Linear Actuators on Trailer
Old November 27th 13, 11:32 PM posted to rec.aviation.soaring
Dan Marotta
Default Linear Actuators on Trailer
I'm not a mechanical engineer, but I've seen lift struts encased in square
tubing. There are two square tubes, sized to slide into each other. They
are attached to the pivots on the top and bottom of the trailer using the
same bolts that attach the gas strut to the trailer.
It would appear that the square tubing would support the gas struts and
prevent or reduce the tendency to bend.
But, then again, I'm not a mechanical engineer.
On Wednesday, November 27, 2013 2:05:09 PM UTC-5, Steve Leonard wrote:
Are they bending when extended or retracted? Check on the mechanism to
make sure you aren't getting something nearly on center when open. If
you go there, loads go out of sight high, and you can bend things when
you try to move it back the other way.
Steve Leonard
They bend when bringing the top down. They bend to the back of the
trailer.
The trailer weighs in at 1200lbs. sq tube truss construction covered in
aluminum sheeting. suspect from the size of the top it weighs in at a
good 600lbs+.
2013 Cobra trailer price list needed for TA trailer sale [email protected] Soaring 0 June 22nd 13 02:42 PM
How well does linear polyurethane paint hold up to flying in wave and sunlight? son_of_flubber Soaring 0 October 1st 12 01:52 AM
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 02:11 AM
FS:CS-10 VHF communications linear amplifier RPE Home Built 2 January 17th 07 05:30 PM
FS Communications Specialist CS-10 Linear amplifier RPE Aviation Marketplace 1 January 3rd 07 03:08 AM
