Speed triangle on ridge
Old November 17th 13, 08:39 PM posted to rec.aviation.soaring
WAVEGURU
Default Speed triangle on ridge
All turnpoints are on the windward side of a ridge. I would probably mark a thermal coming off the ridge near the start, start the task and go back to the thermal and get high enough to make the second turn. ( in a perfect world ) These are bluffs with flat tops so not a lot of sink downwind of the face.
Old November 17th 13, 10:56 PM posted to rec.aviation.soaring
I'm not totally clear on the geometry, but if you are trying to get to a ridge it is perfectly classic final glide MacCready theory. Set a ridgetop point as your final glide point, then fly to it as if final glide. It is much faster to climb higher in a strong thermal and bomb to the ridge than it is to stop soon and go to the ridge slow. For example, if your best glide is 53 kts, and you're in a 53 kt wind but have 10 kt thermals, going higher and faster will get you there, flying 53 kts will not. Same downwind.
John Cochrane
Taxi calculator? (propeller type and speed, aircraft weight, taxi speed) John Doe[_4_] General Aviation 0 February 3rd 11 10:55 PM
FAI triangle records speed question Bruno Soaring 1 June 6th 09 05:05 PM
500 km Triangle at 306 km/hr in Argentina Paul Remde Soaring 36 January 3rd 07 08:48 PM
A fine ridge day in PA - the Ridge Soaring Irregulars ride again QT Soaring 0 April 6th 06 04:01 PM
FAI triangle in SEE YOU Paul Feltz Soaring 2 July 7th 04 07:46 AM
