec.aviation.soaring
JS
Thanks, didn't realise that there was an off season.
Once drove from California to Julian in November: 3 days in the same cold front.
The flight the next day had some interesting sections due to the down side of the wave hitting the ridge. Keeps your attention!
Then went to Blairstown and if declared would have beat the STD 300k O/R state speed record then held by "The Scoundrel".
Not bad for a commute to work.
Would Benton, TN be less snowy in Winter?
Perhaps there's a gliderport near the other half of the same ridge system in N Africa.
Old October 29th 13, 07:20 PM posted to rec.aviation.soaring
Papa3[_2_]
Don't forget about Mifflin. You can start on the Mifflin Soaring Association website: http://msasite.ridgesewing.com/index.htm
We operate pretty regularly in the winter from Blairstown, though it's always best to call Yards Creek Soaring in advance. Some of the best ridge happens during the winter as long as there's not too much snow on the ground. The key is the appropriate clothing, especially shoes and boot warmers.
P3
Old October 29th 13, 07:52 PM posted to rec.aviation.soaring
Papa3[_2_]
Oh, and it probably goes without saying, but if you just use the OLC and sort by airfield within Region 2 or Region 4, you have most of the ridge system covered.
http://www.onlinecontest.org/olc-2.0...sc=2&sp=20 13
Almost all of the really long flights from the top airfields in this list are ridge/wave missions.
P3
North East US ridge flight resources Greg Delp Soaring 15 February 24th 14 11:18 PM
USS Liberty survivor Phil Tourney to be on Radio Liberty programtoday at 4 PM on the west coast and at 7 PM on the east coast NOMOREWARFORISRAEL[_2_] Naval Aviation 0 September 26th 08 11:24 PM
D.C. anti-war rally on C-SPAN today at 8:15 AM on the west coast of US and at 11:15 AM on east coast - President Carter at Brandeis on C-SPAN 2's 'Book TV' today at 12:30 PM (on the west coast and at 3:30 PM on the east coast): [email protected] Naval Aviation 0 January 27th 07 02:18 PM
East Coast Visibility Kyle Boatright Piloting 23 June 25th 06 09:03 PM
A fine ridge day in PA - the Ridge Soaring Irregulars ride again QT Soaring 0 April 6th 06 04:01 PM
