Are we gonna fly today or will the eight hour test and evaluation session
use up all available daylight? "son_of_flubber" wrote in message ... On Wednesday, November 13, 2013 8:17:22 AM UTC-5, Tom wrote: The reality is there have indeed been fatalities due to over-strong tow ropes, and one of the preventative measures is to use a rope designed to break in case of over-stress. The problem is that rope degradation is not recognized and defective ropes are used until they fail prematurely. Is it a problem that we use tow ropes of a type that is subject to rapid degradation? The structural part of the rope is exposed to abrasion and UV. The open weave of the rope allows grit to penetrate and destroy the rope from the inside out. We use ropes that are dirty and show signs of "acceptable" wear. We test our ropes by towing the next glider. Rock climbers approach this problem differently. Their ropes are designed to minimize the penetration of grit. The function of the outermost wrapping of the rope is to protect the structural core from grit. When the outermost protective wrapping is worn, the rope is discarded. In the old days, rock climbers would wash their ropes in the washing machine to remove micro grit. Three questions: 1)Would a simple visual inspection find 99.9% of bad tow ropes before they break (Prematurely)? Do "good" towropes ever break? 2)Are we using the right type of rope? 3)Is there a way to test a tow rope on the ground without destroying it? If you applied a known load to a tow rope (on the ground) and measured the elongation, would this not give an objective estimation of the condition of the rope? (As fibers break or weaken, the rope will elongate more under a known load). If the elongation is outside the limits, the rope is retired. Would a magnifying glass improve the visual inspection process? |
On Thursday, November 14, 2013 10:50:46 AM UTC-5, Dan Marotta wrote:
Are we gonna fly today or will the eight hour test and evaluation session use up all available daylight? Good point. Time is limited. If an elongation test would detect weakening ropes, you would only need to do it once a week or so because many forms of degradation is gradual. If you had a permanent jig for testing elongation, it would take 10 minutes. Or you could test the ropes at the beginning of wave season when you know they are gonna get stressed (or even better, you could replace your ropes at the beginning of wave season). Ever have a rope break at Moriarty? I know that you have a lot of grit. |
Our ropes are 200 ft long so the jig would either have to be very large or
the rope would need to mounted and dismounted numerous times. I've had three rope breaks in the past three years while flying the tug at Moriarty - never before in the previous 20+ years. Two were the fault of the glider pilot horribly mishandling the glider and one of those resulted in the rope being wrapped around the wing of the HP-14. The wing was cut back to the spar before the rope broke. The third rope break had one of our instructors flying his Libelle and the rope broke at about 300' AGL on tow. He and I were both surprised and he handled the emergency perfectly. The rope broke about 10 feet in front of the glider, probably in an area of high wear. We inspect our ropes daily in the morning and during operations throughout the day. If sufficient wear is noted, the rope is replaced. More often it's the weak link which gets replaced due to abrasion with the pavement. We use the top half of drinking water bottles, slipped over the weak link, and wrapped heavily with duct tape. These work well, but, if the tug lands such that the protector hits the end of the runway, it's ripped off. We then replace the weak link. (Whew!) "son_of_flubber" wrote in message ... On Thursday, November 14, 2013 10:50:46 AM UTC-5, Dan Marotta wrote: Are we gonna fly today or will the eight hour test and evaluation session use up all available daylight? Good point. Time is limited. If an elongation test would detect weakening ropes, you would only need to do it once a week or so because many forms of degradation is gradual. If you had a permanent jig for testing elongation, it would take 10 minutes. Or you could test the ropes at the beginning of wave season when you know they are gonna get stressed (or even better, you could replace your ropes at the beginning of wave season). Ever have a rope break at Moriarty? I know that you have a lot of grit. |
Is there a difference between a Winch launch Weak Link, and an Aerotow Weak
Link? I would think the Winch launch requires a much stronger link because of the higher angle of attack. At 00:46 15 November 2013, Dan Marotta wrote: Our ropes are 200 ft long so the jig would either have to be very large or the rope would need to mounted and dismounted numerous times. I've had three rope breaks in the past three years while flying the tug at Moriarty - never before in the previous 20+ years. Two were the fault of the glider pilot horribly mishandling the glider and one of those resulted in the rope being wrapped around the wing of the HP-14. The wing was cut back to the spar before the rope broke. The third rope break had one of our instructors flying his Libelle and the rope broke at about 300' AGL on tow. He and I were both surprised and he handled the emergency perfectly. The rope broke about 10 feet in front of the glider, probably in an area of high wear. We inspect our ropes daily in the morning and during operations throughout the day. If sufficient wear is noted, the rope is replaced. More often it's the weak link which gets replaced due to abrasion with the pavement. We use the top half of drinking water bottles, slipped over the weak link, and wrapped heavily with duct tape. These work well, but, if the tug lands such that the protector hits the end of the runway, it's ripped off. We then replace the weak link. (Whew!) |
On Friday, November 15, 2013 7:04:22 AM UTC-5, Peter Higgs wrote:
Is there a difference between a Winch launch Weak Link, and an Aerotow Weak Link? I would think the Winch launch requires a much stronger link because of the higher angle of attack. Peter - you seem to confuse angle of attack with deck angle. The angle of attack of the glider during a winch launch is no different than if the glider was in free flight at the same speed! During a winch launch, the glider is flying up a trajectory with a deck angle of up to 45degr. And yes, the weak link strength spelled out in the plane's POH typically call for a stronger one for the CG hook vs. the nose hook. With our winch, we measured the line forces and the results show an interesting force distribution - not at all what everybody expected. Uli Neumann 'GM' |
At 12:39 15 November 2013, GM wrote:
... The angle of attack of the glider during a winch launch is no different than if the glider was in free flight at the same speed! Actually, it is significantly different: the wing has to deal with the tension in the cable (including the cable self-weight) as well as supporting the weight of the glider. This could easily double the AoA required in steady flight & smoth conditions towards the end of a winch launch. |
long range aircraft flying short-range routes? | tupolev204 | Piloting | 10 | April 22nd 11 07:44 PM |
FAA Administrator and FAA on the ropes and going broke | PapaFoxTrot | Piloting | 0 | September 16th 08 03:33 PM |
Charging system failure cuts short a long X-Country | Ron Lee[_2_] | Piloting | 10 | November 15th 07 11:04 PM |
Tow Ropes | [email protected] | Soaring | 6 | July 15th 05 07:39 PM |
Plasma Ropes ----- Help | Dave Martin | Soaring | 7 | September 30th 03 11:23 PM |
