GE proposes to use artificial sink to generate 500 MW of power inSouthern AZ
Old November 19th 13, 12:56 AM posted to rec.aviation.soaring
bill palmer
Default GE proposes to use artificial sink to generate 500 MW of power inSouthern AZ
I have to look at it from a conservation-of-energy standpoint. Where is the energy that is converted to electricity coming from?
The only answer I see is from the heat of the ambient air that transfers to the water droplets to evaporate the water, thus cooling the air, making it more dense. etc.
I'd be amazed if that is more energy than it takes to pump if up 2200 feet,(much less desalinate and pump from 50 miles away)!
Also, when the air passes through those turbines at the bottom, that's going extract energy from the air, and probably re-condense a lot of that water.. Are they going to collect and pump that water back to the top? The more they can, the less water they have to desalinate and pump from the ocean.
On Monday, October 28, 2013 2:24:27 PM UTC-7, son_of_flubber wrote:
http://www.industrytap.com/massive-e...tric-grid/3811
2250 foot high evaporative cooling towers to be used to generate power.
Bush Proposes To Cut Funding For Airport Improvements. Larry Dighera Piloting 0 March 11th 08 04:00 PM
FAA Proposes $130 Recurring Aircraft Registration Fee Larry Dighera Piloting 0 March 11th 08 03:35 PM
FAA Proposes $130 Recurring Aircraft Registration Fee Larry Dighera Owning 0 March 11th 08 03:35 PM
Does the elevator/stabilator generate upward force? Dan Piloting 20 December 6th 06 04:19 PM
Linux: generate ICAO SELCAL tones just like on aviation radio Dan Jacobson Instrument Flight Rules 0 October 11th 04 01:16 AM
